Like Tree5Likes
SC10 4x4 Thread
Old 05-17-2011 | 10:35 AM
  #1351
Wild Cherry's Avatar
Tech Legend
Originally Posted by isarctard
Has anyone modified the rear chassis to make it easier to tighten the motor when using a 550 Novak with a 15t pinion? If so got any pics?
Just use a x knife and trim a little off chassis, you hardly need to trim much off at all...
Wild Cherry is offline
Old 05-17-2011 | 10:48 AM
  #1352
BlueGlowBoy's Avatar
Curious....do any of the other AE vehicles use this ESC/Transponder tray? I couldn't find any... maybe this is a taste of things to come...
I want to use it either way, just for the plain and simple fact that it has some extra cushioning, but I'm one of the unfortunates that has to run a servo extension with my Savox if I want to keep the receiver in the box... (odd that some savoxs fit, but others use shorter wires...)
BlueGlowBoy is offline
Old 05-17-2011 | 10:54 AM
  #1353
Originally Posted by JEFFs SC10
Is anybody running the Savox 1258? Is it enough servo? how do you like it? I'm thinking of getting this vs the ds1015.
input is appreciated.
I use this servo and I feel it works very well. It has plenty of torque, but the amazing part is the speed. Going from my poor memory I believe it is .08 and 167 tq or something close. anyway I believe the Savox 1258 to be a great value.
also the wire on mine was long enough to reach the Receiver box.
Lon_L is offline
  #1354
No AE vehicles use this exact radio tray.
Some dont want to run an extension, I can appreciate that if there concern is that it might come lose at some point in the future. However, look at the rc8be's ( I have one and think its the greatest thing ever) and most run a servo extension for the esc due to the distance across the chassis. I run an extension for the esc on my rc8be and will have no problem running an extension for my sc10 4x4.
Heres a little trick for those concerned with the extension. For a little added security against the connector coming lose, take a small zip tie, run it between the wires and zip tie the connectors together. Problem solved.
JayCrash450 is offline
Old 05-17-2011 | 10:58 AM
  #1355
Originally Posted by JoeC
I can not get my slipper to engage no matter what I try. Are you guys sanding the pads or the disc?
check to make sure you have the thrust washer assembly correct. if you install the silver washer incorrectly your slipper can not engage correctly.
Lon_L is offline
Old 05-17-2011 | 11:00 AM
  #1356
Originally Posted by SaladFork
Ditto...
And here is a shot of my electronics...
Very Nice looking rig you got there Salad.
Lon_L is offline
Old 05-17-2011 | 11:03 AM
  #1357
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Salad...how is one supposed to eliminate the switch from a Viper ESC? Is that a plug on the switch for a transponder?
T-BirdJunkie is offline
Old 05-17-2011 | 11:06 AM
  #1358
1fastslash's Avatar
Default 3s question
HI guys i was wonder if AE says its a 2s truck because thats the roar rules or because most 3s batterys wont fit the truck or if its because the drivetrain cant handle 3s . my 5000 mah 3s batterys will fit snug as a bug in the battery tray but i am afraid to run it because i dont wanna ruin my truck . whats your guys opinion on this .Thanks
1fastslash is offline
Old 05-17-2011 | 11:10 AM
  #1359
SWAMPER's Avatar
no thats the plug for the programmer i think
SWAMPER is offline
  #1360
JEFFs SC10's Avatar
That's the one I have my eye on.
JEFFs SC10 is offline
  #1361
SWAMPER's Avatar
ROAR
SWAMPER is offline
Old 05-17-2011 | 11:11 AM
  #1362
BLbound's Avatar
That's the same reason I'm using the tray...for the extra cushioning I'm not going to use the receiver box...the tracks I run on are indoor clay tracks so there's really little use for the box for me. I do run a outdoor track every now and then but I'm not worried about getting a few pebbles of dirt on the chassis.
BLbound is offline
  #1363
SaladFork's Avatar
Thanks Lon, the AE just looks to nice with the Viper gear.
TBJ, this isn't a Castle ESC, the buttons do not fail you will not need to cut it off or worry about it failing lol. That port on the on/off button is where the Progauge plugs in, this eliminates the need to unplug the receiver plug to program. Comes in handy if your receiver is tucked away.
SaladFork is offline
Old 05-17-2011 | 11:12 AM
  #1364
Originally Posted by FRONTI3R
Here is mine all built and ready to go. It's my older GFX Designs Body pictured! New Body is being paited by GFX designs as we speak - it's the one in my Avatar.
Looks great good job.
Lon_L is offline
Old 05-17-2011 | 11:14 AM
  #1365
As a former nitro guy, ThunderbirdJunkie remembers the switch that KO or Hitec or whoever it was made that was a pushbutton...those failed pretty regularly, ha.
Buttons and switches just don't instill a lot of confidence.
