RC10B4.1 FT/WC
I tried the simple green turnbuckle thing and it did not work, I even added an 8th battery I tried my worn down silver a.e turnbuckles on my b4.1 and my shiny brand new blue ones off my 4wd. I use speaker wire which i guess may be the problem. It got like blue green and corroded after 2 tries. PLease help i just spent 20 bux in batteries and undid my turnbuckle ends
...exactly! You have to let the turnbuckle be the conductor in the simple green. Dont let the wire on your t/b in the fluid. Wrap the threads, dunk the majority of the rod and wait until you get the desired color. Take it out, flip the wire to the other end and dunk the remaining untreated part of your t/b.
The shade of color will vary by the length of time you soak it.
ps- I used alligator clips. Makes the job even more simple!
Way tight transmission screws ?
Suggest adding one 3/16th axle shim in ft of top shaft spacer....( not for spacing , better for bearing to ride on)
Also use the servo kit washers, not the metal .030 washer
transmission screw's...
*Lock Tight
note:
If transmission case is well used & screw's were way tight , it is now mostly warped & needs replacement .
*Lock Tight
note:
I'm just curious where I could find some serrated wheel nuts. I was thinking about taking a dremel to mine, but buying some would be much simpler.
Someone even suggested that taper could point down giving quicker rebound allowing a lower spring rate. Benefits??
Has anyone found that there lap times inproved as they went from a B4 to B4.1 either converted or just a new kit. Is the B4.1 faster all personal set ups considered. I do understand that the +8 chassis can help with this.
Please excuse the learner Q's. Thanks for any thoughts.
Good morning Gentlemen,
Ghea parts are here and will be on our website with in an hour. i appreciate your patience and i have more than enough for everyone who was looking for them.. Thank you once again
nicee. the vented slipper plates, jc spur and new pads are very good. The pads last much longer with the vented, ill try this tho.
Picked up third in the a with my 13.5 buggy today at the tracks trophy race, down to the f mains! man was that a fun wait!
i got a slick track setup that i can give out to anybody who wants, for indoor clay, very wet, slippery but the traction is pretty good, dirt still has to settle due to a fresh layout
| + YouTube Video | |
