TLR 22 Racing Buggy Thread
#7516
Location: Dont get any more northwest than me..........
has anyone ran the casey peck setup yet and how did you like it?? i have that setup on my buggy currently and will hit the outdoor track with it for the first time this weekend. it sounds perfect for my track as its a little rough and loose.
#7517
You can unthread as many turns as you want, increasing droop. There is no magic behind "2". Unscrew too much, and you lose strength between the shaft and eyelet, so be careful there. More front droop adds rear traction ON-throttle.. which simply adds some push coming out of a corner. It doesn't mean "harder to drive"... it means "drives differently"... so if the person's car is currently OVER-steering coming out of a corner, more front droop will tame that out, making the car EASIER to drive.
#7518
A caution on droop up front- Too much and you will have difficulty acheiving the proper ride height. The springs can only deal with so much travel.
#7521
Running different things on this car has been great. I started with the Evans set up and ran it pretty much everywhere but it was the small adjustments that seemed to make the car come alive for my driving style. I see people asking for different set up's and my thought is rather than starting completely over play with one particular end of the car and see if the changes help or hurt. Some of the changes I made were money and I can't wait to try them at different tracks.
#7522
I have put it off long enough....I retired the XXX and picked up a 22 yesterday. The build went very smoothly and all I have to say is I can't wait to run this thing! What an awesome design and this buggy looks tough as nails. Going to start with the kit setup (rear motor) and see how it does at the local track which is high grip, indoor running on dremeled slicks. I am curious to try the mid motor setup on this type of surface, but I have heard that those that do have to put a lot of weight in the rear of the car....
#7523
#7524
Rooster... i can explain it more in person (hit me up on monday at the track), but it has more to do with the type of traction, than the level of traction, when figuring out what surface the mid motor starts to excel on. Even at our track, which I could argue is maybe thee highest traction off road clay track EVER.... isn't enough to give the edge to mid motor. HowEVER... you said you like a car that feels looser.. and mid motor might be the trick for you on our track.
#7525
Shock Cap Quality
How do I e-mail TLR to inform them of the poor quality of the kit shock caps?
The replacement ones I purchased are a 100 times better, I would like to send the kit caps back to them for inspection. I don't want anything, just thought they might want some samples that they could show to their suppliers.
#7526
#7527
go to the 22 build tips thread that is a sticky towards the top of the electric offroad page, there you will find it.
#7530
working on a buddies car trying to figure out...what parts do you guys use to make the graphite battery strap hold down???? does someone make a kit or are they parts taken from somewhere else?
