TLR 22 Racing Buggy Thread
#7472
K. Thanks.
#7474
Feel like a shmuck for asking this but where do the threaded kingpins exactly go? I think I remember it being mentioned but can't seem to find it via search.
The second question I have is whether saddle packs will fit with the wider side touching vs the skinnier sides touching with the rear motor mount. Make sense? I thought not.
#7475
#7476
I'm not excited..are you excited? This is the 22 thread... not the "teach me all about LRP esc modes" thread.. those kinds of things either belong on the appropriate thread, or in PM. I don't mind one here and/or there, but when it takes up an entire page and a half... cmon... Back to our regularly scheduled program... the losi 22!
#7480
I have a Savox 1251-MG low profile servo in mine, and did not have to remove any material at all. I did use one thin shim and one thick one on each mount as recommended earlier in this forum thread though.
Maybe it is just a matter of adding another shim to push it forward more for the added clearance.
#7485
I normally run the 96mm lipo like this as well as I posted earlier, unless the track is slightly slicker than normal from moisture, otherwise I run it with a pad in front pushing the small lipo back into the rear bulkhead, to move the lipo's weight a little back more for additional rear traction.
As you can see here also I have two positions for my wing, depending on what I want/need.
