RC10B4.1 FT/WC
Old 01-07-2012 | 08:31 PM
  #9406
brent701's Avatar
Originally Posted by Ryno B4.1
Some of us are just too damn lazy to take the bearings out all the time
lol. It does get annoying though lol
brent701 is offline
Old 01-07-2012 | 09:18 PM
  #9407
idrummerboy13's Avatar
im not lazy but i always clean my tires after practice and races, when your racing you wanna waste as little time as possible and get on the track, plus its the same nut size as rear so you need one less driver, also alot less slop and wheels are universal so if only 22 wheels are stocked i can use em.
Will switch the rear also for the same reasons.
idrummerboy13 is offline
Old 01-07-2012 | 09:28 PM
  #9408
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Originally Posted by idrummerboy13
Anybody using the proline front hex ? I can get some from track they look nice also
It takes 3 seconds ThunderbirdJunkie's bearings press firmly into the wheel on PL Velocities, never had one fall out.
Originally Posted by racer1812
maybe covered BUT, is there a reason the Traxxcrap spring cups won't work with the TLR springs? They fit a little tight over the rod end but other than that I don't see a reason they won't. I got springs but the TLR cups were on B.O...
The Traxxas spring cups are taller and push the bottom of the spring up in relation to the arm/rod end.
T-BirdJunkie is offline
Old 01-07-2012 | 09:42 PM
  #9409
Default kyosho
anybody know the spring rates of the kyosho big boars that are close to greens and browns. Thanks.
Old 01-07-2012 | 09:47 PM
  #9410
Jake S's Avatar
http://www.petitrc.com/setup/kyosho/...WheelRates.pdf
petitrc / oople are my two fav sites
big sheet of them:
http://img.photobucket.com/albums/v2...BoreSpring.jpg
Jake S is offline
Old 01-08-2012 | 12:02 AM
  #9411
Wild Cherry's Avatar
Tech Legend
Default Updated set-up for the 8m
Ft
#1 piston , 35w , 2 x .030 limiter, silver 12m Losi BB spring
Shock =inside on tower & outside on arm
Camber stud 1 X .030 limiter
Camber link inside on tower & inside on caster 30 degree
1/4oz in ft corners & 1/2 oz in ft of servo
*graphite nose plate & ft arms
24m ride height
1/4oz in back corners & Ae ballast weight next to transmission
Rear
#2 piston ,27.5w, 2 x.030 limiter, white Losi 12mBB spring
Shock = Inside on arm & tower & 1 x .030 under ball stud on u brace
camber link = inside on U brace & middle on hub
Rear hub = 0 degree ,mounted in middle , 3 degree toe block, 2 degree anti squat
24 m ride height
*Plastic rear arm
*Carbon U brace
Tire
JConcept Gold Bar Code
Track conditions
Smooth Clay , lots of shape corners, no hard landings , med traction ...
We are having the Pacific N/w ShootOut next weekend , this is what the guys are using including me ...
Wild Cherry is offline
Old 01-08-2012 | 02:53 AM
  #9412
mrbusta's Avatar
broke the plastic bulk head last night and the front hinge
pin holder and lost a pin lol bad landing on a jump is the alloy version worth purchasing and anyone got a link to whats good thanks guys
mrbusta is offline
Old 01-08-2012 | 06:07 AM
  #9413
F18engineguy's Avatar
I have a brand new alloy one I can sell you if you like...PM me
F18engineguy is offline
Old 01-08-2012 | 08:18 AM
  #9414
Well the new worlds car is out and ot has all of the stuff we have been running since its been aval. and the kyosho car has been playing with the long chassis just as long and still cant get one out yet or even put in the worlds car ,this tells who is on top of what people want in a kit that says WORLDS car ,minus the k car springs . This is not to put kyosho down just making an observation .
blingy is offline
Old 01-08-2012 | 08:42 AM
  #9415
SoccerSting's Avatar
I made an aluminum front hinge brace and bought the STRC bulkhead. The Associated one is ridiculously expensive.
SoccerSting is offline
Old 01-08-2012 | 08:49 AM
  #9416
tomdav's Avatar
Originally Posted by Wild Cherry
Ft
24m ride height
Rear
24 m ride height
*Plastic rear arm
*Carbon U brace
Tire
Track conditions
So your using the plastic b44 hubs?
tomdav is offline
Old 01-08-2012 | 10:08 AM
  #9417
jirish617's Avatar
Originally Posted by patiofurniture
You have no mention of the number of inner ball stud washers front and rear. I would make sure that you at least either have one or no ball stud washers in the rear and on or two in the front. If you want the car to turn in more and rotate go with fewer washers in the rear. If you want the feeling of more traction at the expense of mid-exit steering ad a washer in the rear. In the front if you want more initial turn in go with fewer washers, but for more exit steering add one. Typically adjusting the rear washer height is a little more sensitive of an adjustment than the the front.
Also I would bet that you car feels so twitchy because your springs are too stiff front and rear. Try at least going to one stage softer with 30wt fr and 27wt rear with #2 pistons in front and #3 piston in the rear with standard limiters. You shouldn't have any chassis slap unless you are either flat landing, or unevenly landing on the downside.
Correct me if i'm wrong, but i thought if you lower your roll center(adding washers) you will rotate/slide easier. (i am talking about the rear). The reason I say this is when the 3-4page debate about roll center a few weeks back on here was being talked about. I was having a traction roll issue with one washer in the rear, when I went to 2 washers I was no longer traction rolling and the car could be thrown into corners easier. Talking to locals at the track some said they are running 3-4 washers allowing more rotation. Unless i'm not understanding the meaning of rotation?
jirish617 is offline
Old 01-08-2012 | 10:22 AM
  #9418
Tech Legend
The K-spring is all good , but the Losi BB are great as well..
We have a few with the BB K-springs and they have been using for a few days now , soon I can tell you if they are really worth the extra $ and effort to find .
The team also use Ae springs at Worlds so you know , so the new B4.1 Worlds does represents what the team used ...
Tom
Yes, all are using Gold Bar Code.
Many are also using they softer JConcept insert & are using 4 or 5 wraps of duct tape on the center of rim to help remove air space between the insert.
yes , 0 degree rear hub , blue or plastic B44 all good .
Old 01-08-2012 | 10:31 AM
  #9419
tomdav's Avatar
Tom
Tape on the rim! You guys have way to much time to play with rc, I'm jealous.
tomdav is offline
Old 01-08-2012 | 10:42 AM
  #9420
tomdav's Avatar
Cherry are you guys using the shorty packs?
tomdav is offline
