I raced and took 2nd for the 2nd race. took third the 1st. rebuilt the truck after as it was raining and a muddy mess when we all got dune racing the HDRC round 4 event.. when I re built the diffs . the only problem I had was the washers with the pin behind the worm gear. it looks a little grooved I checked with a LHS and no washers with out buying the gear set. I have a gear set.. Thanks HH. just need the washers. any body know where I can get just the washers?
Just out of curiocity has any one tried using synthetic automobile gear lube in their diffs? It seems to me it would offer better protection from wear.
They are LOSB2959 and LOSB2963 and you get all four fronts in one pack and all four rears in the other.
I have to say, we had one batch that the tolerance was a bit off on the rod ends, however its not most of them or even many of them. I have many of them that take hard hits and dont adjust. The easiest way to ensure soemthing with a bit better bite is to get the Losi 8b 2.0 titanium turnbuckle set. Much sharper edges that grab better and they are lighter.
Any vehicle if you push on the wheels hard enough will change a bit. If you feel you got a bad batch of rod ends, contact customer support and they will get you taken care of.
Perhaps I shouldn't have used the term machine, that's great that yours is not loose brand new out of the box. I'm just saying that for the money I expected more, I can grab both front tires and with very little force change the toe and camber in either or opposite directions, perhaps some shimming might take care of it but it looks to me that alot of it is caused by tolerances in the steering knuckles and hubs, and as well with the steering bellcrank etc. Yes a setup station is great for onroad so in my mind it's just as good for offroad
What are the part numbers for the carbon fiber shock towers? Where do you get the BEC chassis plate and what is the part number for that?
It doesn't come with them, just use the stock ones. Or Dubro makes capture ends that are much stronger (I don't have a part#). The problem was in the threads on the turnbuckles not the capture ends.
As for the others who commented on my issues the truck is brand new never ran and I did install Ti turnbuckles and new ends.
BCE website:
www.bcespeed.com
Losi hop up parts:
http://www.losi.com/Products/Related...s&SubCategory=
www.bcespeed.com
Losi hop up parts:
Just received my SNR pins from Chris and I am very happy with the quality.
Thanks Chris!
Thanks Chris!
