Hyper TT 4wd 1/10th Truggy Thread
#1651
You can try using a 1201MG servo.It's only 12$.So if you don't like it you don't spend lots of money.
http://www.hobbyking.com/hobbyking/s...idProduct=9618
#1652
#1653
what are u talking about? servo is not a problem bellcrank is
just a little dremmel ing??
#1654
JZ. I just picked up the bell crank system that was previously linked to. I'm planning on installing it tomorrow, if you can stop by and wanna take a look.
#1655
#1656
I was talking about the guy that was searching for a servo before some posts(and selected this @ 60$)
#1657
As far as I can see, the bell crank system alone isn't going to work. I've noticed a few issues that'll need to be figured out. Goin racin today, but maybe tomorrow I'll look into it more.
#1658
Everything fits, the only thing I had to do was get the proper bump steer..it's not to hard to do. I also use traxxas tie rods & ends..no more ends coming off, Ofna also makes a nice chassis for the TT. I believe that the "new" A arms (from the SC) will fit on the TT, they are better, part of the problems the SC guys were having with bending and breaking dog bones & axles (rear) was the over flexing of the A arms, it was also bending shock shafts. I would look into getting the beefier A arms. Most of the parts interchange from the TT & SC..
#1659
and i hear ya ...yes i used those traxxas ball end as well
how tight do u set the servo saver?
how long u been running this setup?
#1661
#1664
If someone wants an opinion for the 4.5T 550 motor , I use 26T pinion(42T spur)
#1665
Yes, the RX8 is the way to go with the larger 550 motors. I have tried an RS pro and two caps on it in my Hyper 10, and it thermals. If you must run the RSpro and a 550 motor, the only thing left is lowering the current limit and a cooling fan. When I tried the RSpro on Hyper 10, I didn't lower the current limit or try a fan, but I have got the RSpro working so far in my TT with a bitchen Tekin 6.5 and the TT2277 rotor, and so far its getting warmer than I like, and almost thermalled, but not yet. Current limit is at 90% and the TT only weights 4.97lbs. Warm weather might cause it to go over the edge, but I will have this truck lighter by then. The heavier the vehicle, the more the current draw, so you are welcme t try it, but yu will be happier with the RX8, its bulltet proof.
