#6481
I saw no less than three rx8's let the majic smoke out last year, my three original mmp's are still running strong, all have 1-2 seasons of racing on them ;P
#6482
Rage ease up will you? I don't own a MMP but why be so arrogant and childish about the matter to others by laughing at there misfortune??I have seen this sytem run great in the SCTE when properly setup !!So we get it, you love the Rx8 and say you have had nothing but problems with the MMP.Yet there are also others have had good experiences with the MMP, so plz get over it and just move on!!
#6485
#6487
Put my truck on the track for the first time last night. Indoor high traction. Runnin mmp and castle 3800 motor hitec 5955. Installed new diff pins made by guy here locally and 5/5/3 in the diffs. I am super impressed w/ the truck and motor.i was able to turn some really fast laps right away w/ the stock setup otherwise. Racin friday nite so hope to lay it down on the mostly slash 4x4's still runnin. And convert those waitin on the ae truck lol
#6488
I put one in my sc10. Using a mmp and orion 8.5 w/ hitec 5965. Had a few glitchin issues before but ran some practice w it and seemed good. Seemed the esc was able to give the motor a lil more power since not powering anything else!! Probably get one for my scte too
#6490
That's what I used(castle BEC) and I have had awesome results with it. I had a lot of servo chatter, and even issues with my throttle, I installed my Castle BEC and all the issues disappeared. It runs super smooth and consistent. I was really happy with the results and would recommend it to anyone. I run my castle ESC with Castle motors so I don't know if that helps the MMP not blow up. To me it makes sense to buy the same brand ESC as the motor you have if you want the best results as they were designed to work together. I know at my track many people have had issues with Tekin and most use Castle products there. I don't know why some people have issues with Castle and others don't, or the same with Tekin. I think whatever ESC you buy make sure it is designed to work with whatever motor you use. Seems like most of the ESC's start losing reliability if you are using them at more than 75% of their capabilities. I get less is not more in Electric Setups more is more if you want reliability. JM2C
#6491
Welll the snows gone the tracks good finally and I am all a titter in anticipation of the first launch of my new SCTE this afternoon.... I just hope I was lucky enough to get one with the hard pins... when i changed the diffs it has decent screrws that seemed to have no issues with stripping i wonder if theres a reloationship between shitty screws and shitty pins.... we shall see.
film at 11:00.
you guys have NO idea how good you have it in socal or anycal for that matter.
film at 11:00.
The losi has stock rubber but calibers on order and that might make a difference too.
Thanks Losi!!!!
and with RX8 / tekin 550 and 17 tooth pinion
ran a bit hot on the motor (170) but ESC was at 93 so I think i'm gonna go a bit bigger on the pinion as that seems to be the general consensus here.
Hot motor cool speedo = more gear
outside temp was about 70f earlier but about 40f later coat and hat weather.
#6492
Welll now I understand what you guys mean by "its like cheating"... wow does it handle nice right out of the box. and being from the north we do things differently like run 7-10-2 in the diffs and it seems to work well like that but seemed to push a lot in hi speed sweepers so this AM it was teardown the center diff and check the pins which are just starting to groove slightly so its on the shelf until pins arrive or get fabricated. I was alternating losi for 1 batt, slash for 1 batt and there are advantages with both i actually found the losi to be better in the tight stuff and the slash better at speed.
Thanks Losi!!!!
Thanks Losi!!!!
#6493
Hotwire on order for better fine tuning of the rx8 too. but its a shelf queen until the chrispins arrive dont want to take a chance of chewing up the gears.
good thing i still have a slash to run for now
I know of course how the poor lil slash is scorned on this thread but it still goes pretty good...
#6494
So far for racing the SCTE, the 3 hole RX8 has been the best speedo I've used in it. It's smooth, adjustable, no BEC or glitch busters needed, switch is good, and overall fairly reliable.
#6495
Those are pretty heavy oils in the diffs. When you rebuild with the chris pins seriously consider dropping down to 5-3-3. Unless you are on carpet or smooth very high bite you diffs are too heavy IMO. You will get better stability and high speed steering going to lower oils.
