Like Tree1Likes
B44.1 Thread
Old 07-25-2012 | 03:19 PM
  #2506
20 SMOKE's Avatar
i use blue/yellow
20 SMOKE is offline
Old 07-25-2012 | 09:51 PM
  #2507
Originally Posted by bergie33
Those of you using Losi BB shocks, what springs are you running? I run on an indoor medium/high bite indoor wet clay track. It seems like running just the BB springs most are going with red/white or red/yellow. Would the same hold true with the Losi shocks in there too?
Noooo, too soft. I made that mistake, running red, and then orange and white, was horrible.
Blue front, yellow rear worked great for me on the same type of track. i ran 35 wt losi oil w/#1 piston in front, and 32.5 wt losi oil w/#2 piston in the rear. Car was dialed, jumped perfect. The bb springs absobed some of the impact on landings, much more controllable.
zipperfoot is offline
Old 07-25-2012 | 10:16 PM
  #2508
I took the rear apart and didn't see any strip gears or anything but there were only 5 thrust balls so maybe that was tw problem.... What could it be in the diff makeing a loud clicking noise and it would not move anywhere I mean it moves but it was like the slipper was real loose. Does associated just sell a whole diff?
The8ight is offline
Old 07-26-2012 | 12:36 AM
  #2509
bergie33's Avatar
OK, is that with just the Losi springs, or the entire Losi BB shock setup? I hope I was clear, that I want to find out what springs people are running with the BB shocks.
bergie33 is offline
Old 07-26-2012 | 12:49 AM
  #2510
D3mOnIcRc8e's Avatar
Any one looking to buy a B44.1 Local to California 909 951, im currently selling mine for 400, just need controller.
http://www.rctech.net/forum/r-c-item...909-951-a.html
D3mOnIcRc8e is offline
Old 07-26-2012 | 03:55 AM
  #2511
20 SMOKE's Avatar
look at the gears there may be something in one of them,start putting it back together one diff at a time and then spin them slowly to find it
20 SMOKE is offline
Old 07-26-2012 | 06:30 AM
  #2512
any one have a new info about the ae bb shock ?
i see them all over the pro's cars, Does anyone know when it's released date ?
adir is offline
Old 07-26-2012 | 03:42 PM
  #2513
My mistake. I was referring to the bb springs with the v2's. I still think red and white would be too soft with the Losi bb shocks on a 44. The b44 is noticably heavier than the 22. I am lifting them both as we speak. 44 is heavier. I ran red and white in my 22 with a shorty pack. Border line too soft even for the 22. Depending on the track of course.
Old 07-29-2012 | 11:44 PM
  #2514
gogi108's Avatar
Ok got the bb springs on , feels much nicer on the bench . the buggy is new built and had its run in on the road and all seems well . what are peoples thoughts on the ballast ? Yes or no ? Will take it to the track in couple days for proper run . cheers
gogi108 is offline
Old 07-30-2012 | 12:40 AM
  #2515
FACTORYBUTNOT's Avatar
The big bore shock spring upgrade is a worthy investment...the car is more forgiving with them. I don't run the ballast...just a square or two of the AE 7gram weight between the saddles.
FACTORYBUTNOT is offline
Old 07-30-2012 | 04:01 AM
  #2516
20 SMOKE's Avatar
i use to run weight when the 44 came out,since coming back i haven't added any yet
20 SMOKE is offline
Old 07-30-2012 | 04:43 AM
  #2517
gogi108's Avatar
Cheers guys . i guess i Will try with and without and see what i like . I'll post my findings . cheers
gogi108 is offline
Old 07-30-2012 | 08:06 AM
  #2518
adir is offline
Old 07-30-2012 | 08:12 AM
  #2519
20 SMOKE's Avatar
there is nothing yet,most of the info was in the b4 thread
20 SMOKE is offline
Old 07-30-2012 | 09:20 PM
  #2520
bsshbr's Avatar
Hi guys, I just put a lrpx12 8.5 in my b44.1 , just wondering what gearing to start at, I was thinking 81/23 ?????
bsshbr is offline
