RC10B4.1 FT/WC
Old 09-04-2012 | 09:42 PM
  #19906
Originally Posted by ilanstylz
So if I lower the end bell timing on my revtech and gear it say at 32/72 or 75 I will get more torque then with it set at end bell max timing geared at 35/75 correct?
Yes the motor giving torque feels much better to me at least on the track! Just have to try things out for yourself to see what you like!
bigdog is offline
  #19907
OptimumRC's Avatar
Originally Posted by uncle everett
Maybe I missed it when I visited Cali this summer, what was it about these facilities that puts them above others?
-Stacked hobby shops
-Large very well maintained tracks in very nice facilities
-Top notch pit areas with designated tire washing sinks.
-42" flat screens ALL over the place
-Snack bars
-Excellent people, particularly industry reps and factory drivers on any given race night.
-taco trucks!
You really just have to go to one of these places to truly appreciate it.
OptimumRC is offline
Old 09-04-2012 | 09:54 PM
  #19908
STLNLST's Avatar
you should have a little more torque at that gearing anyway without turning the timing down as your FDR is different. Depending on where your motor timing is now you might loose a bit of power across the board,
STLNLST is offline
Old 09-05-2012 | 04:34 AM
  #19909
Default That's why
I did. I guess the real pull back to these facilities would be the competition.
uncle everett is offline
Old 09-05-2012 | 07:08 AM
  #19910
anyone know when it is big bore shock and spring are available yet ?
taztal3 is offline
Old 09-05-2012 | 07:18 AM
  #19911
Eli's Avatar
Eli
This has been the question of the last few months. We have been told in a few weeks well over a few weeks ago. Associated did release a picture saying they will be here soon but how soon. My guess no more then two weeks but who knows.
Eli is offline
Old 09-05-2012 | 07:27 AM
  #19912
ryanpatrickgore's Avatar
couple of weeks.. haha
ok you got us with the tire washing sinks and the taco trucks
ryanpatrickgore is offline
Old 09-05-2012 | 07:32 AM
  #19913
where are picture of big bore shock and spring ?
taztal3 is offline
Old 09-05-2012 | 07:40 AM
  #19914
Eli's Avatar
Eli
They posted it on facebook less then a week ago.
Eli is offline
Old 09-05-2012 | 08:37 AM
  #19915
skengines's Avatar
Originally Posted by mxracer458
Wcrc is where the reedy race is being held for the 3rd year in a row,traction is off the hook without any tire wear,trust me these tracks as well as sdrc are top notch
I couldn't agree more. I moved from Southern California to Las Vegas, Nevada and the tracks are really day and night. WCRC is double, maybe triple the size of the track I currently race at and also has significantly more traction.
skengines is offline
Old 09-05-2012 | 03:28 PM
  #19916
3srcracing's Avatar
So I am trying that anodizing thing and it's not working. I got one to work but now they are just going in the same color they came out (dark gray) any idea what I am doing wrong?
I have the negative wire on the turnbuckle positive in the simple green (no dolited). I have it for I have 81Volts to get the shiny gold. I even checked it with the volt meter to make sure its 81 volts and it is. I wrap it on the tip of the turnbuckle put it in right before the wire touches leave until bubbles stop or 35 seconds. And then pull out, but nothing happens?
What am I doing wrong?
3srcracing is offline
Old 09-05-2012 | 03:53 PM
  #19917
B.A. Racer's Avatar
try to switch the wires...put the negative in the simple green..and do not let the wire touch the simple green
B.A. Racer is offline
Old 09-05-2012 | 04:21 PM
  #19918
3srcracing's Avatar
Intresting, I left it in for like 5minutes. It turned blue?
http://www.valhallaarms.com/wyvern/t...olor_large.jpg
I guess I need more voltage?>
Old 09-05-2012 | 04:56 PM
  #19919
Wildcat1971's Avatar
ok, for those switching to hex up front, I found some low profile 8/32 lock nuts at ace for 20 cents each. Here is a pic. the one on the right was from ace.
By lhelmrich at 2012-09-05
Wildcat1971 is offline
Old 09-05-2012 | 05:20 PM
  #19920
TJMac's Avatar
McMaster Carr or GTFO.
j/k
TJMac is offline
