Like Tree5Likes
SC10 4x4 Thread
Old 08-29-2011 | 12:34 PM
  #6976
Slotmachine's Avatar
Originally Posted by nmdesertracer
Just got a email back from RPM there making a-arms for our 4x4 . Should be out soon..
I got the same reply, about a month to new RPM arms for the truck.....
Also got a reply from the Associated team and they said to store the truck on blocks to keep from warping them............
Slotmachine is offline
Old 08-29-2011 | 12:37 PM
  #6977
CraigMBA's Avatar
Originally Posted by jboquire
Just like they did on the nationals.....wait, they didn't
Sure, and AE isn't making an update shaft and backplate because there isn't a problem to fix. :
CraigMBA is offline
Old 08-29-2011 | 03:31 PM
  #6978
Cameron Kellogg's Avatar
That's a good fix. Maybe if I leave my truck on a block my slipper won't slip either.
Cameron Kellogg is offline
Old 08-29-2011 | 04:02 PM
  #6979
JayL's Avatar
R/C Tech Elite Member
that's what the 1/8 nitro buggy/truggy guys do as well
JayL is offline
Old 08-29-2011 | 04:14 PM
  #6980
Yeah I know, I was just being a smart @$$.
Old 08-29-2011 | 04:21 PM
  #6981
Originally Posted by Wild Cherry
Yes , but installed up ft now , not in back ....
heard he just got 2nd in 4w at the SCNats in CT.
Was just a one day due to storm .
it was just one round, but his truck looked amazing.. scott and billy fischer where battling the whole qualifier, scott passed billy , then billy passed him back. they qualified 1 and 2.. awesome qualifier to watch.... 90 entries in the 4x4 class, not bad considering we had a hurricane in the forcast.. 300 entries
in case anyone was wondering he was running 30k front diff 5 rear, 1.3 pistons with 30wt oil
nazman01 is offline
Old 08-29-2011 | 04:24 PM
  #6982
Jorge T's Avatar
Originally Posted by T-BirdJunkie
The inside shaft is on the pin, the outside probably still has the flat keys.
By pining the front pulley to the shaft they've eliminated the de-coupled (random) slipper. the outer hub flat key drives the rear. Now its like a touring car with a slipper...
I really like the way the clutch basket works, its very predictable and allows for tuning front rear bias w/pad size. I run a Novak 4.5 14mm rotor, boosted 60 on a RX8, geared 14/58. It, with other tweeks and weight balance took almost 2 seconds of my lap times , just by being able to jump farther and get on the power earlier.
This track we run at is huge. my only problem now is i have to be carefull braking, it will flip me truck at the end of the 200 ft straight! Looks retarded watching your truck flip off the track
Jorge T is offline
Old 08-29-2011 | 04:33 PM
  #6983
Wild Cherry's Avatar
Tech Legend
Jodge , sorry you got it all wrong , the slipper still performs same as before....Just the rear plate can't slip & now you can adjust or loosen the slipper as intended for even better performance & traction ...
Wild Cherry is offline
Old 08-29-2011 | 04:46 PM
  #6984
Now the front and rear gearbox is "locked/pinned" to the rear gear box shaft. The slipper slips now like it does on the 2w trucks.
Old 08-29-2011 | 04:53 PM
  #6985
Jorge T's Avatar
I understand that the slipper will still work, but if they pinned the rear shaft to the front pulley, the front and the rear cannot move independently. what slips is only the spur between the two fixed slipper hubs.
Currently the rear hub is indexed to the front pulley. The drive comes from the pressure on the thrust washer from the whole slipper assembly. decoupled, hence the problem.
The outer hub is indexed to the shaft and drives the rear w/gears.
Unless they did something totally different from what you described, it would not be decoupled anymore
Jorge T is offline
Old 08-29-2011 | 04:56 PM
  #6986
Tech Legend
The problem was the rear plate slipping when you ran a loose slipper , now that won't happen , design & performance is still the same ....
With the old style slipper ?
It sometimes demanded a very tight setting to keep the rear plate from slipping.
Canceling out any benefit the slipper could bring to the car as the slipper was about locked up to get proper acceleration ...
Old 08-29-2011 | 04:59 PM
  #6987
When you say rear slipper you are talking about the outter slipper plate correct.
This would be so much easier with pictures.
Old 08-29-2011 | 05:05 PM
  #6988
Tech Legend
The first plate installed behind the spur has the notch for the new pin on the top shaft ...
Not for sure , but the outside plate looked the same ....
I got to examine the parts just before installation....
Old 08-29-2011 | 05:08 PM
  #6989
ITS ME DAVID's Avatar
I'm waiting for the new parts I'v seen to cure the slipper .
Ae have a way better solution....
Orly fare to share some details
ITS ME DAVID is offline
Old 08-29-2011 | 05:09 PM
  #6990
OK that is what I thought you were talking about.
