RC10B4.1 FT/WC
Old 04-28-2011 | 12:53 AM
  #2656
mellow's Avatar
Whats the reason behind Cav using a plastic FR Hinge pin brace?
mellow is offline
Old 04-28-2011 | 02:18 AM
  #2657
mrjeremyaaron's Avatar
Originally Posted by TheModTurtle
http://www.rctech.net/forum/electric...ne-modify.html
http://www.rctech.net/forum/electric...-1-thread.html
First one is the B44 and the second is B44.1
Next time, just use the advanced search, its very effective like using psychic versus fighting...
mrjeremyaaron is offline
Old 04-28-2011 | 05:00 AM
  #2658
Jmuck69's Avatar
Looks. He likes the all blacked out look.
Jmuck69 is offline
Old 04-28-2011 | 06:26 AM
  #2659
kyle3333's Avatar
I have heard that since it is plastic, it flexes a bit and therefor offers more steering. But, it could just be aesthetics as well.
kyle3333 is offline
Old 04-28-2011 | 07:14 AM
  #2660
t0p_sh0tta's Avatar
I actually think that I have enough weight in the rear and put mine a little closer to the front. One on the bulkhead and then up front in the slots for the esc/receiver.. Have you tried adjusting the rear end instead of adding weight?
Yes, any softer and I get too much chassis slap. I'm running green springs out back with #2 pistons and 27.5 AE fluid.
My setup is almost identical to this.
t0p_sh0tta is offline
Old 04-28-2011 | 11:54 AM
  #2661
Jake S's Avatar
it also lets the cheaper brace wear out before arms
Jake S is offline
Old 04-28-2011 | 03:19 PM
  #2662
jcr
Just picked up the T4.1 (non factory team). Was wondering what are some good parts to pick up?
Anyone used the Yeah Racing aluminum parts?
jcr is offline
Old 04-28-2011 | 03:54 PM
  #2663
Jake S's Avatar
bashing? or racing?
if your bashing or racing id suggest getting a set of front arms for when it happens lol
if racing, look into "the hot tire" setup at your local track.
if your bashing, the brushless t4.1 is great, nothing really need upgraded to have fun.
Jake S is offline
Old 04-28-2011 | 06:00 PM
  #2664
B.A. Racer's Avatar
what would be a good starting point for a 13.5 in a b4 for small indoor track?
B.A. Racer is offline
Old 04-28-2011 | 06:01 PM
  #2665
racer53's Avatar
With or without timing and boost???
racer53 is offline
Old 04-28-2011 | 06:02 PM
  #2666
B.A. Racer's Avatar
no timing or boost yet..just indoor for acouple more weeks then will put the 8.5 back in
Old 04-28-2011 | 06:06 PM
  #2667
racer53's Avatar
Without timing or boost I am running 28/78...you might can go higher on the pinion just watch your temps...
racer53 is offline
Old 04-28-2011 | 06:18 PM
  #2668
B.A. Racer's Avatar
dang idk what happened to my 78 but i have 75 and an 81 which pinions for those and which would you prefer?
Old 04-28-2011 | 06:22 PM
  #2669
mjk1210's Avatar
go with the 75. it will move the motor forward for better balance. Then use anything between a 24 and a 32 and check temps and performance every couple minutes until you like it.
mjk1210 is offline
Old 04-28-2011 | 06:25 PM
  #2670
B.A. Racer's Avatar
ok cool..i was going to run a 27/75 first off... just wanted to see the opinions
