Like Tree5Likes
SC10 4x4 Thread
Old 01-21-2012 | 07:34 AM
  #15421
Originally Posted by Evil Genius jr.
I am in need of some setup help. I am suffering from major under-steer both on and off power. I attached my setup. Thanks!
https://docs.google.com/open?id=0Bz8...g4ZDVlYzU4Mjdl
The first thing that jumps out to me is the battery placement, have you tried moving it forward? that might help.
jnyrcr is offline
Old 01-21-2012 | 07:36 AM
  #15422
Evil Genius jr.'s Avatar
I have tried moving it forward however the battery wires interfere with the hold down if I do.
Evil Genius jr. is offline
Old 01-21-2012 | 07:38 AM
  #15423
Is there any way to put it in with the wires to the back?
jnyrcr is offline
Old 01-21-2012 | 07:42 AM
  #15424
:facepalm: Duhh, Thanks! It works!
Old 01-21-2012 | 07:50 AM
  #15425
Cool, give that a try, there's other things you can do as well if that docent give you enough, I noticed you don't have any spacers under your ball studs on your shock tower, that might help as well, but I'd do one change at time if it's handling descent the way it is, definitely would look at some of the factory team setup sheets to get some ideas, good luck.
jnyrcr is offline
Old 01-21-2012 | 08:47 AM
  #15426
BlueGlowBoy's Avatar
30K is too much up front. Going up into higher diff weight in the front is to increase understeer, and I would expect exactly what you have described by running that thick up front.
In the beginning, there was too much rotation in the truck running 3k and 3k. Some even went as high as 60K for a bit, but we've worked out many other ways to get this truck planted. Most guys now, who are running a "regular" slipper setup, seem to be going 7k-10k up front with a rare 15k. 30k is way too high!
BlueGlowBoy is offline
Old 01-21-2012 | 08:55 AM
  #15427
Thanks! I will order some 5K, 7k and 10K and then start with the 7K.
Old 01-21-2012 | 08:57 AM
  #15428
Thomas P's Avatar
My tip.
20front
3k rear
Yellow springs on all 4 corners, same rest setup as you have..i have superb grip on carpet, and would not go for Yelloow sways...
Thomas P is offline
Old 01-21-2012 | 09:02 AM
  #15429
Wild Cherry's Avatar
Tech Legend
Originally Posted by CoyoteSlash
Or maybe they are perfectly honed straight, and your precious Factory Team did something wrong with 'numerous' shipments of Stock arms...
If you were correct ...
Wouldn't I be able to find the same problem
with my or other Sc10 4x4 arms ?
Wild Cherry is offline
Old 01-21-2012 | 09:33 AM
  #15430
Cain's Avatar
Tech Legend
Originally Posted by Thomas P
My tip.
20front
3k rear
what is your full setup for carpet?
Also are you using a clutch basket?
For you guys using clutch baskets, what are you using for diff fluids?
Cain is offline
Old 01-21-2012 | 10:10 AM
  #15431
Chad Smith's Avatar
10k up front and 5k rear
Chad Smith is offline
Old 01-21-2012 | 10:18 AM
  #15432
Misfit138's Avatar
+1
Misfit138 is offline
Old 01-21-2012 | 10:58 AM
  #15433
vito's Avatar
i keep my diff and shock oil out side in a cover will it be fine . hope not to buy new oil?
vito is offline
Old 01-21-2012 | 10:59 AM
  #15434
Cain's Avatar
Tech Legend
Originally Posted by thebizz
I am one of these guys having this problem with the Ix8 on 2S with the pro4 4000kv. at first Lrp said it was a motor issue but 3 of us local guys did some quick R&D and showed them that it wasn't . Since then I run the TC spec with the pro4 4000kv. and its been awesome! Hope they get that firmware update soon!
here is a pic of the IX8 in the truck
for your exotek saddle setup, what parts did you need exactly to do that and did you have to modify the chassis in any way?
Cain is offline
Old 01-21-2012 | 11:09 AM
  #15435
So after inspecting my truck I saw the steering knuckles were rubbing on the arm causing binding, Anyone else have this problem?
