RC10B4.1 FT/WC
Old 06-23-2011 | 03:26 PM
  #3466
MiCk B's Avatar
Hey,
Some wheel bearings caster blocks and steering arms. That should leave you sorted out.
MiCk B. :-)
Originally Posted by nashvillecactus
what is a good short list of spare parts I should have on hand for my b4.1 FT? The local track does not really have any spares for sale, and my LHS is spotty at best for anything related to offroad buggy, so I need to order what I need beforehand in case I break at the track. I have front arms on order, I'm going to pick up rear arms from my LHS on Saturday, I have front and rear shock towers, I have spare CVD assemblies, what else should I keep on hand?
Thanks!
MiCk B is offline
Old 06-23-2011 | 03:28 PM
  #3467
Asharus's Avatar
Originally Posted by Teufel Racing
Thanks for the tip on the RPM ball cups,
Had thought of running those, as past practice has showed me they are better. Yeah I only broke the rear camber link ones. Not sure why those only break.
I'm pretty sure it's due to the turnbuckle not being long enough back there to give more meat for the OEM ballcup to hold on to.
Asharus is offline
Old 06-23-2011 | 03:30 PM
  #3468
Asharus's Avatar
Thanks!
I haven't broken anything except for the rear ballcups *knock on wood*. It sounds like you have pretty much everything covered though. Some spare front wheel bearings and wheel locknuts (front and back) wouldnt be a bad idea to have either. I converted my front axles to the nut type instead of the BHS because I prefer having a nut instead of a hex screw on something I remove after every run.
Asharus is offline
Old 06-23-2011 | 03:44 PM
  #3469
bds81175's Avatar
Moderator
If you are as stellar a driver as me you might want to carry some extra wings. I think someone may have mentioned it already but CVD rebuild kits. Shock o-rings too. I've been using the X cross section nitrile rings from McMaster Carr. If you get hit in the rear end just right you can also break the rear arm mount chassis plate (9818). Not sure how I even managed to break that one but I did.
bds81175 is offline
Old 06-23-2011 | 04:17 PM
  #3470
racer_guy's Avatar
Thanks!
front a-arms are good to have, some spare wings arent too bad to have either. some tuning option that are good to have are: different shock oils and springs, maybe some pinion gears.
racer_guy is offline
Old 06-23-2011 | 04:24 PM
  #3471
Asharus's Avatar
Ah yeah I'm still on my first wing but I have a spare. I personally use the kyosho grooved o rings on both my sc10 and b4.1, I haven't had to rebuild my shocks yet and it's been about 2 months, racing once or twice a week.
Asharus is offline
Old 06-23-2011 | 06:01 PM
  #3472
I converted my ballcups to the RPM's, so far that's been a big help. As far as the front axles, I've been thinking about doing the same thing. Invariably, dirt gets packed back in the little screws and I have to go and dig it out, so far I've been using a teeny tiny flat screwdriver. So where do you find alternate axles to do this?
nashvillecactus is offline
Old 06-23-2011 | 06:28 PM
  #3473
idrummerboy13's Avatar
really, still smooth? thats cool never heard of that.
idrummerboy13 is offline
Old 06-23-2011 | 06:34 PM
  #3474
Nice, I wanted to check out the Kyoshos, but I see no reason to switch if there's no significant improvement.
same here im iffy.
i got the rtr and obv changed out everything cept for b4 shocks and gear diff,cvds. still doesnt handle like the ft i drove which is running cav setup. thing was perfect,how ever i would like a car that could turn and grip, plus most people drive em! well alot=/// 22 doesnt have enough support now for me. not nuff parts on the wall..
Old 06-23-2011 | 09:38 PM
  #3475
Wild Cherry's Avatar
Tech Legend
Originally Posted by Marcos.J
i will keep that to my self for now unless he does it again then I will call him out
my bad comment & i know better ...
Wild Cherry is offline
Old 06-23-2011 | 10:21 PM
  #3476
Asharus's Avatar
Associated makes em, I think it's the T4 axles, or the SC10. I've seen RTR B4.1s with them too, but I'm too tired to look up the p/n right now.
Edit: I guess I'm not too tired, ASC 9613, you will need e-clips and either nylon nuts or the locknuts you use for the slipper.
Asharus is offline
Old 06-23-2011 | 10:22 PM
  #3477
Asharus's Avatar
Yeah, check this. http://www.shortbusracers.com/2011/0...shock-leaking/
Asharus is offline
Old 06-24-2011 | 03:01 AM
  #3478
Thanks!
Old 06-24-2011 | 07:03 AM
  #3479
B.A. Racer's Avatar
cant forget spurs!
B.A. Racer is offline
Old 06-24-2011 | 07:30 AM
  #3480
Jmuck69's Avatar
Originally Posted by B.A. Racer
cant forget spurs!
Invest in some Kimbrough spurs and save yourself some frustration. They run truer and wobble free as compared to standard AE spurs.
Jmuck69 is offline
