Like Tree9Likes
Old 07-11-2012, 07:22 AM
  #36781
I am still trying to solve my steering problem,
question for Losi expert, what is the different between the long ackerman link and the short ackerman link in the front
also what is the different between bump steer, up or down, how will it effect the truck ?
thanks
mwhiteknight is offline
Old 07-11-2012, 07:41 AM
  #36782
Briguy's Avatar
Trader Rating: 125 (100%+)
thanks
http://www.tlracing.com/ProdInfo/Fil...4%20Manual.pdf
Go to the setup guide , different car but same geometry .
Briguy is offline
Old 07-11-2012, 07:44 AM
  #36783
kjohnsiii's Avatar
Trader Rating: 55 (100%+)
thanks
This is what I refer to when I have unanswered questions: http://jq-products.com/the-news/43-t.../160-the-guide
kjohnsiii is offline
Old 07-11-2012, 07:47 AM
  #36784
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Originally Posted by JRL 13
nice numbers! truck looks pretty well balanced! I just got my truck together w/ tekno drivetrain, king headz chassis & diff upright/ape batt tray. With the batt tray in the full forward position and a big HW 150A ESC out back my truck put down the following #s.
619 690
670 690
Seems to handle well, but still cant get it to turn well.
How much weight did u add to the back? all that weight u got to add is makin my ESC look heavy/rethinking my choice! haha Would be nice to play around with some weight but the truck is already so heavy.
you should sell that esc and grab a sctpro fits perfect
BlackStarRacing is offline
  #36785
thanks, they explained the ackerman and I will keep my long ackerman link. How about the bump steer , it does not have it in that guide.
Old 07-11-2012, 07:48 AM
  #36786
Casper's Avatar
Trader Rating: 34 (100%+)
Originally Posted by Nathanio
Ryan/Casper/Other Losi employees; do you know when the revised diffs are going to be available? My center diff has leaked from the outset and still is after the recent rebuild.
I'm guessing RTV/CA is the way to go for now.
Yes glueing the inserts in is pretty easy to do and the only current work around. It does the job quite well though.
Casper is offline
Old 07-11-2012, 07:51 AM
  #36787
thanks I read it and it does not have bump steer information.
Old 07-11-2012, 07:53 AM
  #36788
ok so i cut out the provided sheet that came with my losi body and the dang holes didn't match.....i might be able to save it with some rings glued under the sheetrock tape and shoe goo lol
Old 07-11-2012, 07:56 AM
  #36789
HighLife420's Avatar
Trader Rating: 49 (100%+)
Did it not work how i told you????
HighLife420 is offline
Old 07-11-2012, 08:06 AM
  #36790
JRL 13's Avatar
Originally Posted by Deja Vu
Nice build!
Thanks!
Thats the plan. I was going to order it last week but the black one was out of stock and still is. Not a big fan of the blue chrome.
JRL 13 is offline
Old 07-11-2012, 08:07 AM
  #36791
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
That is a really nice setup guide. Will look there when i'm having setup trouble.
Rockthecatbox21 is offline
Old 07-11-2012, 08:08 AM
  #36792
Thanks!
It comes in black too!!!!!!!
Old 07-11-2012, 08:11 AM
  #36793
yeah they lined up exactly where you said but they were about 2-3 mm off it might just be my post as they are not new lol... the holes i made were small so i should be able to save it whew!!!!
Old 07-11-2012, 08:12 AM
  #36794
Thanks!
Have you tried Falconsekedo i purchased mine from them they are out of cali!
Old 07-11-2012, 08:22 AM
  #36795
Moogumby's Avatar
Trader Rating: 32 (100%+)
Can you explain the problem your having again? i know its a steering problem but what exactly is happening..
and if you can explain your steering set up like what hole your using on the servo arm?
Moogumby is offline
