RC10B4.1 FT/WC
Old 03-08-2012 | 02:57 PM
  #12556
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Originally Posted by Bob Barry
As my buddy Chris says, I went to bed, woke up and everything was different!!! I still catch for not understanding why my motor had 3 wires coming off it I swore they were messing with me :
Bob's not kidding. He really didn't know about the 3 wires...or the 3 seashells...
SpraydbySprague is offline
Old 03-08-2012 | 02:58 PM
  #12557
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Bob doesn't know how to use the three seashells?
*giggle*
T-BirdJunkie is offline
Old 03-08-2012 | 02:59 PM
  #12558
mxracer458's Avatar
Good write up Craig,my car with bb springs is very forgiving an pretty darn plush,keeps my car on 4 wheels alot when I mAke mistakes!!more time on 4 wheels means more laps and better times,maybe not the fastest but most consistent and that's whAt you need,well for me anyways lol
mxracer458 is offline
Old 03-08-2012 | 03:03 PM
  #12559
mxracer458's Avatar
Originally Posted by T-BirdJunkie
Craig, that dual-spring coilover pictured is not progressive. It's dual rate. In general, there is not enough room in RC shocks to have an actual progressive coil. Most of them are dual or triple rate IF they have any progression at all.
99% of all trophy trucks and buggies are dual rate shocks front and rear,the top spring is nice hitting the smaller stuff which really makes it plush,then you get in those 4 foot whoop sections and the bottom spring comes alive,even most sandrails run dual rate shocks with triple bypass,that's a whole other topic!
Old 03-08-2012 | 03:21 PM
  #12560
treky11's Avatar
Originally Posted by CraigMBA
Suffice to say, I went to a lot of trouble and expense to find a match for AE greens. And it's not TLR yellows.
What springs did you find to be equal to the AE Green and browns?
treky11 is offline
Old 03-08-2012 | 03:25 PM
  #12561
*giggle*
I figured it out. I in the first 1 and used the other two to cover it up.
Bob Barry is offline
Old 03-08-2012 | 03:29 PM
  #12562
whole lotta words
Thanks for the information. You also confirmed a few of my suspisions...
The biggest thing you did was prove me right LOL I was over thinking this stuff to the point that it's slowing me down.
Well since I have no std springs this week , I'll be running my BB springs again. I guess I'll go batty insane and try some stuff I never would have before LOL
Old 03-08-2012 | 05:14 PM
  #12563
+ 1 what are the same rates as the associated green and browns alls i can say is i went to reds in the front and yellows in the rear (losi bb springs) and i love them. i am thinking about trying white in the rear
JoshCorti11 is offline
Old 03-08-2012 | 05:31 PM
  #12564
ViGiLaNtE351's Avatar
Moderators : Can we have this link as a Sticky
http://www.petitrc.com/reglages/BuggyBigBoreSpring.pdf
With the amount of times the same question about what springs are the same as another brand, this should definatley be a sticky!!!
Anyone else agree? I think its time....
ViGiLaNtE351 is offline
Old 03-08-2012 | 06:09 PM
  #12565
Kraig's Avatar
Super Moderator
We can't sticky a link or a single post in a thread. It is all or nothing.
Racers, watch your language please.
Kraig is offline
Old 03-08-2012 | 11:26 PM
  #12566
easy e's Avatar
Default Air in shocks
I build my v2 shocks exactly exactly like the video saxton posted on YouTube. But no matter what more oil less oil slower bleed faster bleed do it 5 times when I turn the shock upside down I can always feel a pocket of air. Pump it a few times take the top and there will 3-5 large air bubbles. also the shaft sucks back in slightly
This literally driving me crazy. I'm not new to rc but I am to bleeder caps. My race buddy has b44.1 and has the same problem.
I watched saxton video 20 times and I still have air in the shock. I used green slime on the o rings, tried new shock caps, maybe someone can advise or make a point I'm missing
easy e is offline
Old 03-09-2012 | 03:42 AM
  #12567
rokitman's Avatar
anyone useing the ghea taper pistons? Wonder what your take was on them?
thanks
rokitman is offline
Old 03-09-2012 | 04:49 AM
  #12568
Matt Trimmings's Avatar
There is always going to be air in the shock, it's normal and your not going to get around it.
Matt Trimmings is offline
Old 03-09-2012 | 04:51 AM
  #12569
bds81175's Avatar
Moderator
If you have limiters in the shock you almost always get a bit of air trapped under the piston. Drive the piston up and down slowly a few times, not letting it rise all the way up to clear the surface of the oil. Set the shock aside for a bit and let the air bubbles rise to the surface. Then continue with the procedure. When you are done, the shaft should rebound very slightly after you compress it. The rebound should be equivalent to about the volume displaced by tightening the bleeder screw (not much in other words). Hope this helps.
bds81175 is offline
Old 03-09-2012 | 07:04 AM
  #12570
Teambcw's Avatar
anyone???
Teambcw is offline
