RC10B4.1 FT/WC
Old 11-18-2011 | 01:06 AM
  #7561
Guest
Originally Posted by Lonestar
Thanks - I agree on the 17g or so "ballast" under the rear brace but I still don't understand the stuff in the triangles. Here's a copy/paste of Cav's Vasaa setup:
"1/2 oz weight behind transmission; 1/4 oz in each rear triangle;"
It's the "in each rear triangle" that I don't get. Am I missing something?
Cheers
Paul
ok its the rear corners of the chassis, the little spots behind where the speed control goes and the reciver.
LOSIRACER77 is offline
Old 11-18-2011 | 01:10 AM
  #7562
Guest
Originally Posted by Wild Cherry
I gave the Losi big springs a try yesterday , but did not have perhaps the best combo and gave up .
My teammates were really ribbing me tonight for not keeping them on...
They still insist using them and who am I to argue bout
their faster lap times ...
So more testing for me before , or rather next week before the shop gets the correct springs weights in stock ....
i bet the guys are not ripping u as bad asmine did me when i asked u if u was a girl!!!!!!!
Old 11-18-2011 | 01:11 AM
  #7563
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
And now, something completely different
All these setup sheets with weight IN the rear arms... (i) where do they put it and (ii) I just don't get the physics of it... why in the arms rather than on the chassis, as this increases unsprung mass?
Cheers
Paul
Hopefully somebody from the ministry of Silly Walks can clear that up for you
Cheers
Paul
It's the "triangle" at the outer rearmost section of the "wings" of the chassis.
T-BirdJunkie is offline
Old 11-18-2011 | 01:16 AM
  #7564
Wild Cherry's Avatar
Tech Legend
I use the pink for a good reason , nobody likes getting beat by a pink B-4 , nobody ....
Wild Cherry is offline
Old 11-18-2011 | 01:18 AM
  #7565
Guest
we got a guy doing the same with a truggy!!!!!!!
Old 11-18-2011 | 01:20 AM
  #7566
Guest
Hey man, do u remeber the pics that associated had of putting the 1 ounce of lead in the rear of the b4-an t4??
Old 11-18-2011 | 01:26 AM
  #7567
Tech Legend
The rear ballast weight from Ae weights about a 1 1/2 oz * ....
* wrong weight, sorry suppose to be 14g
That what I use , but if I have a loose surface or dusty ?
Will remove some to help find grip....
Higher traction needs 14g..
more rear ballast weight = more rotation , corner speed & steering
Don't have picture , sorry..
Old 11-18-2011 | 01:31 AM
  #7568
Guest
The rear ballast weight from Ae weights about a 1 1/2 oz ....
Higher traction needs 1/1/2 oz..
so all i need to do is put in alittle more weight then.
Old 11-18-2011 | 03:07 AM
  #7569
-WHEELMAN-'s Avatar
Hey Cherry! Are you using any special spring cups or retainers to mount the TlR springs on your or your team mates stock B4.1 shocks? What color or rate spring are most of them liking so far?
-WHEELMAN- is offline
Old 11-18-2011 | 03:42 AM
  #7570
Lonestar's Avatar
now THAT clears it up
I thought triangle meant A-arm... damn me, non-native speaker
thanks for the help - interestingly this is where I had weight on my car already
Paul
Lonestar is offline
Old 11-18-2011 | 03:46 AM
  #7571
20 SMOKE's Avatar
hey guys i just got a tekin 10.5 motor, i saw on the motor can timmimg marks, how does tekin mark the endbell to adjust timming, cause the best i can tell its sitting between 15-18 degree of timming, i do not have a hot wire yet.
they come with 12* from the factory
20 SMOKE is offline
Old 11-18-2011 | 05:19 AM
  #7572
Matt Trimmings's Avatar
the rear ballast weight from ae weighs about .6 of an ounce.
Matt Trimmings is offline
Old 11-18-2011 | 05:25 AM
  #7573
B4power's Avatar
Originally Posted by B4power
Can anyone here tell me if the JC concepts Hi-Flow body will fit on my body even tho I have a tall ESC(Mamba Max Pro)?
The wedges on both sides of the body donnot seem to give much room for a big ESC.
Does anyone have an answer to this?
B4power is offline
Old 11-18-2011 | 05:51 AM
  #7574
Try asking on the jconcepts thread.
Old 11-18-2011 | 06:05 AM
  #7575
vfrninja's Avatar
I think the only one that works is the stock proline body. You need 35-36 mm in height. I can tell you for a fact the JC Finnisher body will not fit over a MMP.
Attached Thumbnails RC10B4.1 FT/WC-imag0101.jpg
vfrninja is offline
