Like Tree9Likes
Old 03-28-2011, 07:53 PM
  #5101
Originally Posted by BashemSmashem
IDK about the anti squat but it looks like 2 degree toe in on the rear .
Thanks.
[QUOTE=racenut123;8878102]I believe it 2 antisquat 3 toe.......Little help from Casper?
If I had to guess, I'd say this too. What I'm wondering is anyone running more of either.
THE DOC is offline
Old 03-28-2011, 07:59 PM
  #5102
Trader Rating: 32 (100%+)
I have run 3-3.....going back to stock.
racenut123 is offline
Old 03-28-2011, 08:02 PM
  #5103
i got a beast for this truck~~~hope to test in coming weeks
Tenshock SC401 brushless motor
4 poles
5200kv
5mm bore
dia. 36mm / length 63mm
Attached Thumbnails Losi 1/10 TEN-SCTE ARR 4x4 Short Course Truck Thread-sc401.jpg
Marco926 is offline
Old 03-28-2011, 08:05 PM
  #5104
Blitzrockey's Avatar
Trader Rating: 33 (100%+)
4 poles
5200kv
5mm bore
I was thinking of getting one of these for a spare to my sp v10, pm me and lemme know how you like it when you get it if you could thanks man
Blitzrockey is offline
Old 03-28-2011, 08:50 PM
  #5105
Trader Rating: 31 (100%+)
Originally Posted by pballer2777
i'm about to change the grease in the diff out for some fluid. were should i start? racing on a hard outdoor surface that starts out slick anf gains grip as more racing get done on it..
It depends on your track and driving style. I am smooth on the throttle and like a lot of off power steering and rear traction. I have 5-5-2 in my truck now on a dry dusty low to medium traction when it is watered. I may try 5-5-3 or 5-7-3
Check this out:
http://www.rc411.com/pages/howto.php?howto=24
flysullivan is offline
Old 03-28-2011, 09:24 PM
  #5106
4 poles
5200kv
5mm bore
keep us posted. I was checking out some of there motors online the other day!
Theroc is offline
Old 03-28-2011, 09:31 PM
  #5107
Originally Posted by 8ight-e
When your wrong your wrong....
Ok so I decided to really test my sidewinder SCT ESC to make sure it would be ready for race night (Thursday) so I started chasing the kids around down stairs in tight quarters. I had prviously only run it in the driveway and on the street, nothing too hard on it. I figured if it can take some play and some 360's I would be safe for race night. About 5min in the ESC let out the magic smoke. Not good even with a fan for the 4x4 SCT's unless all you do is run some speed passes and play in low resistance areas. I pulled it out and tossed my MMp back in and WOW what a difference, the 3800 w/ MMp is really smooth, nearly as smooth as the tekin 4.5 was just runs way cooler. At any rate my story.
I was wrong about these little esc's they cannot take constant amp jolts really getting on it, it may pass for some mild play but I'm hear to say tell everyone this is proven, it cannot work. PS my scte is only 6.33lbs too!
I didn't have this experience at all. I ran the SCT system with a fan on the ESC and it ran just fine after practice and a whole night of racing. However, the motor got really hot so I put the castle motor fan on it for the next race day. I didn't have any issues racing with the SCT ESC at all, it ran like a champ and never got over 130 degree's with the fan on it. However, The motor on the other hand was running in the upper 140's even with the fan so I swapped the whole system out with a MMP and HV4.5. The MMP runs around 130 and the fan never even turns on. Unfortunately, I found the HV motor does need a fan to keep it under 150 but the HV gives the truck that little extra grunt it needs.
I'm not sure what fan you used on your SCT ESC, but apparently it wasn't up to the task
I use sunon laptop fans and they have always done the trick for me
I just need to find a sub 6lb truck to put my SCT system in now
Starscreem is offline
Old 03-28-2011, 09:38 PM
  #5108
Cult Racing's Avatar
Trader Rating: 42 (100%+)
4 poles
5200kv
5mm bore
i think thats what ill be getting for my backup losi after i see the results
Cult Racing is offline
Old 03-28-2011, 10:33 PM
  #5109
Originally Posted by D-money
the t8 motors do fit you dont have to shim anything all you have to do is remove a little plastic
grind down the bottom motor support u mean?
maybe can put a remark on the 1st page 'recommendations' MOD needed?
chiatw73 is offline
Old 03-28-2011, 11:42 PM
  #5110
hgrove99's Avatar
I watched the video that losi has on "how to rebuild the diffs" and i have a ? Adam Drake says during the video that the washers b3553 (im pretty sure) are not a must, and that he doesnt run them. I wanted to know if anyone with the scte has done this?
hgrove99 is offline
Old 03-29-2011, 05:00 AM
  #5111
jhautz's Avatar
Trader Rating: 86 (100%+)
You are the first person I've heard say that their 4.5 motor runs cooler than the 1410 motor. What timing are you running?
jhautz is offline
Old 03-29-2011, 05:01 AM
  #5112
8ight-e's Avatar
Trader Rating: 58 (100%+)
You may have gotten a esc with some higher quality parts, I won't ever recommend this sysytem for a 6+lb vehicle. If it cannot do it consistently, it's not an option in my book. I now know of others who have also burnt their sidewinderSCT esc's. The motor seems to run about 8' cooler on the MMp, at least from my initial checks, not sure if anyone else noticed this as well or if it was a fluke. Thursday will be the real test, I'm hoping we have enough to race as a class. If not I will be spending extra time practicing and tuning with it reguardless.
8ight-e is offline
Old 03-29-2011, 05:10 AM
  #5113
pballer2777's Avatar
Trader Rating: 28 (100%+)
I have done this on my 8th scale cars. It frees the diff up a bit.
pballer2777 is offline
Old 03-29-2011, 05:21 AM
  #5114
Benny 13's Avatar
Originally Posted by jhautz
You are the first person I've heard say that their 4.5 motor runs cooler than the 1410 motor. What time are you running?
my 4.5 never sees over 12x's
Benny 13 is offline
Old 03-29-2011, 05:43 AM
  #5115
I have not even put my truck on the track yet and can see where the droop screws are eating up the chassis. Are most people using the droop screw pad mod from the 2.0 or limiting their shock travel? I have never done the shock limiter but it seems to me that this would be hard on the shock caps when the shocks are fully extended. Opinions?
Ram4whldr is offline
