SC10 Thread
Old 01-11-2011 | 10:21 PM
  #5371
UK.hardcore's Avatar
AKA 17mm adapters any good?
UK.hardcore is offline
Old 01-12-2011 | 11:35 PM
  #5372
bzb
how much toe in/out are you guys running in front?
bzb is offline
Old 01-13-2011 | 12:23 AM
  #5373
andrew-01's Avatar
I think that more or less relies on how you want the truck to feel. Typically 0 to -1 is what I've seen.
andrew-01 is offline
Old 01-13-2011 | 02:31 AM
  #5374
ShortCourseOnly's Avatar
Originally Posted by DRRC
I also converted my FT T4 to a SC10 and the rear t plate does not fit the sc10, you have to use the FT rear T plate
the front shocks are longer in the T4 so a spacer can be used inside the shock to limit travel
front shock tower dont have the holes for the bumper, can be fixed by getting rpm bumper
rear shock tower is a good fit, just make holes for the body mount to screw into
converting to sc10 buying new parts would cost about $80-100 for chassis, battery holder, body mounts, side nurf bars, body
it might be cheaper to buy a used sc10 and use the other parts for spares
DRRC, I did mention the shock towers.
I used the T4 T-plate with the T4 transmission. So if you do not convert to the SC10 transmission you are OK. The difference between the T4 and the SC10 trans is the diff bearings and the case as it fits to the T-plate.
I disagree that the front shocks are longer on the T4. The part number is the same between the RTR kits and the 1.02" length is the same. I use 6 limiter thin spacers.
There are many ways to make your T4 fit the SC10 classification. Krio mentioned to me that he started with a T4 FT and purchased the original SC10 kit and built a SC10 FT from two kits. He then built a T4 with the remaining parts and sold it for nearly the price of the original SC10 kit so this was the most cost effective way to get a SC10 FT before the kit came out. If you have a T4 FT and want to convert it then it might be best to follow what Krio did.
ShortCourseOnly is offline
Old 01-13-2011 | 03:25 AM
  #5375
Registered User
I had those but they were loose on hex by feeling shaking wheels. The 4 rear slash wheels are tighter on hex, put HPI blitz front axle w/parts to make slash wheels to fit on front.
RustyRC is offline
Old 01-13-2011 | 05:19 AM
  #5376
Cameron Kellogg's Avatar
I run them with DE Racing wheels. The AKA ones are nice but the front uses a very small bearing on the outside. On the high bite tracks I go through a bearing every so often. The bearing is really to small in my opinion. I am going to machine out the hub to accept a normal bearing like the other brands that are out do. I use a very small dot of super glue on the bearings to help hold them in the hub also to reduce the slop between the bearing and the hub.
Don't get me wrong though I do like them.
Cameron Kellogg is offline
Old 01-13-2011 | 08:03 AM
  #5377
I think i'll get the Pro-line front end when its out together with the rear hex set.
Just ordered my FT kit. hope he gets along with my FT T4.1.
Old 01-16-2011 | 03:28 PM
  #5378
I just bought an SC10 FT and I'm looking for a suggestion on what gearing to run at our local track. This is an old design of the course but comparable to that it is today. Thanks
http://www.youtube.com/watch?v=bh3WeNNqSc8
Running Castle SCT combo
Venom 5000mah 2S Lipo
dalesum is offline
Old 01-17-2011 | 06:49 AM
  #5379
nightc's Avatar
Hi,
Anyone know if I can use RPM 3.5mm ball cups on SC10 rear camber turnbuckle (the one that's 71mm length)? My standard ball cups pops out once in a while.
nightc is offline
  #5380
nightc's Avatar
Any possibility to install 1/8th motor in SC10? If yes, what's the modification like?
nightc is offline
Old 01-17-2011 | 07:04 AM
  #5381
bzb
after how many runs you guys rebuild the ball-diff (ft)
bzb is offline
Old 01-17-2011 | 07:46 AM
  #5382
offtraxx's Avatar
Originally Posted by nightc
Hi,
yes they fit but u want the short ones. rpm ball cups come in 2 lengths, short and long. longs work but may require trimming wich is a pain to get straight.
1/8th motor in a sc10? why? it may fit with a good chance of destroying ur tranny. if u want insane speed and plent of broken parts, just go with a 3.5 or something
offtraxx is offline
Old 01-17-2011 | 11:00 AM
  #5383
Sprinkler's Avatar
I am finishing up the build on my SC10. While putting the rear end on with the CVD's and rear hubs I noticed that the left side out drive does not have much room for the CVD end to slide in. The white plastic t-nut that the diff screw goes into is taking up a lot of room inside that outdrive.
Is that normal?
Sprinkler is offline
Old 01-17-2011 | 11:05 AM
  #5384
grod22's Avatar
The T nut should suck in there and sit bottomed out in the outdrive slot leaving the proper room needed....something sounds goofy man.
gr
grod22 is offline
Old 01-17-2011 | 11:18 AM
  #5385
???E-Racer's Avatar
I have an older B4 Tranny and want to use it on the SC10.
So should it bolt right up? Or would I need anything extra?
I would just prefer to use a Ball diff on carpet.
???E-Racer is offline
