SC10 Thread
Old 10-05-2011 | 11:19 AM
  #7411
1Fastpede's Avatar
Who sells an aluminum wheel hex for the RS? I know jconcepts sells the rears but I'm looking for all 4 (frt and rears) no-one sells them together?
1Fastpede is offline
Old 10-05-2011 | 11:22 AM
  #7412
thebbbrain's Avatar
Since RS so new they are still under development. I read in the JConcepts thread they are going to release some for the frontends of SC10s using RS parts.
thebbbrain is offline
Old 10-05-2011 | 11:37 AM
  #7413
Asharus's Avatar
I saw the new blue front JC hexes at the JC 2011 Fall Indoor Nats this weekend. Jason Ruona had them on his SC10. It should be out soon.
Asharus is offline
Old 10-05-2011 | 11:38 AM
  #7414
1Fastpede's Avatar
thanks guys!
Old 10-05-2011 | 07:25 PM
  #7415
TeamNuts's Avatar
JConcepts part number 2081. Enjoy.
TeamNuts is offline
Old 10-06-2011 | 06:39 AM
  #7416
Picked up a FTSC10 yesterday to run on shortcourse nights at the local track. I've built several kits and pay close attention to the details but I've ran into a issue I just can't figure out. When bolting the transmission case halves together the 3 1" long screws which pass through it which thread to the motor mount plate don't seem to be long enough? With the washers over them I can barely get a thread in the motor mount plate and by taking them off I'm still not flush with the blue plate? Tranny spins free and I can't see a gap or anything which leads me to believe nothing is installed incorrectly. Any help on this would be great. Thanks
WideOpenThrottle RC is offline
Old 10-06-2011 | 06:54 AM
  #7417
Use thread locker to keep them from backing out.
Murray100 is offline
Old 10-06-2011 | 07:10 AM
  #7418
The Joker's Avatar
Are u totally sure ur using the right screws in the right places?! There are (3) longer screws that go threw the tranny & into the motor plate... Check that the tranny screws are the correct measurements. (1) 4-40x1/2... (3) 4-40x1... & (3) .030 - Ballstud Washers used on the (3) 4-40x1 screws with blue loctite.. http://aedownloads.com/downloads/man...rtr_manual.pdf
The Joker is offline
Old 10-06-2011 | 07:12 AM
  #7419
kc_nitro_rc's Avatar
Mine was the same. I had to leave out one of the washers so the screw would make it two or three threads into the plate. Thinking of buying 1-1/8" screws.
kc_nitro_rc is offline
Old 10-06-2011 | 09:25 AM
  #7420
RCW
Both my b4.1 and SC10 had screws that were too short. I bought longer ones and cut them to fit.
RCW is offline
Old 10-06-2011 | 10:18 AM
  #7421
Yes I quadruple measured , must have gotten the one's made on a friday, I'll just have to get some a little longer and cut to fit...
Old 10-06-2011 | 10:23 AM
  #7422
They seem short but work fine with a drop of locktite to hold them. Thought the same thing 20 + years ago.
bentgear is offline
Old 10-06-2011 | 10:25 AM
  #7423
Wild Cherry's Avatar
Tech Legend
You must of cut them same size if they fit ....
Wild Cherry is offline
Old 10-06-2011 | 01:14 PM
  #7424
If you can get a few threads of the screw into the threads on the aluminum plate. That was my problem. Two of the three 1" screws barely made it in enough for loctite to do its job. The third one wouldn't reach without leaving the washer off.
Most likely it's a plastic mold slightly out of tolerance. Someday I'll buy a new pair of case halves and see if it fits better.
Old 10-06-2011 | 01:23 PM
  #7425
Matt Trimmings's Avatar
I think the issue is that back in the day the washer was a thin servo washer and now it is the thicker ball stud washer. It still works but i would use the thinner washer for some self assurance along with the lock tite.
Matt Trimmings is offline
