RC10B4.1 FT/WC
Old 10-31-2010 | 06:29 PM
  #751
1Fastpede's Avatar
Originally Posted by bigdog
Anyon else have a messed up b 4.1 kit! I wa finishing my kit and realized my left rear cva had no thread on it and I did have nuts for the rear tires
yea mine was missing the rear wheel nuts. i emailed them and they sent replacements in 2 days. which was cool
1Fastpede is offline
Old 10-31-2010 | 07:02 PM
  #752
Chris email sent thanks again! Cant wait to run wed night!
bigdog is offline
Old 11-01-2010 | 11:33 AM
  #753
rc east's Avatar
Just finished! went with the Cav. set-up from rc10.com
Attached Thumbnails RC10B4.1 FT/WC-dscf1781.jpg
rc east is offline
Old 11-01-2010 | 03:41 PM
  #754
i1justin's Avatar
so you drilled a hole in the rear shock tower and bought extra 0* factory hubs?
I see your running a indoor clay tire (or blue groove tire) so I see why you went with that setup, I mainly run outdoor but travel to do some indoor clay during the winter so I was just looking and thinking of what changes to make to that setup since, I was looking to not drill the tower for now and going to run the .5* hubs that come in the kit.
He went with 3 inboard toe, so i know its not the same thing but what might we expect using the 2.5* inboard toe and the .5* hubs compared to the 3* inside and the 0* outside.
i1justin is offline
Old 11-01-2010 | 03:59 PM
  #755
UltegraSTI's Avatar
Originally Posted by i1justin
so you drilled a hole in the rear shock tower...
so guys are doin on trucks what they used to do on bugs?
R
UltegraSTI is offline
Old 11-01-2010 | 04:01 PM
  #756
Anthony.L's Avatar
Justin, I race at TRCR and run a setup very similar to Ryan's posted on rc10.com. I'm running the drilled hole on the rear shock tower and the 0* rear FT blocks. Both made a very noticeable difference on the track at TRCR. I've yet to run the T4.1 anywhere else.
I will post my full setup soon, need to document it anyways.
Anthony.L is offline
  #757
mattleegee's Avatar
i did the 4th hole/ 0* hubs also
mattleegee is offline
  #758
Anthony.L's Avatar
Yes.
Old 11-01-2010 | 04:02 PM
  #759
i1justin's Avatar
4th hole, does that equal more rotation or less for the back end? so now i gotta go buy the 0* hubs, bummer. At least the .5* work great outdoors
i1justin is offline
Old 11-01-2010 | 04:43 PM
  #760
rc east's Avatar
Actually I'm hoping they have the 0* hubs at the shop. thats the last thing I need. where can I get the part # for them? Are they just the old plastic T4 hubs?
rc east is offline
Old 11-01-2010 | 09:40 PM
  #761
Anthony.L's Avatar
More rotation.
Old 11-01-2010 | 09:45 PM
  #762
Anthony.L's Avatar
Well if you have a Factory Team 4.1 then you want these alum 0* hub set. This is what I'm running on my FT T4.1.
ASC9864
There is a plastic 0* degree hub set part number but I cannot find it.
Old 11-01-2010 | 10:39 PM
  #763
i1justin's Avatar
Originally Posted by Anthony.L
More rotation.
Thanks Anthony!
i1justin is offline
Old 11-01-2010 | 10:41 PM
  #764
Anthony.L's Avatar
Thanks Anthony!
The truck just felt more "free" in the infield and ultimately much faster.
Old 11-02-2010 | 07:22 AM
  #765
rc east's Avatar
ASC9864
ok I found them Thanks! I hate the thought of blowing another $30 but are these basically the same as the b44 hubs?
http://www.teamassociated.com/parts/details/9730/
I have plenty of these that I can run for now, should give the same results right?
seems like the 0* hub with 3.0* toe block is about the same as 0.5* hub with 2.5* toe block just a slightly shorter wheelbase? is that what makes the difference?
rc east is offline
