Like Tree5Likes
SC10 4x4 Thread
Old 10-12-2011 | 08:47 AM
  #8476
MantisWorx's Avatar
Originally Posted by SourDieselX
would anyone here in Houston be willing to drill the shaft for me to do the pinned modification for me if I hook them up with a few extra bucks? I'm not real sturdy with a drill plus lack some of the tools.
i can do it for you, i live off of 290 and barker.
MantisWorx is offline
Old 10-12-2011 | 08:49 AM
  #8477
SourDieselX's Avatar
ha perfect, i'm off 290 and fry
SourDieselX is offline
Old 10-12-2011 | 08:50 AM
  #8478
MantisWorx's Avatar
Originally Posted by Vegatron75
STRC makes the pulleys.
I'm heading to the track tonite. Gotta try out the "new and improved pinned slipper"
I'm tying 45F/40r, Yellow fronts/ blue rears, rcshox 2 stage pistons V1,garolite pads, 22mm RH.
I'll report back.
i can tell you now that 45/40 is way too high on the oils, its going to bounce all over the place. i had 45 in the front of mine but i had the comp drilled out to 1.2. anything over 35 in the rear is just going to lock up and you may even break the lower piston, remember that your pack comes from the pistons coming together......
Old 10-12-2011 | 08:51 AM
  #8479
MantisWorx's Avatar
Wow! pm me, im headed to MM right now to try this stuff out, will be back around 3.
Old 10-12-2011 | 10:45 AM
  #8480
Artikbot's Avatar
Just tested the pinned out frontend...
HOLY SMOKES BATMAN!!
It gained SO MUCH acceleration!! It's almost unbelievable!
not to mention I've cut laptimes quite a lot due to the much higher on-power steering partially due to the front end pulling harder.
Artikbot is offline
Old 10-12-2011 | 11:05 AM
  #8481
Botwoon's Avatar
Pinning my shaft today, expecting good results.
Botwoon is offline
Old 10-12-2011 | 11:06 AM
  #8482
Jmuck69's Avatar
That just sounds gross...TMI.
Jmuck69 is offline
Old 10-12-2011 | 11:08 AM
  #8483
Artikbot's Avatar
I expected a nice upgrade and I got TREMENDOUS performance benefits!
Artikbot is offline
Old 10-12-2011 | 11:09 AM
  #8484
CraigMBA's Avatar
Originally Posted by murky123
This truck does best with smooth driving and clean lines.
Easy to do in qualifying if you have skills. The chassis has pace.
In stock form, impossible to do with lapped traffic in front and a fast Losi behind and you have to make a move off the "optimal" line.
IMO all the changes we are trying to make to the truck make it easier to drive, and more consistent lap for lap. Pinning the decoupled slipper is a step in that direction. Basic chassis development stuff.
CraigMBA is offline
Old 10-12-2011 | 11:11 AM
  #8485
Wild Cherry's Avatar
Tech Legend
Tell us how your drilling the shaft in detail if you could please
Wild Cherry is offline
Old 10-12-2011 | 11:29 AM
  #8486
ShortCourseOnly's Avatar
I can understand that the pinned front slipper disk is will improve on-power front grip. I am about to assemble my kit and plan to start with hthe garolite disk on the inside and the stock pad on the outside. Do you think this will provide good front grip?
ShortCourseOnly is offline
Old 10-12-2011 | 11:30 AM
  #8487
CraigMBA's Avatar
And it's better under braking. And the chassis is noticeably less pitch sensitive front to rear. And you can now use all the motor. And you can turn the brakes up.
This might be the best $0.05 I ever spent in 21 years messing with RC cars.
CraigMBA is offline
Old 10-12-2011 | 11:41 AM
  #8488
CraigMBA's Avatar
Once you pin the front drive belt, I'm not a big fan of mixing pads since the slipper doesn't slip independently F/R anymore.
I would use the same pads across the slipper with the pin modification (no matter if you were using the basket or not). Once you get it adjusted properly, I'd expect the forward bite to be the same no matter which one you choose. IMO only difference between them is going to be how long they last before you have to do maintenance on them.
If users are going to leave the slipper decoupled, I'm certain everyone will find some magic cocktail of slipper pads that work best for them (we have a couple hundred pages of just that in this thread).
CraigMBA is offline
Old 10-12-2011 | 12:17 PM
  #8489
1Fastpede's Avatar
Wait till you change the ackermann bar.
1Fastpede is offline
Old 10-12-2011 | 12:19 PM
  #8490
BlueGlowBoy's Avatar
The guy you quoted didn't say he was going to pin his shaft...in fact, he insinuated the opposite... he was asking if running the better pad on the front would increase front grip.... his mindset being that "if pinning the front is the 'best' way, and I don't want to start drilling anything YET, would putting the higher grip pad for the front wheels and a lower grip pad for the rears accomplish a similar result"
At least, that's how I read it...and I think he's onto something...if you don't want to drill your top shaft....
BlueGlowBoy is offline
