Cost is everything to a lot of folks, especially beginners in this hobby. Sensored without a doubt more costly, to some it doesn't matter, to some like myself just feel it's unnessasary extra expense for weekend racing.
Sensored has it's place and obviously so does sensorless, I see no reason to bash any sensorless combo especially if they've proven to work well in the hands of the owner/driver? Granted a lot of folks have had some probs with thier ESC's regardless of brands (I seen many many RX8's go up in smoke when first released just like the M.M.M. years back) But vast majority of users will never admit to user errors or poor set ups.
I'm no Po but I do run well (got a A-main win last week) but I see no disadvantage of a properly set up sensorless combo. Both my indoor and outdoor SCTE's run butter smooth on our local indoor tracks and they are small and very technical. I have zero issues with cogging, dead spots or power inconsistantcy's. Hell, my MMP's are several yrs old and running a Spektrum 6040HS servo's with a cap only to boot. Yay Castle IMHO
Casper maybe you can help....
I am running a SCTE with a Teking 4.5 550 motor with a LRP SXXTC I have the drag brake and brake all the way down as well as the Power/Punch set at 1.
I am geared at 13/40
The truck is very fast and can make 10 min mains on a 6200 lipo
What would the advantage be going to a 540 4600 motor?
Just wondering if it is a huge difference in motors.
Thanks for any info you can give me.
I wholeheartedly believe that sensored has no more power than unsensored provideing both have the same KV, comparing the Tekin 4000 to the Castle 3800 isn't exactly a fair comparison even tho it's pretty close.
From all my years in BL and reading arcticles, posts etc UNsensored is slightly more efficent than sensored, It may be minute but thats what I feel is true.
STPETE40; I still have that Beta motor in my possesion that will do everything the 4600 Pro4 can do and plan on testing it again when we hit the 1/8scale track.
@ Casper
A very civilized post, thank you. Good to see someone state facts and opinons rather than just spouting off "sensorless blows" etc etc like a typical fan boy.
Thanks.
If a motor had all windings identical, no variance in an clearances, perfect balance, perfect magnet spacing, perfect flux fields and the hall sensors were all identical then sensored would probably be more efficient. Sensorless allows for all of these imperfections by firing the coils at the correct time regardless. With the correct timing once a sensorless motor is at sufficient speed it will be more efficient. Sensored motors will always be more efficient (and consistent like casper says) at very low motor speeds.
Going from sensorless to sensored, made a hugh difference at slow speed. It went from skipping in the corners to smooth sweeping in the corners. I will never go back to sensorless. I suppose thats why they are priced different. If you havent tried it, you should. Just like DSM2, just adds more control.
Salad, good to see you did what was right.
I have seen it stated in this thread that the Losi Team racers use the plastic front chassis brace and in the rear use the torque rod. Could someone tell me why the plastic brace is used in the front over the aluminum one?
Thanks Casper for the straight forward answer.
Nice to have someone like yourself on her giving there time to help all of us out.
Personally, I went back to stock plastic because its a bit lighter. 5 grams or so I believe, if I remember correctly. I wieghed them myself beore the swwitch. Doesn't sound like much, and I'm not a weight nazi with this thing, but if I am going to shave weight, I want it off the front of this truck. Team drivers may have a different reason.
Sensored/uncensored....blah, blah. When I can run consistent laps, then I'll look at what motor may or may not be faster.
sales guy gave me a good deal just to get rid of the older 6000 60c-2s batteries. they have the newer ones but hell 500 mah isint needed. im running the novak 5.5 14mm rotor with rx8 but just picked up the 4600 pro4 today...going to wait to put it in though. just wanted to grab it since the lhs had it in stock
