Like Tree9Likes
Old 05-04-2012, 08:43 AM
  #33586
jlfx car audio's Avatar
Trader Rating: 37 (100%+)
Originally Posted by FLHX1550
Take the droop screws out and use internal limiters
Now explain how many mm of shims goes into each shock . For a base line setti.g
jlfx car audio is offline
Old 05-04-2012, 09:14 AM
  #33587
rctrucker2's Avatar
Default What part number?
Originally Posted by hacker07
If you are referring to the screws going into the top of the diff case through the front triangle type support, yes. You want to put longer screws into that position. The two top screws from the rear facing screws in the rear bumper can be swapped. The newer trucks have the case modified and these screws already in place.
I am trying to locate the part number for these screws but an not exactly sure which ones you are suggesting to use. Are you referring to part number A6278 which are the 5/40 x 1/2 button head screws?
Thanks for help on this
rctrucker2 is offline
  #33588
RC_Woody's Avatar
jlfx,
Most people on here are running for off-road at full droop, and some even further - plus "2 turns out" Meaning lengthening the shock even further.
Now I don't have the numbers on the exact measurements on what 2 turns out is, but search back about no more than about 10-15 pages and there was some discussion.
So to answer your question, most people start with a baseline of of full droop Meaning droop screws removed or backed out so far they never touch the chassis.
Of course if you are running carpet or something, then yes you might want to find a different baseline.
Take a look at probably the most common baseline setup:
http://www.losi.com/ProdInfo/Files/L...ford-02_12.pdf
RC_Woody is offline
Old 05-04-2012, 09:17 AM
  #33589
FLHX1550's Avatar
If you look on the team setup sheets, they list droop as "100mm" (or whatever) that is the length of the shock from the center of the eye on the top, to the center of the eye on the bottom.
Droop screws are too inconsistent (they move, get dirt stuck between them and the chassis).
I myself run no limiters, and will turn the rear shock eyelets out 1 or 2 turns depending on conditions.
FLHX1550 is offline
Old 05-04-2012, 09:22 AM
  #33590
Casper's Avatar
Trader Rating: 34 (100%+)
Droop screws are ok as along as you have the inserts in the chassis. If you use the alum chassis as a stop then you dig in holes and it changes. Yeah if you race in wet loose condtions you can get dirt in there but not aways. I agree shock length can be better but droop screws can be very convienent if you drive in many different coniditions.
Casper is offline
Old 05-04-2012, 09:24 AM
  #33591
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by goehm
Gosh - that really does look pretty.
It looks like you could use that top brace to shorten your wires and save even more weight and reduce resistance. Solder vertically on the ESC, shorten and route it right over (or under secure w/ zip tie). That's be sweet!
Good idea. I'll give that a try!
rcgod is offline
Old 05-04-2012, 10:57 AM
  #33592
Josey Wales's Avatar
Red face thats great
thats great. You deserve a pat on the back
Originally Posted by Feint Motion
I've been "rebuilding" both of my Losi's to get ready for the summer.
Truck #1
"Almost every TLR upgrade"
Fresh battery tray/Reciver/servo tray on the way. Hobbywing SCT pro system with tenshock sc401 soon.
Savox 1258
Truck #2
Bling Bling
Castle 1410, HW SC8 Flawless setup, savox 1257 in this one.
Both are built for Large outdoor 1/8 Nitro tracks, so no "hacking" to save weight here. lol
Josey Wales is offline
Old 05-04-2012, 11:05 AM
  #33593
How strong is the point between the cf plate and the alunimumfront part of the chassis seems like only being 3mm thick it wiuld be a stressful area
Old 05-04-2012, 11:08 AM
  #33594
rcgod's Avatar
How bourable is the point between the cf plate and the alunimumfront part of the chassis seems like only being 3mm thick it wiuld be a stressful area
I agree it looks like it could be a weak point. Probably.why extreme recommends always running the front losi brace in addition to the top plate.
rcgod is offline
Old 05-04-2012, 11:41 AM
  #33595
RC_Woody's Avatar
Not really a SCTE question but relevant...
So saw a guy at the track last week who had a Losi 8eight(not sure if 1.0 or 2.0)
I compared the wheel base to my SCTE and it was darn near identical, at least very close. (kinda makes you wonder why SCTE is called a 1/10th scale)
My question is about motor:
Why are people running the Tekin T8's(and similar) with low KV's(lot of torque) vs something like the Pro4 3300/4000/ 4600(and similar 4 pole)?
Is the buggy that much heavier? I wouldn't think it would be unless maybe due to the tires?
Edit: I realize that typically 1/8 scale runs 3s-6s, which needs a lower KV motor, but are more cells for a longer run time?
RC_Woody is offline
Old 05-04-2012, 11:42 AM
  #33596
goehm's Avatar
Trader Rating: 45 (100%+)
I'm not a fan because, while it gives consistent shock extension, anytime you adjust your shock locations you have to then also rebuild your shocks.
goehm is offline
Old 05-04-2012, 12:06 PM
  #33597
FLHX1550's Avatar
Thus far I have not run a limiter at all.
The original question I was answering was in regards to the droop screws. I myself run full droop, and have the screws in, about 1/4 turn from touching the inserts just to give the screw something to hit when they flex
FLHX1550 is offline
Old 05-04-2012, 12:08 PM
  #33598
BlackStarRacing's Avatar
Trader Rating: 40 (100%+)
Tires:
Are you guys running all four of the same tire or are you mixing the tires from front to rear? If so on loose clay would you place the a higher nub or smaller nub tire on the front vs the rear?
BlackStarRacing is offline
Old 05-04-2012, 12:25 PM
  #33599
Ive actualy took some droop out of mine and it seemed to respond better to steering input and also didnt get as loose off power
Old 05-04-2012, 12:41 PM
  #33600
chucko's Avatar
In answer before you edited my 8 E on the ground is at 8 lb 1.6 oz my scte on ground 6 lb 9.8 oz sorry if I took so long answering I had to get the scale out lol
chucko is offline
