RC10B4.1 FT/WC
Old 08-12-2012 | 10:24 PM
  #18436
Originally Posted by johnny ray
Hey all just pulled the trigger on a ft b4.1 wc I went with the losi red springs front and white rear shaved u brace and cf hubs. Gonna run a full size stick pack 4000 mah Hyperion. Just looking for any tips on weights and placement. Going to run 17.5 blinky. Thanks in advance.
Full sized pack with red and white? May be a little soft for a full pack depending on the pack. Plus weight? Springs will be too soft imo. Might want to have some orange and yellow on hand just in case.
zipperfoot is offline
Old 08-12-2012 | 10:27 PM
  #18437
jf+'s Avatar
jf+
Originally Posted by Wild Cherry
using 1mm shims instead of the .030 on the hubs & caster .
also
RPM ball cups
AVID Steering
nothing else cept clean
Cherry. Dude.
0.030in = 0.762mm. The average mustache hair is 0.25mm.
You really thought it necessary to point out that you use a 1mm shim vs. a 0.762mm one?
jf+ is offline
Old 08-12-2012 | 10:28 PM
  #18438
jf+'s Avatar
jf+
Originally Posted by B.A. Racer
you should not be shimming worn items...if they are worn, replace them
These items are not worn.
jf+ is offline
Old 08-12-2012 | 10:32 PM
  #18439
Odin544's Avatar
Originally Posted by jf+
Cherry. Dude.
like you feel the need to point out the difference between the two...
Odin544 is offline
Old 08-12-2012 | 10:34 PM
  #18440
Originally Posted by Gitsum
All you guys shimming the heck out of your cars will be back complaining of a twitchy car.
Agreed. Same thing with bearings. For most applications abec 3 or 5 are the most common. Abec 7 have the least play and stricter tolerances, but cause too much friction and resistance. With abec 7 bearings you woud have no slop at all in your bearings, but they would have too much rolling resistance. Sometimes a little play is a good thing, and there for a reason for that.
Reducing some play for onroad maybe... But off road? The car is already bouncing about in the dirt, clay or carpet. Is taking out .030 of slop really needed?
Old 08-12-2012 | 10:42 PM
  #18441
Suspended
Yes
PFKAOG is offline
Old 08-12-2012 | 10:43 PM
  #18442
3srcracing's Avatar
Anyone see something interesting with this b4.1?
http://sphotos-a.xx.fbcdn.net/hphoto...33300153_n.jpg
Found out why fast:
"You're not crazy, Ty did that himself. He chopped off the sides, did some dremel work, and re-epoxied the sides to the narrowed chassis. Pretty slick if you ask me. He could possibly be running a proline 22 body on there, as well, to compensate for the narrower profile."
3srcracing is offline
Old 08-12-2012 | 10:45 PM
  #18443
CHIZZLE's Avatar
more time driving, less time shimming
CHIZZLE is offline
Old 08-12-2012 | 10:47 PM
  #18444
Wild Cherry's Avatar
Tech Legend
Cherry. Dude.
Pointing out the blue 1mm washers for those who would like a better fit ,
even included in the WC kits ...
#31286
Wild Cherry is offline
Old 08-12-2012 | 10:50 PM
  #18445
Odin544's Avatar
Found out why fast:
He's been running that for quite a while now. About 7 months now. http://vimeo.com/36154887
Odin544 is offline
Old 08-12-2012 | 10:52 PM
  #18446
gamedog1966's Avatar
Originally Posted by Odin544
B4.1 thread.
my bad guys my mind went straight to the sc10 sorry guys for giving the incorrect tech for the buggy
gamedog1966 is offline
Old 08-12-2012 | 11:06 PM
  #18447
RC*PHREAK's Avatar
Found out why fast:
cute, but i don't think it improves anything...
RC*PHREAK is offline
Old 08-12-2012 | 11:53 PM
  #18448
OptimumRC's Avatar
Found out why fast:
Yeah, it is great that he hacked off a lot of the structural integrety of the car, only to re-epoxy some side on for looks. On top of that, it's a truck chassis.
It is definitely not magic....
OptimumRC is offline
Old 08-13-2012 | 05:54 AM
  #18449
I'm a "newbie" and have a question. I'm heading to the track this weekend for the first time and got everything packed away nicely in my rolling tool box. How do you guy's transport your cars? Everything fit in my tool box but the car.
mrjbrown51 is offline
Old 08-13-2012 | 05:56 AM
  #18450
Box in one hand car in the other.....have a nice day.
Gitsum is offline
