Like Tree5Likes
SC10 4x4 Thread
Old 05-18-2011 | 03:39 PM
  #1501
Originally Posted by JayCrash450
Who has the most packs through their truck? What does the long term durability look like for this thing?
I am one who loves to go to practice and slam down pack after pack. I know things should cool, and I do wait a little between runs. I take good care of my stuff I just like to run like crazy. I had a hyper 10sc that I ran alot and gave me little problems in the durability department (just handled like crap on the track). I will be running mine in a few days. Sold that hyper months ago in anticipation of this sc10. The rx8 and sc4x should be here today in the mail...cant wait!
I have been running mine quite a bit , trying to find a setup that would give me the same awesome feel that my Losi has. I have found the truck to be very tough. Infact today I was hitting a jump at RCIS that was built to be singled on to a table top and then off the table to the down side of another single. The only model that I know of that has ever cleared it all is my elec 1/8 scale. I have seen some Pro's try it with nitros, some quite a few times heh Pattishal? and never make it. Well today I cleared it with my new SC10, but not without about 6 missed attempts and really big crashes. All I managed to damage was some body abuse. This confirms to me what I had conluded during the build, the SC10 is very well built truck with plastic that is top notch. I have not noticed any wear on the metal pieces , but nor would I expect to yet.
good luck and enjoy your new truck
Lon_L is offline
Old 05-18-2011 | 03:42 PM
  #1502
SaladFork's Avatar
It's durable...
+ YouTube Video
SaladFork is offline
Old 05-18-2011 | 03:52 PM
  #1503
[QUOTE=SaladFork;9131699]It's durable...
so funny, looks just like the big wrecks I had during testing today. I saved the durability portion till after setup testing though
Lon_L is offline
Old 05-18-2011 | 04:51 PM
  #1504
bschanz's Avatar
Originally Posted by symmetricon
I forgot to ask is the clicker locked or loose. The rear end gets squirly when on breaks whin the clicker decoupled. Try tightening it down ,then brake a high speed. If It moves straight, then it was just from the cicker.
Clicker is loose. Have not had a chance to run it again. Pesky job got in the way today.
ben
bschanz is offline
Old 05-18-2011 | 05:27 PM
  #1505
Racecrafter's Avatar
The new shock orings we have installed are ridiculously smooth.
Testing went well as there was a very slight sign of wetness around the lower part of the cartridge (possibly due to the lube during assembly).
Until I get these under a few more battery packs and through a few races I won't give them 100% approval. If they do pass muster then we will have them for sale on our site. Somewhere around $2.50-3.00 a full set.
Racecrafter is offline
Old 05-18-2011 | 06:05 PM
  #1506
i had a shock on the front that would leak where the cartidge is screwed to the shock body. I took some teflon tape and put it on the threads, screwed the pcs together and then trimmed the excess with a razor blade now no leaks at all.
bseckel is offline
Old 05-18-2011 | 06:24 PM
  #1507
where do you measure the ride height? the rear of the chassis is alot higher then where the tub part starts
cjm1126 is offline
Old 05-18-2011 | 06:28 PM
  #1508
I didn't take my shocks that far apart but I looked at the manual and it appeared as though there is no o-ring that seals the lower cartridge. I could see that as a problem and I could see Teflon taking care of any leaks there if that's the case. Are there any o rings or something else that seals the lower cartridge against the shock body?
JayCrash450 is offline
Old 05-18-2011 | 06:44 PM
  #1509
bschanz's Avatar
Default cvds
hey guys and gals, i seem to have been a little generous with the black grease when building the cvds and after a few packs at the track, they are getting caked up with grit. I can see this leading to failure, as I am a low maintenance kind of guy. has anyone tried dry chain lube like pedro's ice wax from cycling to lube high friction, exposed areas? I might try it and see how it works.
Ben
bschanz is offline
Old 05-18-2011 | 07:37 PM
  #1510
BlueGlowBoy's Avatar
Originally Posted by Gas Rat Racin
If wanna go back even further it was called SODA Off Road Racing. Thats back when my parents raced.
Yeah, I have the Papyrus video game based on that.... horrible by today's standards, but I still load it up once in a while to remind myself how twitchy 2wd can be!
BlueGlowBoy is offline
Old 05-18-2011 | 07:44 PM
  #1511
MarqueeRc's Avatar
I personally liked when it was called the Mickey Thompson series!!
MarqueeRc is offline
Old 05-18-2011 | 08:35 PM
  #1512
dirtybird 808's Avatar
anybody running tekin RX8 esc and redline 4.5 motor set up feedback appreciated
aloha
dirtybird 808 is offline
Old 05-18-2011 | 09:36 PM
  #1513
ktm11rider's Avatar
aloha
I am but only have had a chance to run it in the street a few times. motor about 120 after half a pack in the street. at a 13 tooth 32 pitch pinion now might have to drop to a 12 for the race memorial day weekend. RX8 runs nice and cool only two lights lite up
ktm11rider is offline
Old 05-18-2011 | 09:48 PM
  #1514
Dusttt's Avatar
I think I have a decent sway bar set up.
I used sway holders from my Xray T3 2011
http://www.amainhobbies.com/product_...Holders-T2-008
Some parts from a Losi Ten SCTE sway bar kit.
http://www.amainhobbies.com/product_...-Bar-Kit-Ten-T
and I bent some 2mm music wire. You can even use set screws and yes the bumper clears. I just finished the front and will do rear tomorrow.
Dusttt is offline
Old 05-18-2011 | 09:51 PM
  #1515
SaladFork's Avatar
Man this truck is WAY more durable than I thought...
+ YouTube Video
