Like Tree9Likes
Old 08-16-2012, 08:24 PM
  #38431
Rockthecatbox21's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Casper
I would say the only right away upgrade is the carbon towers.
Another option is the TLR tuned kit but it is bit of money but you get a lot of great hopups for a much reduced price if you were to get all the parts seperate.
Outdrives I would upgrade when you wear out the stock ones.
Drive shafts are fine out of the box.
Upgrade chassis if you feel you want to take some weight out but run the truck and get used to it first.
I agree with the tires for your track and the racing spring sets!
You said that a lot better than i did.
Rockthecatbox21 is offline
Old 08-16-2012, 08:29 PM
  #38432
Default Parts you might need for your Losi SCTE
If you want to go completely nuts, this is what I got for my new SCTE. I bought the ARR and stripped it down completely. Just getting back into racing after a 23 year break. Back in the day I was pretty good and raced a few national events with the big boys. So far only got one race in, but lots more to come.
Just signed up to race at the Short Course Showdown in Carrolton, TX at Mikes Hobbies. Should be fun.
Mostly buying from Amain Hobbies and Stormer Hobbies. Amain has a better selection and cheaper shipping. Stormer Hobbies are normally cheaper but they get you on the shipping. Ask Evan at Stormer, if you order big enough he will give you a discount on shipping and free stickers.
Some might think this is overboard, and it might be, but I hate being without something at the track. Im also planning on traveling to compete again at the national level so for me these parts are all must haves.
1x TEKTT2500 PRO4 Motor
1x TEKTT2300 RX8 ESC
1x MIP12200 MIP Pro4 kit
1x LOSB0127 LOSI SCTE TEN Roller
1x FUTK1400 Futaba 4PL
1x SAVSC1258TG Savox Servo
1x STRSTLB2103GM ST Racing Rear Hub
1x STRSTLB2123GM ST Racing Steering
1x RPM73042 RPM Front Bumper
1x RPM73112 RPM Rear Bumper
1x RPM73082 RPM Skid Plate
1x LOSA3573 Losi Pinion Gear 13
1x LOSA3574 Losi Pinion Gear 14
1x LOSA 3575 Losi Pinion Gear 15
1x LOSA5240 Losi Shock Oil Set
1x LOSA5281 Losi Diff Fluid 7000
1x LOSA5279 Losi Diff Fluid 5000
1x LOSA5280 Losi Diff Fluid 3000
1x TLR99101 Losi Shock Plyers
1x JCI2089 J Concepts Wheel nut
2 x SPTSTLB3495GM ST Racing Hex Set
1x LOSB3436 Spur Gear
1x LOSB2963 Losi Spring Set Rear
1x LOSB2959 Losi Spring Set Front
1x TKR2210X Tekno Drive Set, Front, Rear, and Drive Shafts
1x GMK0143 GMK Supply Shims
1x KHZ-SCTE-035 King Headz Center Diff
1x KHZ-SCTE- 026 King Headz Diff Plate
1x KHZ-SCTE-036 King Headz Motor Mount
1x LOSA 99174 Losi Car Stand
1x KHZ-SCTE-065 Servo Saver
1x CSE095-0007-00 Castle Creations
1x MUTGTO244 Mugen S5 O-Ring Set
1x HPI 6503 HPI Clear Body Washer
1x PTK-5032 Pro Tek 4.00 Super Bullet
1x 5/40 Aluminum Lock Nuts Locking Nuts RC4Less
6x Turnigy NANO Tech 2s 6600 65-130c (Six Packs) Hobby King ( Love These, never run out of power, super fast shipping and the price is way less than other)
2 x AKA13003SRE AKA Racing Grid Iron Short Course Tires (Soft) (Pre-Mounted) (TEN-SCTE) (2)
4 x LOSB3568 Losi Differential Seals w/Gasket & Hardware (Ten-T)
1 x AKA38001 AKA Racing Premium CA Tire Glue
2 x PAHT894S Panther Raptor Short Course Truck Tires (Soft) (2)
1 x LOSA99172 Losi Camber Gauge
1 x LOSA99173 Losi Ride Height Gauge Order 1138323
1 x TEKTT1450 Tekin Hotwire USB Interface
4 x LOSB2906 Losi Shock Rebuild Set (2) (Ten-T)
1 x LOSA5227 Losi Silicone Shock Oil (50wt) (2oz)
1 x HUD190070 Hudy Power Tool Tip Set (2.0, 2.5, 3.00mm + 4.0, 5.8 Phillips)
1 x LOSA99202 Losi Losi-Lok Thread Lock, Blue
1 x LOSA99203 Losi Hi-Pressure Black Grease (8cc)
1 x LOSB3104 Losi Front & Rear Gearbox Set (Ten-T)
1 x LOSB3542 Losi Differential Housing & Hardware (Ten-T)
1 x LOSB3569 Losi Differential Gear Set w/Hardware (Ten-T)
1 x LOSB3572 Losi Rear Ring & Pinion Gear Set (Ten-T)
1 x LOSB4023 Losi Rod End Set (15) (Ten-T)
1 x JCI2090 JConcepts 4mm Lightweight Locking Wheel Nut Set (Black)
1 x JMP2111 Jammin Products Aluminum Hard Anodized Steering Post Set
1 x TLR4004 Team Losi Racing Hard Anodized Servo Saver Tube
1 x TKR2216 Tekno RC HD CV Rebuild Kit
1 x TLR8060 Team Losi Racing Hi Performance SCT Body (XXX-SCT/SCTE)
1 x TLR6081 Team Losi Racing Titanium King Pin Set (4)
1 x TKR2212 Tekno RC M6 Front & Rear Outdrive Set (2)
1 x FTW00014 FTW R/C Carbon Fiber Ackerman Set (2) Order 1150897
1 x LOSB3576 Losi Center HD Lightened Outdrive Set (2)
1 x LOSB3993 Losi 4mm Aluminum Serrated Lock Nut Set (6) (Blue)
1 x SPTSTLB3495R ST Racing Concepts CNC Machined Aluminum Hex Adapter Set (Red) (4)
1 x TEKTT3812 Tekin RX8/Redline T8 1/8th Scale 30mm Brushless Fan (2)
1 x OFN36055 OFNA 2.5x17mm Hex Hub Pins (4)
1 x RPM81170 RPM Bearing Blaster
1 x PTK-6700-2RS ProTek R/C 10x15x4mm rubber sealed "Speed" wheel bearings (10)
1 x PTK-MR126-2RS ProTek R/C 6x12x4mm rubber sealed "Speed" wheel bearings (10)
1 x RCE3002 Racers Edge Modified Bearing Oil
1 x TRI4025 Team EPIC "Modified" Thin Ball Bearing Micro Oiler (2oz)
1 x PTK-6701-RSZZ ProTek R/C 12x18x4mm dual sealed "Speed" wheel bearings (10)
1 x HUD111063 Hudy Limited Edition Universal Handle
1x Plano 732 Tool Box MUST HAVE
1x LOSA99176 Losi Tire Balancer
No part number but I bought a screw kit from Krafcik on this site. Very nice
There are a few more items Iíve picked up at the local hobby shop but not much. Their prices are much too high. I already had a power supply and charger.
