RC10B4.1 FT/WC
Old 10-27-2010 | 08:42 PM
  #721
Cameron Kellogg's Avatar
Originally Posted by mattleegee
Thank you... so it doesnt really matter? Just use the same on both sides?
Well if your name is Ryan and you do this for a living then yes it is a big difference.
Just use the same on both sides and you should be good. It's just a tuning option to compromise middle hole not enough and out side too much. Then the B set of holes might be perfect.
Cameron Kellogg is offline
Old 10-27-2010 | 08:44 PM
  #722
mattleegee's Avatar
Yeah i just jammed the ballstuds in the hole i picked out for them to go into, im sure someone at the track will set me straight when they see what i have done
(im new )
Do you happen to know where i can find a "how to" on building v2 shocks? I have been up and down rc10 im freakin out
mattleegee is offline
Old 10-27-2010 | 08:52 PM
  #723
http://www.teamassociated.com/manuals/
Check out this link and select one of the kits that have the V2 shocks. T4.1, B4.1, or SC10. You will see the "factory team" manual. Download and view.
Old 10-27-2010 | 08:59 PM
  #724
mattleegee's Avatar
great i was on that page forever... about the only one i didnt open
Old 10-27-2010 | 09:42 PM
  #725
azz187's Avatar
Default 17.5 gear ratio
Hey guys
Can someone suggest a good gear ratio for a b4.1 on a medium size dirt track with:
Speed passion3.0- 17.5 turn and Tekin RS PRO, without boost/timing? and a good starting point with boost and timing advanced?
azz187 is offline
Old 10-28-2010 | 08:47 AM
  #726
rc east's Avatar
Originally Posted by rick_da_rookie
I just bought a B4 and wonder if someone can point me toward a really good setup for packed clay, rough, sometimes dusty, low/med traction. I have searched around and have not had much luck.
I havent seen much mention of the swaybar....is it necessary or needed?
Thanks!
This one works good for my B4, no swaybar
http://www.teamassociated.com/pdf/ca...assic_2009.pdf
rc east is offline
Old 10-29-2010 | 07:22 AM
  #727
rc east's Avatar
Default T4.1 build
Finally got my T4.1 the other day, so far the build seems to be flawless. Funny, directions say nothing about grease on the trans gears? all I have left is the shocks. I noticed 5 limiters in front shocks? Whats evrybody running for indoor clay shock set-ups?
rc east is offline
Old 10-29-2010 | 07:50 AM
  #728
kyle3333's Avatar
You really don't need to put anything on the transmission gears at all. Some guys put a little bit of pledge on the idle(middle) gear. It is also a good idea to mark the gears when you initially assemble, so that when you rebuild the gearbox the gears are put back as they where when initially assembled. This cuts down on the possibility of a potentially noisy gearbox after a rebuild.
kyle3333 is offline
Old 10-29-2010 | 10:11 AM
  #729
mdowney's Avatar
Very few kits tell you to grease the tranny gears but I always use a but of AE black grease on all of them.
mdowney is offline
Old 10-29-2010 | 10:32 AM
  #730
rc east's Avatar
Yeah I figured a little black grease can't hurt, honestly this is the first kit I've built from scratch since the old rc10 gold pan! jeez that musta been a good 15 or so yrs ago! anyway thanks for your help, can't wait to hit the track with this thing.
rc east is offline
Old 10-29-2010 | 10:50 AM
  #731
VegasHB's Avatar
Yikes, black grease is too sticky to use as gear lube if ya ask me. Probably makes it super quiet but I can't imagine it helps if not hurts performance. If anything maybe a puff of graphite powder. I use the pledge.
VegasHB is offline
Old 10-29-2010 | 10:58 AM
  #732
RCmayor's Avatar
Stealth lube works best, or Aero Car super gear lube.
RCmayor is offline
Old 10-29-2010 | 11:03 AM
  #733
Might be weird but I've always had really really good luck with AE Green Slime. I use it in my B4.1/T4.1/B44.1/SC10 transmissions and they all are extremely free and long lasting.
You can also try this I've using it with great results on all my 1/8th stuff. It should work just as good in 1/10th.
Chris Jarosz is offline
Old 10-29-2010 | 11:15 AM
  #734
Ae*Driver*70's Avatar
Talking AE Is Killer Of All......
on the gears i take it ,not on the balls !
Ae*Driver*70 is offline
Old 10-29-2010 | 11:34 AM
  #735
Correct, only on the gears.
