#4951
Nice to see it worked out for you, I'm sure other bashers will appreciate the info. My guess to why you had no reply is that not many people are interested due to most race a tracks and this would be illegal at nearly every track. Even the most lenient tracks w/ rules will make you run SC wheels/tires.
#4952
so are they the 810 hubs? i managed to find a set on line. they're on the way. i converted my slash and have a few sets of 1/8th scale tire i wanna run on a track i go to that has sct open class. do they rub on the body alot? get the wing mount n tail with the 810 body and your good to race two classes lol
thanks
thanks
#4953
It's odd that you have read enough to know there's a problem but missed the fix. Your best bet is to contact Chris Attebery (sp) on here as he's making and selling them or get the deminsions and goto a local machine shop and have them made. The dimensions have been posted but I don't know them offhand. Good luck.
#4954
Running a Macbook pro.
#4955
If you used the stock 810 axles & hexes then your car will be too wide for ROAR and probably the body. I used the Ten-T axle stubs and the 810 hexes(modifided). To use the 810 hexes on the Ten-T stubs you have to shave the flange off the back of the hexes till its only about .5mm. Then they will mount correctly and be the proper width to fit the wheels under the body.
#4956
i just put the mamba max pro system in my truck and now i'm looking for the right battery. i'm goin to run 2s, so what battery size would be the way to go. what's the minimum c rating? also when losi gets the pin issue taken care of will we be able to get them for free and how will we know when and how?
#4957
The thing that irritates me about this whole diff pin deal is that i was promised interim pins in a few days and permenant pims in a week or two. I haventseen a thing in two weeks. I passed on Chris's pins because i trusted Horizon was telling the truth. I am not upset but its ridiculous they lied to buy themselves time. Now i missed out on the first several shipments. Screw Horizon, im going to buy Chris' pins...
#4958
Let's change the subject Here's some shots I took of my SCTE. First the dirty pics
Now some clean pics. The white body is my practice/race body. The blue body is my "show" body lol.
With DE Wheels:
With DE Wheels:
#4960
I have my Mamba Monster Timing set to highest, Geared at 20pinion, And my temps stay below 140. The ESC stays at 80ish Degrees in 70 degree weather. Pretty Built proof system.
I purchased my MMM separately from the motor. So i haven't tried the 1/8th motor in it. Only reason is because i want to stay and 2s. The 1/8th motors do better with 3s+
I out preform buggies at my local track with this set up.
#4961
thank goodness we got chris
#4962
So does anyone know know what the extra lexan pieces are for that come with the body? I know the square ones go right behind the cab but what are those triangle ones for? Also did I lose the screws for the body fins or did the truck not come with them to mount the fins on the body? Or can someone tell me what they used to mount them.
Yea, those baffeled me as well.. They are just reinforcement peices to place on the back side of the body where the numberplates go.
#4963
#4964
#4965
Yeah i read the dimensions and wrote them down but I don't have the tools to accurately make them. I saw where people got the "Chris Attebery" pins but didn't know exactly how to purchase them. and as far as it being odd that I missed the fix...u try reading through 331 pages in 1 night.
