TLR 22 Racing Buggy Thread
#7487
Cant wait to run my car this weekend !!Car is very easy to drive and I am new to 1/10 buggy so that should say something bout this 22! I bought this as a roller and switched it from mid to rear motor and it works very good on our outdoor track (when it has enough water lol) Dont even know what fluid is in the shocks Etc. Soft Holeshots in the rear and pre scrubbed Losi ribs up front..Darn fun to drive .Really feels like your racing a model car instead of running a small go kart that you can`t sit in LOL ..Love it!
#7490
Ordered a 22 yesterday from Amain. A bit new to 2wd electric but Im sure Ill be alright
They seem to be extremely popular these cars, think Losi really pulled something off with this car.
#7492
Will prob start with the rearmotor config and go from there.
Is there any optionparts thats nice to have or is it good to go as it is? Like springs and pistons for the shocks and stuff like that.
#7493
#7494
AE diff bolt and nut and a B-fast diff rebuild kit. The car is painfully durable. The only thing i have ever broken on mine, is a bent turnbuckle. I promptly swapped them out for lunsfords, but the stock ones are descent. The only other thing not factory on mine, is as i stated above, the diff bolt, nut, diff balls, and thrust balls.
#7495
22
We race on a nice outdoor dirt track. Very smooth and run damp with a nice dust layer on top. Best tires so far are DD's with a proline rib or carver front. RB5's are king so far with good steering and foward bite. This is not your uber high grip clay, its low grip thats very consistent.
I'm thinking about trying Corey's setup for a start but the 22's I've seen look like stiff fish with very little grip. Very stable in the high speed section when loaded up but a real bear to keep in throttle on the low speed sections.
Thinking about 1mm limiter on front shock and 2deg rear camber, hubs foward, white rear spring. Any suggestions would be nice. I really dont want to lay down the 400 for a new RB5.
http://youtu.be/RyVqyFAB4-M
#7496
Moderator
Trader Rating: 470 (100%+)
Dumb question..... just rebuilding my diff and the instructions say that the screw is to face the drivers side in rear motor configuration? Does this mean the end of the screw or the area where you install the hex driver to adjust it?
#7498
Moderator
