This is camber.
We measure it with one of these.
http://www.losi.com/Products/Feature...odId=LOSA99172
Does this help?
This is camber.
Does this help?
yea, i get that much i just meant what holes mean what or when it says -1.5 you always use the gauge to check? i just looking over the sheet studying it but like where it says camber link it says "2" which i get but wasnt sure what if your turning the turnbuckles to get the -1 or if there is a hole change that gets you to those and then fine tweak with turnbuckles. I think i have the rpm monster camber gauge and by looking at pics online since its been so long since used that it does show 1* increments. But i just want to make sure i have the correct hole locations and all...im sure im over analyzing it but id rather be safe then sorry
I tried experimenting by using box stock rear springs in front and fronts in rear. I found cutting a coil off the previously rear springs worked well when using them in front. I find this is a cheap alternative to buying the racing spring sets.
Also, the hobby wing sct pro esc and 4000 kv motor simply kicks ass!!
Can someone give me the losi part # for a SCTE servo mounting kit(spacers & screws).
Thanks Rob
Thanks Rob
ok, and ya...be doin ass backawards if i didnt do height first and thanks for reminding me! What is the proper way to set ride height and is there another set-up that would be better for being outdoors or just stick to the Dunfords?
What are you guys doing about the excessive play and sloppyness that develops in the turnbuckle rod ends?
http://www.youtube.com/watch?v=LF2BjgLwXLk
We do ride hieght body off with the SCTE as it is hard to measure with the body.
Keeps slop away much longer!
ok, just what i thought...thank you very much! i'll keep studying and looking over my truck as i go until all parts get here and then knock this thing out...got alot of work ahead of me, lol!
Looking for opinion on best all round tire for truck. Racing on hard pack semi dusty tracks.
Not sure who I actually am stealing this from, but the best thing I've heard about slop in a Losi is this: Secret Losi Overtaking Power.