By far the best buys so far have been the ST Racing Hubs, MIP Pro4 kit, Tekno drive shafts and axles, full King Headz set, and the Losi Tire Balancer. All very nice. Balance your wheels, itís a must. You will notice the difference immediately. Truck is scary fastÖÖ
Jeffem62 is offline
Old 08-16-2012, 08:35 PM
  #38433
Wow longest post i've ever seen. I could have done that but i'm too lazy to type all of it.
Old 08-16-2012, 08:36 PM
  #38434
Casper's Avatar
Trader Rating: 34 (100%+)
Jeff. I don't want to know what that bill was.
Glad you like the truck and are back into the hobby though.
One thing I did forget is get some 4mm serrated nuts for the wheels. the stocks work for a little while but the nylock wears out pretty quick on these 4mm nuts and the wheels will fall off.
Casper is offline
Old 08-16-2012, 09:02 PM
  #38435
I've been flying Rc aircraft for many years and I sold most of it and rolled the $$$ into the Losi.
Definetly get the losi 4mm serrated locking nuts. They are much better than the
Jc concepts and also have nylon and you get six in the package. Jc concepts are only serrated. However, once you balance the wheels you should not have any issues.
Having too much fun, hope to see yall at the track.
Jeffem62 is offline
Old 08-16-2012, 09:03 PM
  #38436
Good thing about amain hobbies, you can go back and look at past orders, then just cut and paste.
Jeffem62 is offline
Old 08-16-2012, 09:33 PM
  #38437
vr6cj's Avatar
Trader Rating: 124 (100%+)
yeah, but I dont wanta know how much many I spend there.
vr6cj is offline
Old 08-16-2012, 09:39 PM
  #38438
Gosh, how could you forget the HA pivot ball set and titanium tie rods, sheesh...haha, jk. That is some truck.
hacker07 is offline
Old 08-16-2012, 09:43 PM
  #38439
I've got both the titanium and the ha ball set. Stormer hobbies had the best price but I can't seem to find out how to look at past orders. Amain is much easier. Still using the stock balls until they wer out.
Jeffem62 is offline
Old 08-16-2012, 09:45 PM
  #38440
  #38441
goehm's Avatar
Trader Rating: 45 (100%+)
I wouldn't have stripped down your ARR. I would have built your new truck from all the parts listed and kept the ARR as-built as a backup.
By the way, I strongly disagree on the toolbox. It has to be a Plano Phantom Pro!
goehm is offline
Old 08-16-2012, 10:13 PM
  #38442
Phantom Pro looks nice. Do the draws come out or stay in? My Plano is nice but sometimes it is a pain taking the draws all the way out and then opening them.
Jeffem62 is offline
Old 08-16-2012, 11:27 PM
  #38443
Oasis's Avatar
Trader Rating: 38 (100%+)
Ya missed a few things Jeff..Lunsford Ti turnbuckles, TLR Ti screw set, Ti nitraid shock shafts, Hard anodized Shock body's, TLR bleeder shock caps, Ti nitraid hinge pin set, DE mud guards..just sayin..
Oasis is offline
Old 08-17-2012, 02:43 AM
  #38444
dtr
dtr's Avatar
In my limited experience hex tolerances are to low for these balancers to give good results. Of course you can help take away some of the imperfections, but put them on your car and there goes your precious fine tuned balance.
I feel the only real option is to mark you wheel hexes and wheels, get the dogbones out and balance the tires in place. It is a bit more cumbersome to place clay into a mounted wheel though. Next time you install just match the marks and there you go... or don't. Did I say tolerances?
dtr is offline
Old 08-17-2012, 04:42 AM
  #38445
Dude, thx for the list. Good thing I ordered all my crap before I read this. I thought my list was pretty good until I saw yours. I'll post some pics and a vid once I get in running. This list is the reason I've held out on getting this truck, I'm an RC addict, and this truck has more hopups than i've ever seen.
jay5280 is offline
