RC10B4.1 FT/WC
Old 03-06-2011 | 07:12 AM
  #1906
racer1812's Avatar
Super Moderator
Originally Posted by B.A. Racer
just got my ballistic 10.5 for the t4...what would be the recommended overall gearing? ill be running on medium sized dirt and clay tracks
87/22 to start, then adjust for heat.
racer1812 is offline
Old 03-06-2011 | 10:13 AM
  #1907
FantomLeopard's Avatar
+1
I might actually gear just 1 tooth steeper at 87/23 but it would be better to start at 21 or 22 and then go from there. Are you going to boost the motor or add timing?
FantomLeopard is offline
Old 03-06-2011 | 12:37 PM
  #1908
B.A. Racer's Avatar
not for indoor right now..but for outdoor i may boost it...what would be a recommended boost for the ballistic? im running tekin esc
B.A. Racer is offline
Old 03-06-2011 | 04:23 PM
  #1909
Actually, even for outdoor you may not need any boost with a 10.5.. It should have enough power/torque for everything in a T4. You might try 10-20 and see what works from there Make sure you watch the temps when you DO boost it so you can find a good middle ground on it.
Old 03-06-2011 | 08:38 PM
  #1910
Wild Cherry's Avatar
Tech Legend
Originally Posted by Jowers
Isn't that what the slipper is for?
Don't start on the dumb pads grazing over really bad like , even though they used to perform just fine till about month or so ago .
Kinda like the old days when diff rings use to be great ...
Now its sandpaper time ....
Well ?
Till Ae gets another fresh batch ....
Wild Cherry is offline
Old 03-07-2011 | 06:19 AM
  #1911
Default aluminum front bulkhead set screw size?
Hello, I need some help with a aluminum front bulkhead (#7990). Does anyone know the set screw size or even better a part number for replacement set screws?
isarctard is offline
Old 03-07-2011 | 06:32 AM
  #1912
1Fastpede's Avatar
Four 4-40 x .093" set screws
Try ace hardware.
1Fastpede is offline
Old 03-07-2011 | 06:57 AM
  #1913
Thanks, I couldn't seem to find them on the AE site.
Old 03-07-2011 | 08:52 AM
  #1914
I searched the AE site for the set screws and could not find them. I found that a bit strange so I called them. The size of the set screws are 5/40x1/8, part#3862.
Old 03-07-2011 | 09:04 AM
  #1915
1Fastpede's Avatar
I got my info from here:
http://www3.towerhobbies.com/cgi-bin...7990&search=Go
Also check here:
http://www.robotmarketplace.com/prod...7092_parta.pdf
Step#11 for part number verification
Step#20 for set screw size verification.
Old 03-07-2011 | 09:38 AM
  #1916
Thanks, but from your references of #11 & 20 thats the rear of the truck that's not even a T4.1. or to do with the front alum bulkhead. The tower hobbies do use the sizes you gave me, but I think AE information and part # is what Im going to use. I was not trying to debate you or try to say you are wrong just guide the next person who might ask this question to a part# to make it easier on them.
Old 03-07-2011 | 11:14 AM
  #1917
racer1812's Avatar
Super Moderator
he was refering to the GT2 manual, in which steps #11 and #20 are correct. They list them as 4-40 set screws but I get nothing on Tower for the part number (7382) listed in the manual. Either way you don't NEED the set-screws, the pin is captured by the front brace and the hinge pin screw in the a-arm..I would go with what AE told you to order..
Old 03-07-2011 | 11:19 AM
  #1918
Hmm, good point the pins should stay with those two options. This is my sons truck, so I was trying to take all the precautions I can. He is kinda rough on things.
Old 03-07-2011 | 12:02 PM
  #1919
Brazie's Avatar
Default Stock motor sucks. Looking for suggestions to upgrading my motor. Thanks!
Here is what I got:
All stock RC10T4.1 brushed RTR with a Reedy 17 turn motor that sucks majorly.
I am looking into getting a Velineon 3500 kv Brushless Motor 10-turn. It is $159.99 at Tower Hobbies and it also comes with a Velineon VXL-3s ESC. I will be running 2s lipos.
Just wondering if that is a good deal for an upgrade. Not trying to get top of the line stuff. The RC10T4.1 is for my daughter. Also if anyone has a better suggestion for a motor I'd greatly appreciate it.
Yesterday my Gf, daughter and I went out to go bashing at a bmx track. My gf and daughter each drive a RC10T4.1 and I drive an RC8be. Once we arrived my daughter got upset with me that I didnt charge her battery cause her car was really slow. Making a short story shorter, it wasnt her battery it was her motor. We Literally had to kick the tail end to get the car moving.
Brazie is offline
Old 03-07-2011 | 12:20 PM
  #1920
1Fastpede's Avatar
You do realize that aluminum bulkhead is from a GT2 and it works on a T4 which is why i showed you the GT2 manual. and step# 20 is the front of the truck. look again.
Page#4 step 11 (shows picture of bulkhead and PART #)
Page #5 step 20 (notes screw size)
goodluck with your 5/40 screws
