RC10B4.1 FT/WC
Old 11-17-2011 | 06:54 PM
  #7546
RCmayor's Avatar
Originally Posted by Lonestar
Sorry - forgot to say thank you for this info. glad to see I ain't the only one this is happening to. If I tap it won't be 4-40 but M3, thread structure is way more resistant to traction
Cheers
Paul
440 is a little smaller than 3mm, the little nubs that key to the brace might come off if you go that route. If the little nubs stay on it will give more support to any size screw you are putting on there plus it keys the brace to the bulk head. I want to try some 2.5mm screws which should be slightly bigger than the stock 2/56 screws.
RCmayor is offline
Old 11-17-2011 | 08:04 PM
  #7547
tommy911t's Avatar
Originally Posted by Wild Cherry
quit using the K-spring in back with the new 8m
Ae green for the grip is way better...
( #3 piston hand drilled with #55 bit & 27.5W 2x.030 limiter)
still using k-spring up ft though ..
ft (yellow 35w #2 piston , 4 x.030 limiter , inside on arm & tower)
tommy
at my track ? where the k-spring thing was discovered being use by team drivers ?
Most of the fastest here are now using Losi big bore springs ..
O-Yeah !!!
I will give more info tomorrow after I do some testing for myself
Thanks for the tip.
Taking my #55 drilled pistons and green springs to the prcr tomorrow for testing...
Any news on the losi big bore spring setup?
Thanks,
-Tommy
tommy911t is offline
Old 11-17-2011 | 08:28 PM
  #7548
SoccerSting's Avatar
What are these #55 pistons that people talk about?
SoccerSting is offline
Old 11-17-2011 | 09:08 PM
  #7549
Jake S's Avatar
Taking a #3 and drilling it out with a #55 bit in the same holes. Makes the piston between the #2 and #3 closer to a #3 it seems tho
Jake S is offline
Old 11-17-2011 | 09:33 PM
  #7550
Old 11-17-2011 | 10:13 PM
  #7551
Guest
Default motor
hey guys i just got a tekin 10.5 motor, i saw on the motor can timmimg marks, how does tekin mark the endbell to adjust timming, cause the best i can tell its sitting between 15-18 degree of timming, i do not have a hot wire yet.
LOSIRACER77 is offline
Old 11-17-2011 | 10:34 PM
  #7552
Guest
can anyone help
Old 11-17-2011 | 11:18 PM
  #7553
jirish617's Avatar
there is just a notch on the plastic, and all you do is line that up with whatever defree of timing you prefer.
jirish617 is offline
Old 11-17-2011 | 11:52 PM
  #7554
Guest
cool, i was not sure, this is my first 1/10 system and buggy in 10 years
Old 11-18-2011 | 12:07 AM
  #7555
Lonestar's Avatar
Originally Posted by T-BirdJunkie
But there's still a pin driving the hex...soo...not sure how this translates into more durable? Maybe somebody can explain?
no one can
I agree with the tuning potential of hexes... then again 80% of the people I see at the tracks I run at can't run a lap without crashing the car or missing 5 apexes in a row... most AE shocks I've seen aren't filled and/or maintained properly ("what? you mean I have to put oil and change o-rings in this thing on a regular basis? Are you crazy??")... a lot of racers still tighten the shock mounts like if there was no tomorrow, hence binding the whole suspension... so many people can't glue tires on rims right to save their lives... so, yes, tuning track width to the mm to get more or less grip on one end of the car is great, but this certainly wasn't a priority for most. Hexes certainly don't hurt as long as you can afford them as well as changing all your stock of wheels at once, but there are soooooo many things to do before that! My candid take on this is that it's 99% marketing, 1% performance/reliability
Paul
Lonestar is offline
Old 11-18-2011 | 12:10 AM
  #7556
Lonestar's Avatar
And now, something completely different
All these setup sheets with weight IN the rear arms... (i) where do they put it and (ii) I just don't get the physics of it... why in the arms rather than on the chassis, as this increases unsprung mass?
Cheers
Paul
Lonestar is offline
Old 11-18-2011 | 12:17 AM
  #7557
Lonestar's Avatar
I actually worked on this yesterday evening as I'm installing a +8 chassis on my ride... M3 is going to be a super super tight fit and hard to tap. The little nibs will shatter... 4-40 is pretty darn close. Neither screw heads fit in the recess in the alum brace though and I didn't feel like re-boring it so I used 2.5mm screws in a new bulkhead and the old-school carbon brace (which I was told provides more front bite... then again, like the hexes, I doubt am skilled enough to feel it)
Paul
Lonestar is offline
Old 11-18-2011 | 12:25 AM
  #7558
Guest
Cheers
Paul
the weight is in the rear, in front of the diff. u take 4 pieces of lead and stick it under the #9564= breace. i took 2 pieces and glued together and put the other 2 pieces, use double sided tape to side, 1 on each side, u might have to cut the lead a bit to fit. i will get pics later this sunday.
Someone on here might have pics of this. i try to find it on the team site,
Old 11-18-2011 | 12:58 AM
  #7559
Lonestar's Avatar
Thanks - I agree on the 17g or so "ballast" under the rear brace but I still don't understand the stuff in the triangles. Here's a copy/paste of Cav's Vasaa setup:
"1/2 oz weight behind transmission; 1/4 oz in each rear triangle;"
It's the "in each rear triangle" that I don't get. Am I missing something?
Cheers
Paul
Lonestar is offline
Old 11-18-2011 | 01:01 AM
  #7560
Wild Cherry's Avatar
Tech Legend
Originally Posted by tommy911t
Thanks for the tip.
Thanks,
-Tommy
I gave the Losi big springs a try yesterday , but did not have perhaps the best combo and gave up .
My teammates were really ribbing me tonight for not keeping them on...
They still insist using them and who am I to argue bout
their faster lap times ...
So more testing for me before , or rather next week before the shop gets the correct springs weights in stock ....
Wild Cherry is offline
