I've been considering converting my shocks to an emulsion setup and have seen a few videos on how to do it.
Tim Bump from Nitrohouse - http://www.youtube.com/watch?v=IgLTY17vPHg
Mike Truhe - http://www.youtube.com/watch?NR=1&v=eWBAKC-c1s4
For those that have converted your shocks over to an emulsion setup, I've got a few questions:
1) These two guys show two different methods. Tim doesn't bleed the shocks, which obviously leaves a lot of air in there. Mike seems to use the bleed hole, which probably gets rid of almost all of the air. So, I'm wondering which approach is correct? Isn't there supposed to be air mixed with the oil?
2) In Tim's walkthrough he mentions he usually needs to go up 5wt in oil when converting to emulsion. Have you guys found that to be true? I just want to know where I should start. If it matters, I'm currently running #5 piston and 27.5wt with the bladders.
3) what has been your overall experience with these on a larger outdoor track? I'm looking to be able to handle the big jumps better, while still keeping my current small-bump handling.
Thanks guys!
Thanks guys!
Can you build the emulsion shocks with the stock plastic caps (with bleeder hole drilled) or do you have to use the metal caps?
I need to write faster. 15 posts will go by on this thread before I can finish mine
I'm alone at the local track with the scte. Others are running sc10 4x4, durango and the hongnor.
Here is a clip from my truck running it on the stand. Is this how it's supposed to sound. Mostly i'm concerned about the sound when releasing the throttle. Coming from the rear part of the truck.
Check it out!
Check it out!
+ YouTube Video | |
The two wires, black and red leads are for battery, the three empty gold bullet plugs are where the VX4's plug in. You then have the receiver cord, the VPort (on/off button) and the fan which plugs into the ESC. The motors come pre-soldered with bullet connectors.
Tim, Ryan, Casper, thanks for the reply and all the great info. I'll try it out and see how it handles.
I know everybody's been writing about the servo saver to loctite it down, in that process how tight do you go ? all the way with a pair of pliers and back it off two turns or what ? Thanks
You want to tighten it so you have at least 2mm of thread showing below the nut.
Thanks! But still some missing, the part wich I have marked looks like a built-in sensor wire, a bit too many wires for an on/off switch.
I'm looking for a little setup advice. I run at Nor-Cal hobbies where the Nats ran this summer. On a normal club race weekend the track is not watered and it is very hard pack with a bit of dust in the corners.
I'd like to reduce turn in and the truck will occasionally traction roll or kick the rear end out off power.
I started with Dakota Phend's setup from the nats. I have changed the following:
Diff Oils: 7/5/2
Shock Oils: 27.5 F/R
Ride Height w/ body on:
F: 25mm
R: 23.5mm
Camber:
F:-3
R:-1.5
Rear shocks: Middle top/ Outside rear
I've tried running Soft Enduros F/R and BowFighter M2 F/ Soft Enduro R. I also bought a set of the Losi Eclipse to try in the rear, but didn't have a chance to try them out.
Would going to the purple spring in the front help slow down turn in? Any other suggestions?
Thanks,
Chris
Diff Oils: 7/5/2
F: 25mm
R: 23.5mm
Camber:
F:-3
R:-1.5
Thanks,
Chris
