Like Tree5Likes
SC10 4x4 Thread
Old 10-06-2011 | 09:28 AM
  #8161
FRONTI3R's Avatar
Originally Posted by Chad Smith
Any pics. So i can get an idea on what to use and how it works.
This is with the RPM limiters:
You should have some small Gray limiter clips that came with your SC10 4x4.
FRONTI3R is offline
Old 10-06-2011 | 09:29 AM
  #8162
take the shock end off.. put the amount of shims.. or.. fuel tubing.. or even orange shock orings on the shock shaft.. then thread the shock end back on..
dgrobe2112 is offline
Old 10-06-2011 | 09:33 AM
  #8163
got beat to it.. here is a picture..
the limiters go between the shock eyelet, and the shock body.. btw.. be sure to make sure your spring retainer clip seats normally..
i believe your truck should have come with limiters in it..
Old 10-06-2011 | 09:44 AM
  #8164
Originally Posted by jpure009
BONDobird,
RX8 instead of Mamba monster
The only real advantage that the rx8 has over the monster is that you can run a sensored motor right? From what I'm told a 1:10 scale 4x4 with a strong 4 pole will never come close to needing a 210amp ESC and 100-120amp is ideal. Am I misinformed?
Bondobird is offline
Old 10-06-2011 | 09:53 AM
  #8165
Originally Posted by FlatBusted
what would be a good gearing to start with on a Pro4 4000/Rx8 on a small (90x40) indoor track?
Run 0 on the timing advance slider and start at 15/62.
Krio is offline
Old 10-06-2011 | 10:10 AM
  #8166
Chad Smith's Avatar
Thanks for the pics guys.
Chad Smith is offline
Old 10-06-2011 | 10:37 AM
  #8167
turbotron's Avatar
Originally Posted by BlueGlowBoy
Kinda hard to see on the green background, but you need the red and black from the servo to go to the BEC, and the white/yellow signal wire to still go to the RX so that you get the signal from your radio.
it worked man! thanks for all your help! no glitching, no nothing. smooth smooth!
turbotron is offline
Old 10-06-2011 | 10:56 AM
  #8168
Originally Posted by dgrobe2112
here is mine.. ready for this weekend.. see what happens.. and if i can break anything.. lol.. hope not..
Are you running RC Pro Finals this weekend or Lone Star Classic at Indy? Either way, y'all all suuuuuck! Had to pull out of RCP Finals due to kid's conflict.
So we really do need to limit uptravel on this truck? I need to look at the design again. Did I just buy a giant sized XXX-4?
cjtamu is offline
Old 10-06-2011 | 11:00 AM
  #8169
JFuel11's Avatar
Default It has to be close...
I have an amp logger that I play around with on the track form time to time and even a 17.5 non-boosted 2wd buggy can pull a peak amp draw upwards of 85+ amps. When you consider the weight and power of the motors we are running in the 4wd sct trucks it is very easy to assume that peak amp draw could easily exceed 150+ amps. I need to do some data logging on my 4wd to confirm.
JFuel11 is offline
Old 10-06-2011 | 11:23 AM
  #8170
no finals for me this weekend.. i am running in killeen saturday..
i been wanting to run up at mikes in dallas.. when i head that way.. i holla at ya.. see if your gonna be there
Old 10-06-2011 | 11:46 AM
  #8171
SourDieselX's Avatar
Just wondering if anyone could recommend me a good servo, about to start the build process in my truck and wanted to get that taken care of.
SourDieselX is offline
Old 10-06-2011 | 12:16 PM
  #8172
Chad Smith's Avatar
Yea its better to buy a good servo the first time than break it and have to take the hole front end apart to get to the servo. Hear is a link to the servo I use. http://www.hitecrcd.com/products/dig...hs-7965mg.html Plenty of speed with that servo. With this truck any servo you run you will need to turn down your steering rate.
Old 10-06-2011 | 12:30 PM
  #8173
i run ko servos.. cant agree more.. put a good servo in there.. so you dont gotta replace it any time soon..
Old 10-06-2011 | 12:41 PM
  #8174
Yeah, we were talking about DFW Mike's earlier this year. Big Phil was wanting to go up there, he says it's still the same dirt. Be a good weekend road trip. Mike's in Porter is having an RC Pro 4wd SC Nationals race first week in November. RC Signup has the days weird though, practice on Wednesday, through Sunday. I have to check my schedule for that week. might be fun, not too far from home for me. Looked today, both Tabush the Younger and Tabush the Elder are signed up. Jorge and I should push for an old man class LOL.
Sourdiesel, that's a good servo. There are others by Savox (1258TG), Futaba (9551, 9452) that are as good and in about the same price range or a little less. MKS also has a nice little servo (DS1009) with similar specs to the above, but for about $45. Haven't used one, know a couple guys that do, they like it. You can look on their website. Whatever you get, you want metal gears, transit speed of .12 or better and torque of 115 or more oz/in (both at 6 volts). Digital preferred over analog.
And +2 or whatever on buying a good servo. Most people that have been doing this for awhile learned the hard way not to cheap out on servos.
cjtamu is offline
Old 10-06-2011 | 01:39 PM
  #8175
why did i think you up in dallas area.. my bad.. been a while since i been to Htown.. but might have to make a trip..
