SC10 Thread
Old 08-14-2011 | 09:48 AM
  #6871
CraigMBA's Avatar
Originally Posted by 20 SMOKE
you asked if i forgot to put the pin back in,i said no.i moved on from the hex nuts and got the proline.and the wheels are j concepts
Then I'm even more confused why they turned. But I thank you for answering the question.
CraigMBA is offline
Old 08-14-2011 | 11:01 AM
  #6872
Registered User
Originally Posted by CraigMBA
No what? You put the roll pins in but it turned anyway? You realize you need different wheels right? Because there is little chance of turning a 12mm hex unless you have a wheel nut come loose....
I write this because mine work fine and I was trying to mine some useful data why you weren't successful using this product. I'm sincerely not trolling you.
Ryno:
Here is the link to the proper nylocks from AE:
http://www.teamassociated.com/parts/details/3438/
Nice, I think those will work and they look good. Just ordered 2 packs from A Main
Ryno B4.1 is offline
Old 08-14-2011 | 11:18 AM
  #6873
20 SMOKE's Avatar
you now they are clamp style the only thing is i think the gap where it clamps was to much so when it closes the 12mm is more in the 11.xx mm and it spun while tightening down
20 SMOKE is offline
Old 08-14-2011 | 04:52 PM
  #6874
bds81175's Avatar
Moderator
Originally Posted by Asharus
you can always use serrated nuts instead of nylon locknuts. i use those on my SCTE.
Ouch! Serrations on your nuts hurts!
bds81175 is offline
Old 08-14-2011 | 07:03 PM
  #6875
Roo3's Avatar
Im thinking about getting an sc10 and i was directed to this forum and 400 pages is way to much to read so im just gonna start following along now
Roo3 is offline
Old 08-14-2011 | 07:06 PM
  #6876
mxracer458's Avatar
ok guys quick question,sat was my 2nd time out with the truck,im coming from stadium truck,where you run it alittle on the stiffer side,where on the sc10 when i run it on the stiffer side it seems to handle the jumps nice but i loose the tight steering it has,do these trucks like to be run alittle on the softer side?i was running blue/sliver springs its on rails but when i got back to grey/red seems like i really have to check up on the throttle and be easy going into some tight corners,the track has some good size cross overs.just curious for some imput
mxracer458 is offline
Old 08-14-2011 | 07:17 PM
  #6877
20 SMOKE's Avatar
did you try moving shock location
20 SMOKE is offline
Old 08-14-2011 | 07:32 PM
  #6878
mxracer458's Avatar
ya i actually have the 4th hole drilled on the shock tower,i was running inside of arm and 4th hole on tower,might move it to 3rd hole on tower and outside hole on arm since that was my t4 set up and it was good,most of the fast guys are running blue/silver with #2 pistons all around,i think im going to go back to that and maybe add a few more limiters in the shocks as well. i believe im 3 in front and 2 in rear,maybe go 4/5 on limiters to limit the rear down travel.I think its me just not being used to how these drive to how you set them up!
Old 08-14-2011 | 08:53 PM
  #6879
stalnakerracing's Avatar
running on carpet whats tire set up should i use i have
barcodes
double dees
subcultures
where should i put them front or rear thanks in advance
stalnakerracing is offline
Old 08-14-2011 | 09:18 PM
  #6880
CraigMBA's Avatar
Warning - slight brag. I picked up a SC10 roller with a bunch of factory upgrades for a smokin deal about a week ago so I could run a second class. Used my four year old 4 cell GTB with a heatsink installed, and an four year old velocitiy 17.5. Added a factory team battery hold down, changed the orings and the bleeder caps, copied some setup off of the AE site where they were using tires like I think work at my local track (Maifields nats setup from last year I think), and followed it exactly.
Won both qualifiers by a lap each over the second place guy.
Won the main by about a lap.
I had to adjust the slipper and diff at the track, and check ride height and cross weight, clean tires, and that was about it. My 4w is like 2 seconds a lap faster but itsn't as easy to drive. But fun to drive when your ish works like that.
Before:
After:
It's not perfect but it's racy. And it doesn't require me beating myself to death to run two classes. I get to run two ten minute mains and four seven mute qualifiers. Winning!
CraigMBA is offline
Old 08-14-2011 | 09:24 PM
  #6881
Asharus's Avatar
Grats dude. Now try running 3 cars on a race day. You barely have enough time to take a bathroom break.
Asharus is offline
Old 08-14-2011 | 11:12 PM
  #6882
BLbound's Avatar
I just started building my sc10ft & noticed my front a-arms are a little tight on the hinge pin. Should I use a drill to ream it a bit? Any suggestions? Thank you!
BLbound is offline
Old 08-15-2011 | 12:46 AM
  #6883
Lojik's Avatar
yes you should, you want them to be free moving but with no slop. here is a vid to help.
+ YouTube Video
Lojik is offline
Old 08-15-2011 | 01:02 AM
  #6884
BLbound's Avatar
+ YouTube Video
Thanks for the vid! The bummer part is I'm on an ipad2, the YouTube vid won't work . I will wait to see it when I hop on my pc, thanks!
BLbound is offline
Old 08-15-2011 | 04:25 AM
  #6885
offtraxx's Avatar
barcodes
double dees
subcultures
I have run carpet for a few winters and none of them would be my first choice. try what u have tho.
hpi blitze D compound rear
stock ae or kyosho front
the small pins u have will fill up with carpet fuzz and be like running on glass.
offtraxx is offline
