I'm also a new SCTE owner, got a used roller.
The front driveshaft just fell off the pin fell out somehow looks like the holes are cupped out that the pin goes through I rotated it and put it through 2 fresh holes and buttoned it back up.
Question is this truck uses STANDARD? and not metric? WTF.... is there a screw kit somone can point me to to change it. none of my nice RC tools fit right lol had to use cheap random harbor freight allen keys from the garage.
Also I still can't find a exploded parts view. the one on the first page here is not very good is there a better one that shows all the parts and numbers with 1:1 pictures and sizes of every screw like HPI manuals have?
Thanks phreak, there is a set screw on mine, but it just clamps the thing to the shaft? seems like the plastic outer ring housing is what holds the pin in. What looks like happend is the pin moved and chipped/made the holes bigger. I rotated it to the other two holes that hadnt been used for now.
Do you have a part number for the new one?
Thanks, also is it just the front that does this and not the rear one?
He is talking about the pin that is inside the cup that keeps the drive shaft in the cup. It has a very tiny set screw in it and the pin is slotted in the middle.
Ok thanks i'll have to look into upgrading that.
the problem with giving you a part number is that it was a "running change", so the part numbers of the new style and old style are the same. so if you order it online, you won't know if you're getting old stock or new. the part number for the couplers is: LOSB3556 but again, no way of knowing if it's new or old unless you're buying from your LHS and can actually see if it has the set screw.
probably safer to just buy the king headz pieces: http://www.kingheads.com/product_inf...roducts_id=936
between my SCTE and 810 i've gone through 3 front/center CVD's and only 1 rear so the front is much more prone to going south.
Sweet thanks a lot. I'll go with the kingz headz if it falls apart again I got it working fine for now I think.
My LHS doesn't carry squat for anything.
Luckily mine fell out while I was installing a motor and just pushing my truck around on my table
Howdy, I'm new whit this electric cars and I have watched good short course car and I think I have found one. Yes, this car may be the perfect bashing and maybe someday racing But I want know it is good to buy RTR or Rolling Chassis version...
If I buy Rolling Chassis version what motor, lipo, radio etc I have to buy with it. I'm not very good with electric stuff that's way I drive nitro cars but now I want to make it easier to drive in the winter
So what I can buy with those money's what I get save when I buy Rolling Chassis version. And of course I can put little more to get better than what RTR car is
Thanks in advance
Thanks in advance
http://www.teknorc.com/product_info....99e0909b4fda3d
Tekno finally showed up to the Losi game
Wonder if they'll work with the Losi lightened outdrives, it says they wont work with stock...probably not
Cyclone wheels now made specifically for the SCTE from AKA..
http://www.RaceAKA.com/110-CYCLONE-S....html&catid=11
Hi hacker07 I'm highly considering the TLR chassis but have a question, since you mount your center diff directly to the chassis without the spacer, how did you deal with the holes that are left without it or do you just leave it open without a cover? Thanks.
Leave'em open! I have run this chassi for months with them open and have had no problems whatsoever.
I've been trying to get pics on for ya but for some reason I'm getting an upload error
Yes, you'll have to make some room for the spur... and yes, you'll have to grind down that one screw and plastic nipple to make room for the can.... Ist sounding like a big deal but after you do it its no biggie ... should'nt take any longer than 5-10 minutes....
