RC10B4.1 FT/WC
Old 09-22-2011 | 06:24 PM
  #6061
RickSlick's Avatar
Default Shocks
I'm going to admit I'm new to this and have learned a fair amount by reading this forum, having said that.............
What is the hoopla over the V2 shocks? How do they improve the B4.1 and what effect do they have?
Also, what would be a good spring to use with these if they really are an advantage on a clay track with 2 jumps and alot of turns that are fairly smooth?
RickSlick is offline
Old 09-22-2011 | 06:55 PM
  #6062
Goodesta's Avatar
the v2 shocks are awesome!
1. no need to change oil every raceday very little dirt gets in like the old ones
2. the o-ring housing is alot better. no more stupid plastic clip to hold them in
3. alot smoother and i find the care jumps/lands better.
for springs greens in the rear, browns up front. honestly though talk to the guys at your track see the setups they run for shock settings
Goodesta is offline
Old 09-22-2011 | 06:58 PM
  #6063
idrummerboy13's Avatar
Default 8mm chassis!
so i am building my 8mm chassis or half way built. I sanded the cut and glued with super gorilla glue which is thick like a med c.a. Then i hot glued some aluminum braces in the outside and inside of the car. Tomorrow i will cut a peice of aluminum very thing high grade stuff, brace the bottem with it and glue it then cover with contact cement, Should be better than one peice i asked my dad for help this time... lol i guess that is cheating
idrummerboy13 is offline
Old 09-22-2011 | 07:37 PM
  #6064
Oso Negro's Avatar
Wow...That sounds like you are planning to add a lot of weight! I hope you aren't planning on running that in a 17.5 class!
Oso Negro is offline
Old 09-23-2011 | 03:52 AM
  #6065
Is the A block c/l holes a half a hole longer or shorter than the B block for the rear hubs thnx.
blingy is offline
Old 09-23-2011 | 04:48 AM
  #6066
Jmuck69's Avatar
Longer
Jmuck69 is offline
Old 09-23-2011 | 06:55 AM
  #6067
ovalracer1m's Avatar
hope it goes well, but why are you using so much reinforcement and hot glue. Almost all chassis done my matt or brent, or the one i did just use ca glue to join the halves then use corners of the old chassis to brace it up. These are glued in with ca glue and left or screwed in as well. If the chassis is done this way, it should be just as strong as a uncut chassis. I have put mine through its paces with 0 issues and i run on a 1/8 style track. Why the bracing at the bottom with aluminum, outside, inside, hot glue, etc? I cant see the hot glue working at all. Not trying to rip on you, just curious.
ovalracer1m is offline
Old 09-23-2011 | 08:11 AM
  #6068
Wild Cherry's Avatar
Tech Legend
Its gona break , your using the wrong glue, told everyone tire glue performs great .
Even if it did crack with use ?
Just a spot of glue again and your good to go ....
My 8m has been running for about 2 months now , no break or even a touch up required thus far .
Wild Cherry is offline
Old 09-23-2011 | 08:28 AM
  #6069
Oso Negro's Avatar
FYI: I did it your way, Wild Cherry, and I've had no problems at all. I've cased the triple at my track at least 10 times already with this chassis and it's still going strong after 5 + weeks!
Thanks for posting your method a while back on this thread!
Old 09-23-2011 | 08:39 AM
  #6070
Tech Legend
OSO . I'v already seen a few chassis with graphite braces break , use the L braces made from a old chassis . Nothing stronger , no screws as well...
Old 09-23-2011 | 11:55 AM
  #6071
yea i will pick it up but i use the gorilla to glue my tires it is just as good as c.a but i guess c.a is better for 9 bux a bottle. I only use hot glue for brace.
Old 09-23-2011 | 12:14 PM
  #6072
Matt Trimmings's Avatar
Hot Glue is not going to hold any bracing there. You really need to take the advice from the other members on this thread. They have alot more experience than you in regards to doing this.
Matt Trimmings is offline
Old 09-23-2011 | 01:00 PM
  #6073
BrentH's Avatar
Listen to these guys drummerboy. All of us are just trying to help you. Do not use gorilla glue or hot glue. It will not hold.
BrentH is offline
Old 09-23-2011 | 01:07 PM
  #6074
F18engineguy's Avatar
did the braces break or did the glued joint come loose?
F18engineguy is offline
Old 09-23-2011 | 02:29 PM
  #6075
ik ik i trust you since you sell them and make them. Epoxy is all i have right now to hold the seam together, i think its the stuff that is for plastics. would that be alright?
