RC10B4.1 FT/WC
Old 09-08-2012 | 04:57 PM
  #20056
smittyusmc's Avatar
Ok so I have a quick question I bought the wrong rear hubs for my buggy. I got the ones that would go on the B44 they are the plastic ones on the package it says that they are for B4 and B44. My question is will they work on the B4 I know I have to get the right size bearings and thats fine I just want to make sure they will work. Thanks for the help.
smittyusmc is offline
Old 09-08-2012 | 05:15 PM
  #20057
elecRC23's Avatar
When do the 12mm shocks come out? And whew can I buy them?
elecRC23 is offline
Old 09-08-2012 | 05:19 PM
  #20058
Suspended
They are out now. Amain has them
http://www.amainhobbies.com/index.php/cPath/1_25_1450_1788/n/RC-Cars-Trucks-Parts-Team-Associated-RC10B41
PFKAOG is offline
  #20059
aeRayls's Avatar
If you already have a FTB4.1 you have everything you need already. If you have an older B4 or a rtr... You need the larger outer bearing and the proper crush tube to go between the bearings.
aeRayls is offline
Old 09-08-2012 | 06:14 PM
  #20060
NUZUM's Avatar
Hi guys just sold my 22 and bought a worlds and was wondering if most run shortys or full size packs and any good indoor clay setup or advice would be nice ..... i see alot of setups on petitrc .. but just like too hear what you all are runnin !!!
NUZUM is offline
Old 09-08-2012 | 06:15 PM
  #20061
YankeeFan123's Avatar
I'm running the xceleroin shorties but they puffed really quickly
YankeeFan123 is offline
Old 09-08-2012 | 06:22 PM
  #20062
elecRC23's Avatar
well, I checked that link. It goes to like hampstersdancing.com or something. I checked amain and they didn't seem to have them either. So I don't know if you were just messing with me or what.
elecRC23 is offline
Old 09-08-2012 | 06:24 PM
  #20063
ilanstylz's Avatar
He was messing with you, nobody knows when they'll be out. So you'll just have to wait like everyone else ............
ilanstylz is offline
Old 09-08-2012 | 07:03 PM
  #20064
HAMPSTERS!!!!!!!!!!!!
Bob Barry is offline
Old 09-08-2012 | 07:10 PM
  #20065
DLF
All, just broke out my old B4 and upgraded it with the +8 chassis. Additionally, it's been so long since I ran it, this will the first time I do so with lipo batteries. My issue is with the set screws that screw into the chassis. Blue thumbnuts are run onto them to hold down the battery strap. Problem is, I'm not getting many threads before the nut's stop. The setscrews are 1/2" long. Do you guys know of some longer 4-40 setscrews that will work better?
Thanks.
DLF is offline
Old 09-08-2012 | 08:11 PM
  #20066
elecRC23's Avatar
Wow, so mature
elecRC23 is offline
Old 09-08-2012 | 08:18 PM
  #20067
elecRC23's Avatar
I'm 14 and I know it's not right. I was asking a simple question and u hav to answer like that. WOW
elecRC23 is offline
  #20068
Matt Trimmings's Avatar
Thanks.
You only need to screw the setscrews in about 10 threads or so, they dont need to be bottomed out in the plastic. when my thumbscrews are in with a battery they are about even with the top of the setscrews
Matt Trimmings is offline
Old 09-08-2012 | 08:21 PM
  #20069
The plastic zero degree b44 hubs work great on the b4,you just need the right size bearings.I use these hubs on my b4.1 that I converted to worlds spec.
airwoods is offline
Old 09-08-2012 | 08:35 PM
  #20070
DLF
Thanks for the reply, Matt. In that case, I'll look into that.
Besides the +8 chassis, are there any other upgrades worth looking at for an old FT B4? The track I run on has become more suited for 1/8th scales if that helps on suggestions.
Thanks again.
DLF is offline
