RC10B4.1 FT/WC
Old 10-10-2012 | 06:38 AM
  #21946
Wildcat1971's Avatar
I like the idea of swapping left and right, might try that tonight.
Wildcat1971 is offline
Old 10-10-2012 | 06:41 AM
  #21947
Originally Posted by associatevalley
Here's a few install pics. My theory was shaving parts is bad and changing geometry is bad so I'm going to do a little of each as to not do to much of one. I'm happy with results. Will most likely be going to lunsford quick tune shock mounts as I'm really not liking the metal on metal action. What pivot ball would be suggested for these?!
do you race that car? it is too clean, like new clean.
Old 10-10-2012 | 06:43 AM
  #21948
I wanted to have everything custom anodized, prolly would have been cheaper!!! But I actually bought everything from at least 10 different places around the world. For example the new big bore spring collars are tresrey, designed for a Durango 410. A lot of custom fitting. The things I could not find red I stripped the blue off of with "greased lightning" cleaner and polished for a chrome look. The wing mmounts were very easy, just grind the body clip bump off flush, drill a small hole then thread a 4-40 screw in. On the underside of wing mount I CA glued a plastic nut to add more meat for the screw to thread into. There is a close up picture of it prolly about 100 pages back in this thread.
associatevalley is offline
Old 10-10-2012 | 06:46 AM
  #21949
3srcracing's Avatar
What bearings would be good to replace and there is only 2 of them? I need to spend $2 more to get the free shipping on Avids site.
3srcracing is offline
Old 10-10-2012 | 06:47 AM
  #21950
Matt Trimmings's Avatar
Just get some extra rear hub bearings
Matt Trimmings is offline
Old 10-10-2012 | 06:48 AM
  #21951
Default no shelf queen!
I race her every week. Although it looks completely modified, my number one priority was to not change any geometry or handling of it.
Old 10-10-2012 | 06:53 AM
  #21952
Default tresrey
Originally Posted by Jmuck69
Are those Tresrey spring adjusters?
Yes they are, and now would be a good time to thanks TSR Products for top notch customer service. They sent me a plastic version of the spring adjuster no charge to see if it would fit before I spent the money on aluminum. Check them out!
Old 10-10-2012 | 06:57 AM
  #21953
Jmuck69's Avatar
I was thinking of using the TD black metal ones instead of the blue AE's
Jmuck69 is offline
Old 10-10-2012 | 07:08 AM
  #21954
Default collars
Those should work also, FYI, the shock cartridge caps do not fit.
Old 10-10-2012 | 07:21 AM
  #21955
YankeeFan123's Avatar
Originally Posted by Tradin Paint
You overlooked the guys question. He is asking how it will effect the handling if he mounts the C tower on the other side of the hub.
Yes is what I was asking about, and so I will try it and hope that it doesn't pop many turnbuckles
YankeeFan123 is offline
Old 10-10-2012 | 07:48 AM
  #21956
I posted yesterday that I was losing power about 5 laps in. This morning i was thinking about it and it occurred to me it could be the slipper heating up. My pad were pretty glazed, I tried to sand them, but the glazed up right away again. If the slipper heats up with glazed pads, would it make the buggy feel like power disappeared?
Old 10-10-2012 | 07:49 AM
  #21957
It could be slipping excessively, you would be able to feel/hear it though.
Old 10-10-2012 | 07:56 AM
  #21958
I kept tightening it down. I have about 4-5mm of thread showing right now. I heard a sound from the car, didnt really sound like a slipper squeel. I thought maybe the tires were slipping as they were running the track pretty damp (CH). Either way my pads are pretty shiny. The triads are out of stock and there is no eta. They said they are out of the pads to make the kits. I might pick up new pads and try the vts again. same crappy pad, but more surface area. We thinking garodiscs, but I am reading that people are tightening them all the way down and backing off 1 turn. Sounds like those pads are pretty slick and I am unsure of how tunable they are.
Old 10-10-2012 | 08:08 AM
  #21959
Matt Ward's Avatar
This is a pic of the c hub on the opposite side. This seems to be the best way to mount the turnbuckles. I tried switching the r/l 0* hubs but did not like them.
Attached Thumbnails RC10B4.1 FT/WC-img_20121010_105822_520.jpg
Matt Ward is offline
  #21960
bilster44's Avatar
Because it feels like crap?
Don't know what to tell ya. Good luck with all that.
bilster44 is offline
