Like Tree1Likes
B44.1 Thread
Old 03-31-2012 | 04:30 PM
  #1801
fastchvy's Avatar
You can use this one too...
http://www.amainhobbies.com/product_...a-Torque-Servo
fastchvy is offline
Old 03-31-2012 | 04:47 PM
  #1802
Mini8 Menace's Avatar
Default is that too much TQ
Originally Posted by fastchvy
that seems like a shit ton of tq like way too much but correct me if I'm wrong
Mini8 Menace is offline
Old 03-31-2012 | 04:54 PM
  #1803
t0p_sh0tta's Avatar
No such thing as too much torque, but that is a relatively slow servo. I'd look for something in the .10 or faster range.
anything over 120oz of torque is fine.
t0p_sh0tta is offline
Old 03-31-2012 | 04:56 PM
  #1804
fullsyzz's Avatar
Originally Posted by Mini8 Menace
i have a savox 1258-tg and it doesn't fit its like a couple mils to long the steering rack rubs any suggestions on a servo that will fit looking for between 150 to 200 tq preferably somewhere in between
The 1258 will work fine. Just grind a few mm off the end of the bellcrank.
fullsyzz is offline
Old 03-31-2012 | 05:30 PM
  #1805
Default hey man thanks
how is it and where did you buy it at cause i could only find them at RCplanet for 150 anywhere cheaper???
hey i found it for $125 sweet deal did you have to do any mods or did it just mount up with or without the spacers??
Old 04-01-2012 | 05:42 AM
  #1806
Buckaroo's Avatar
For some reason, the servo mounting holes on the chassis plate are super variable.
I tried a 1258 in my car, and if I were to grind a few mm of as you suggest, I'd be compromising the threads in the ball end on the bellcrank.
My friends' B44.1 has nearly 2mm clearance with the same set up! Way to go, AE!
Buckaroo is offline
Old 04-01-2012 | 05:53 AM
  #1807
UN4RACING's Avatar
Originally Posted by TheHillsPancake
which is better steel pinion or aluminum pinion for a 6.5 motor and which brand is best?
I like the losi pinions they run quiet and last forever. There hard coated steel. I like the steel so I can tighten them down and not worry as much about stripping one or seizing the threads. (I use blue lock tight).
Aluminum or titanium are probably more efficient and less stress on the motor though.
If it matters the Losi pinions run quieter. IMO.
UN4RACING is offline
Old 04-01-2012 | 01:44 PM
  #1808
fastchvy's Avatar
Found a guy on ebay that has the x20's in stock, he said he has 6.5 in stock
http://www.ebay.com/itm/NEW-LRP-X20-...item256e31710c
fastchvy is offline
Old 04-01-2012 | 02:54 PM
  #1809
Default i got one as well but from someone else
i got the X20 6.5 too susposted to be hear be weds at the latest hopefully sooner was talking to the guy i am getting it from and he has been running them for the last 3 weeks and he's coming off the track with temps around 150 with a TC spec esc not sure the setup but he was running 18/81 gears and the power band is so smooth yet powerful i can't wait to get mine will let you know what i think
Old 04-01-2012 | 03:17 PM
  #1810
fastchvy's Avatar
Who did you get yours from?
fastchvy is offline
Old 04-01-2012 | 04:49 PM
  #1811
Default a guy that is sponsored by LRP
he said they gave him some to test out and he had a couple of them i just asked him if i could give his info and he would rather me not give it out but i have known him for over ten yeas we ran into each other at the track after the races and we haven't talked in a couple years but he hooked me up after we went to get a drink and i was gonna wait for it from my LHS could get them but i had the chance to i went with it but i will post about it
Old 04-01-2012 | 05:33 PM
  #1812
UN4RACING's Avatar
I haven't heard anything on mine. Its on order so if they are hitting the net they should arrive any time.
Old 04-01-2012 | 06:45 PM
  #1813
Originally Posted by htrd03
For those of you running kyosho big bore shocks, what springs are you running. Switching to big bores and was looking for a little help and direction. What oils and pistons are you running?
Just looking for a starting point with these things. A little help would really be appreciated.
Thanks, Joe
htrd03 is offline
Old 04-01-2012 | 07:59 PM
  #1814
Thanks, Joe
Sorry, I don't run big bores on anything so I can't help.
nhraman is offline
Old 04-02-2012 | 12:56 PM
  #1815
Thanks, Joe
Ha I asked the same question not too long ago and didn't get many answers. SO...I went on Kyosho's site and looked up Tebo's ZX-5 shock setup for the Reedy 2011 at West Coast RC (my local track). I know it's not the same buggy but the specs on the Kyosho are pretty similar in dimensions and weight Kyosho being a touch lighter. Haven't run it yet though but at least I have a ballpark to start with.
Front: 35wt/ yellow springs
Rear: 30wt/ red springs
jamr1130 is offline
