RC10B4.1 FT/WC
Old 02-06-2012 | 08:25 AM
  #10966
racer1812's Avatar
Super Moderator
Originally Posted by Asharus
Grats on the trophy Guy, it was a fun race. At least the last few laps was clean, LOL! I still feel horrible about what happened 13 seconds into this vid.
+ YouTube Video
why didn't you wait
racer1812 is offline
Old 02-06-2012 | 08:37 AM
  #10967
RCHR's Avatar
Originally Posted by Wild Cherry
Cut 3/16in from the inside of the pads....
Makes the slipper more consistent....
easier to adjust & stays the same longer
Surface area looks similar to the Losi slipper setup, seems like you could just use Losi gears and pads for the same effect.
RCHR is offline
Old 02-06-2012 | 08:48 AM
  #10968
Wild Cherry's Avatar
Tech Legend
You could give give those parts a shot ...
The mod works great ,won't have to buy any extra parts.
Wild Cherry is offline
Old 02-06-2012 | 09:44 AM
  #10969
Has anyone done the "losi spring conversion"? Do you notice a difference? Someone at my track said it makes a huge difference in the way the car feels?
faze is offline
Old 02-06-2012 | 09:49 AM
  #10970
im using kyosho springs and their really nice (pricey but nice) a few people at my local track are using losi springs and they say its fairly similar to stock associated ones. im trying kyosho's since i have a full set of front and rears from my rb5.
derbrylac is offline
Old 02-06-2012 | 09:50 AM
  #10971
Guys, where can I get more of these Golden 4-40 locknuts from the Carbon C-tower?
http://www.amainhobbies.com/product_...rce=google_ext
GuiltyByAssoc is offline
Old 02-06-2012 | 10:10 AM
  #10972
brent701's Avatar
#4449
brent701 is offline
Old 02-06-2012 | 10:25 AM
  #10973
Originally Posted by brent701
#4449
Ordered, Thanx!
Old 02-06-2012 | 11:50 AM
  #10974
F18engineguy's Avatar
Default spur gear wobbling
Any of you ever had a problem keeping your spur gear from wobbling? I installed new gear, new slipper and pads, new bearings inside of case, new spring and washer and nut. No luck. I did not change the top shaft, but I just really don’t think it could be bent. To be honest I don’t think the spring sits square on the slipper plates. Almost as if un even pressure is being applied to the slipper. Any thoughts?
F18engineguy is offline
Old 02-06-2012 | 11:56 AM
  #10975
Tech Legend
Not unusual to find a bent top shaft , also motor plate ....
If the spur is wobbling as bad you sound , most likely one or the other ....
Old 02-06-2012 | 11:59 AM
  #10976
brent701's Avatar
Have you not been reading the last 100 or so pages of this thread?
I think 20+ pages straight were about Losi BB springs, lol
But to answer your question. Yes a lot of people are using. yes they make a difference to a point. Do they make you faster? to a point yes. do they feel different, yes.
Are they worth it. To me yes they are. to others maybe not so much.
brent701 is offline
Old 02-06-2012 | 12:02 PM
  #10977
Agreed! I'd go with the top shaft as the primary suspect. I've bent 2..
Old 02-06-2012 | 12:04 PM
  #10978
[QUOTE=Wild Cherry;10286622]Not unusual to find a bent top shaft , also motor plate ....
I guess I will change the top shaft and see what we get. I'm just thinking that if the shaft was bent the spur would kind of move up and down not move in out.
If the spur is wobbling as bad you sound , most likely one or the other ....[/QUOTEI guess I will change the top shaft and see what we get. thanks
Old 02-06-2012 | 12:05 PM
  #10979
Yep, but with mine its because the machined areas on the top shaft that accept the back slipper plate are off. I contacted associated today and they are supposed to be sending out a replacement for that and rear hubs. The left side 0* hub included with my worlds kit is machined much to large for the bearings. You can actually watch the inner bearing spinning in the hub when you hold the car up. Not to mention how far you can move the drive shaft back and forth within the hub...
KSimmonds is offline
Old 02-06-2012 | 12:50 PM
  #10980
idrummerboy13's Avatar
+ YouTube Video
thanks, i would have let jay go be he spun my in a circle and that was not cool. no1 waited for me so why should i wait for no1? lol. Good job on second. Need to get faster and find my 18 lap
idrummerboy13 is offline
