Another win for the SCTE at Rc Pro South Rd 2 in Lafayette, La. The truck was awesome all weekend, Track was a large 100x160 Outdoor, Dusty Track.
I am running on highly abrasive red clay, and the wear is fine... im using the de rear skid.
they use a zero off-set wheel. the one's that i know of that fit without trimming:
-stock losi wheels
-DE racing SCTE
-jconcepts rulux SCTE wheels (would stay from these, they have cracking issues)
-AKA cyclone SCTE (haven't seen these in person yet)
i have only used stockers or the DE wheels.
-stock losi wheels
-DE racing SCTE
Ok thanks im looking for some diffrent tire compounds and treads from the stock tires but the stock tires do work fine in some conditions. I think il get the losi stock wheels or the AKA ones. Do you know if the Toro 4x4 Sc 120 Amp Esc has timing on it stock ? If it does i need to set it at 0%. The Tenshock motor does seem to run hot when i touch it at least with my hand less than 5 sec.
Oh yea the Tenshock 4600 kv power is crazy im suprised that people i race with use a 3800kv or less on a big track. I was killing them all in the straights/turns lol.
I think people were thinking i was using a 3 cell lipo lol.
if you don't have the programming card, the timing options are: disable, normal, highest. normal is the pre-set and it doesn't say how many degrees it adds, just that it adds some. i would definitely put it on disable.
i would also invest in a temp gauge. the feel test isn't all that accurate. IMO, it's a cheap, must have tuning tool.
Yea i just read the manuel for the Esc it says the factory setting for the timing is Normal but the lowest gives you the most efficently and runtime though .
Il try to do it manuely but il just disable it.
I need to get a new battery for my temp gun. Somebody did temp it for me after a 5 min heat and it was at 149 i believe but dam when i felt it i couldnt keep my hand on it for 5 secs. I had to gear it down to a 14t pinion for the 10 main to keep it a little cooler.
But its a fast motor and the ESC is pretty smooth runs cool also i have a racer that might get the Tenshock motor.
Hi all I have some traxxas diff oil left over I was going to use in my scte but the weights seems different than losi I've got 10k 30k and 50k ummm a noob so any help is appreciated
hey guys i just become a losi scte owner i brought of well know aussie driver in oz here what i got tell me what you think
SCTE ROLLER
includes the
TLR Chassis
TLR Upgrade kit which includes carbon shock towers and metal shock caps plus much more in the kit including alum rear hubs and inserts etc etc
also got the extender rear brace for better strength
brand new in packets are Chris Pins for the diffs and Chris shims and spacers for the diffs to make them bullit proof
also custom made front diff holders to stop the front drive shaft coming out a know weakness with these trucks
1 x LOSA6908 bearings for centre diff
4 x LOSB3568 complete rebuild pins and gaskets and shims for diffs
plus wheels and tyres
1 x set of mounted Snipers 90% new
1 x set of Goose Bumps 90% new
1 x set of bar codes 90% new
will also put the orginal chassis in which is still fine
body is a Ford dark blue truck
i pick that u for $400 au
SCTE ROLLER
includes the
TLR Chassis
Seen this on another forum, not mine.
Axial Exo Terra Buggy Rollcage on A SCTE
Shouldnt be that hard to do, looks like he used the front bumper from the Exo as well. Spare lexan for the sides.
Cant wait to try it!
Source: http://www.rcshortcourse.com/forum/l...tml#post255999
SCTE ROLLER
includes the
TLR Chassis
SCTE ROLLER
includes the
TLR Chassis
Last edited by BmainStar; 04-30-2012 at 11:40 PM. Reason: Dang it Spell weakness right
That Desert Truck is sick
Those are way to high for the scte, they are find for the traxxas vehicles since they only use a 2 gear planitary gear system vs. the 4 gear system the scte and a lot of other vehicles use. So get yourself some 3k, 5k, and 7k and you will be pretty much set.
R/C Tech Elite Member
I got my BCE chassis yesterday and just got all my gear swapped over, man this chassis is a thing of beauty! I almost don't wanna race it now!
FYI: for those wondering, it does have the hole for the long rear chassis brace but I am sticking with the shortie, I want it to flex a lil bit.
