RC10B4.1 FT/WC
Old 02-05-2012 | 08:02 AM
  #10921
idrummerboy13's Avatar
Originally Posted by rednck21
Pledge works great too.
works the best I think, then after it dries coat in wd40 just a little bit or silicone. Then it won't get messy=]
idrummerboy13 is offline
Old 02-05-2012 | 08:07 AM
  #10922
B.A. Racer's Avatar
Originally Posted by idrummerboy13
nice, hear k springs are dialed and worth it if you can give 40 dollars.
What can i do for when I land on a table top which is right before a turn, I am landing just on the downside but if i turn while landing my rear washes out. The jump was just added so its slick but Im trying a little more oil because my rear can use more pack. 32.5 all around Im going. I can always change oils fast in my car so its all good=]
32.5 is kinda stiff for the rear...what pistons are you using front and rear?
B.A. Racer is offline
Old 02-05-2012 | 09:02 AM
  #10923
YankeeFan123's Avatar
Originally Posted by chancejeff
you think its all driver preference on camber and stuff because i was running at like 4 degrees front and rear and turning out avg 15sec laps in second place stock buggy than i was told thats way to much in so they said go to 1 degree for both and now i feel less consistant running fastest at low 16 when my avg was 15sec
Hey, I you're running a second and a half faster each lap, why change it? If it works for you and you're faster and more consistent who cares what other people say, it works for you
YankeeFan123 is offline
Old 02-05-2012 | 09:06 AM
  #10924
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by Bob Barry
New tire setup = dialed
4w fronts on the rear?
Interesting.
T-BirdJunkie is offline
Old 02-05-2012 | 09:26 AM
  #10925
bcrazy's Avatar
Interesting.
looks like 2wd fronts in the rear
DIALED!!!
bcrazy is offline
Old 02-05-2012 | 09:48 AM
  #10926
Wild Cherry's Avatar
Tech Legend
Originally Posted by cantrell8
hey buddy, im sorry for bein a dick to ya a while back.
such a good sport ....
Wild Cherry is offline
Old 02-05-2012 | 09:50 AM
  #10927
#2 around 2 limiters, white loss springs, and silver front losi. 27.5 slaps a lot, the layout is large and has big jumps
Old 02-05-2012 | 10:02 AM
  #10928
B.A. Racer's Avatar
put #3 pistons in the rear with 27.5
Old 02-05-2012 | 10:05 AM
  #10929
Tech Legend
Team Set up uses #2 27.5 in rear shock
Old 02-05-2012 | 10:31 AM
  #10930
http://www.youtube.com/watch?v=p9DSBxBF8Zo
what would be a good setup for this track
clay is wet
chancejeff is offline
Old 02-05-2012 | 11:15 AM
  #10931
bcrazy's Avatar
I have gone to the #3 piston in the back of my B4.1+8 and it works great for me.
I started with this setup but have gone to the 0 deg hubs in the rear with the C mount and no washers on the inside camber link. My car felt good at the Reedy Race with this setup but my driving was not so good
I did just order some Losi BB springs to try on my buggy.
http://www.teamassociated.com/pdf/ca...ercup_2011.pdf
bcrazy is offline
Old 02-05-2012 | 11:44 AM
  #10932
Originally Posted by brent701
Why not. It's only been post 10+ times throughout this thread, lol
Front
AE 9880
AE 7496
AE 4449
Jconcpet 2135
Rear
Jconcpet 2091
If I already have serrated wheel nuts then I dont need part#4449 right?
Old 02-05-2012 | 12:18 PM
  #10933
B.A. Racer's Avatar
im running a similar setup to jasons..my b4 has never felt so good
Old 02-05-2012 | 01:07 PM
  #10934
BrentH's Avatar
I'm assuming those running the #3 piston in the rear are on high traction, smooth surfaces. I think its worth noting what surface you are running on as it varies around the nation (the world for that matter) when talking about setups
BrentH is offline
Old 02-05-2012 | 01:09 PM
  #10935
brent701's Avatar
the RS steering blocks use #4449 locking nut to hold the ball stud to it. the SC10's without hex do not. The ball stud screws to the block itself
SO to hold the Ball studs to the steering blocks #9880 you need the locking nuts #4449
See the nut looking hole in the block?
brent701 is offline
