RC10B4.1 FT/WC
Old 03-17-2012 | 11:24 PM
  #12871
Guest
Originally Posted by SoccerSting
Well you could cover the bottom of the chassis with those lead weights that have the sticky stuff on one side. Then cover that with a chassis protector.
i thought about that???????hahaha
i just think we all need more weight in the car, more than putting on big bore shocks and spring.
LOSIRACER77 is offline
Old 03-17-2012 | 11:38 PM
  #12872
Just1More's Avatar
The idea is to match a light car with light springs/oil..it's all about the setup. In 17.5 class you want a light car, weight limit is 1500g and other manufacturers are closer to that weight than your typical B4 is(i'm at 1640ish). Not to mention that if adding 100+ grams to your B4 would make it handle better, the pro's would be doing it.
Just1More is offline
Old 03-17-2012 | 11:48 PM
  #12873
SoccerSting's Avatar
nvm
SoccerSting is offline
Old 03-17-2012 | 11:49 PM
  #12874
Guest
u r right, every thing has changed in size and weight, BUT ASSOCIATED SPRINGS HAVE STAYED THE SAME!!!!!!
Old 03-18-2012 | 02:27 AM
  #12875
LOSI123's Avatar
Is it possible to get a b4.1 ft to be 1500 to 1550 grams with no lead but with a 310 gram 6200mah lipo? would it require much mods or straight from box might be possible?
I will be putting a 60amp xerun esc in it and a 55gram servo, with shortest wires posible etc....
i suppose i will find out once built, but im just hanging out to know and have never built or owned a 2wd buggy before.
LOSI123 is offline
Old 03-18-2012 | 02:46 AM
  #12876
Just1More's Avatar
I don't think so..maybe 1550-1580g with no added weight. Personally i run an XP1015 servo for the weight, so i recommend a full size servo up front.
Old 03-18-2012 | 03:20 AM
  #12877
elex300's Avatar
Just piced up a pair of Scrubs for the heck of it. Which way do you run them? I thought I read somewhere you can run them in either direction but one is more aggresive.
elex300 is offline
Old 03-18-2012 | 04:00 AM
  #12878
Guest
i use a old hitec in my buggy i have 3 pes in the front of servo on the chassis and 1 ounce on top of servo, i also found out the the difference between the stock steering and the avid bearing steering pieces, there is a BIG DIFFERENCE in the perforamce, with the avid parts the steering is more direct, u will tell the change i proimes,
Old 03-18-2012 | 07:14 AM
  #12879
Tyler Keel's Avatar
Normally you want to run them with the "V" in the middle of the tire facing with the point forward. I accidentally ran them backwards one race, never even knew any difference.
Tyler Keel is offline
Old 03-18-2012 | 07:17 AM
  #12880
Tyler Keel's Avatar
Originally Posted by Bob Barry
17.5's have to be geared really tall to be fast, thus making the low end softer as a side effect. If you throw the HT rotor in, it adds to that low end while allowing you to keep the high end. In theory you would get more high end too because your temps would drop slightly and you could gear up another tooth
so more power low end, more power high end = winning IMO
BINGO! Thanks for fielding that one Bob.
Old 03-18-2012 | 07:51 AM
  #12881
Tyler Keel's Avatar
Oh btw. Thinking about selling my buggy. If anyone is interested.
Old 03-18-2012 | 04:09 PM
  #12882
nobody wants your clapmobile
Bob Barry is offline
Old 03-18-2012 | 04:53 PM
  #12883
Default weight
Hey guys what is the gun weight to run at light or heavy?
and if anybody knows what the pros are running.
cheers
ghost rider is offline
Old 03-18-2012 | 06:06 PM
  #12884
Tyler Keel's Avatar
The factory clap mobile. But seriously if anyone is interested in a great car, just throw me a pm. I've posted pictures of it on here before. Bob can vouch, I take amazing care of my stuff, and it's extremely fast.
cheers
1528g in mod. In stock, I'd find out what the minimum your track goes by and get it as close to that as possible.
Old 03-18-2012 | 06:17 PM
  #12885
Yeah, his car's are tight... the clap washes off with a lil motor spray.
I built a second car today at the track with nothing but old parts LOL. Only thing is it has a std chassis and I need shocks. gonna be a perfect car for my kid
