SC10 Thread
#6858
Ordered my hex parts directly from Team Associated. Got everything in yesterday and installed today. Make sure you have the 440 aluminum lock nuts that the ball studs screw into, it was the only thing that wasn't included with the parts I ordered.
#6863
Interesting. I use Jconcepts wheels, which I think are thinner. They used to make half height nylocks, which would also work.
I bought the Proline front end because I was in a hurry (I wanted to race this weekend, and it's a brand new to me truck, since I didn't have any tires I wanted to use the same tires I have for my SC4x4) and I figured WTH? Mine has no slop. The PL aluminum hexes are the same size as the Jconcepts ones.
Maybe I got lucky.
Maybe I got lucky.
#6866
No what? You put the roll pins in but it turned anyway? You realize you need different wheels right? Because there is little chance of turning a 12mm hex unless you have a wheel nut come loose....
I write this because mine work fine and I was trying to mine some useful data why you weren't successful using this product. I'm sincerely not trolling you.
Ryno:
Here is the link to the proper nylocks from AE:
http://www.teamassociated.com/parts/details/3438/
Ryno:
#6868
I just installed a proline hex kit that I've had sitting in the box. Fit is tight and perfect, front and rear. I did add a second 3/16" shim to the front just to tighten it up a little, no issues. I also added some 4-40x1/8" setscrews to the front hubs to hold them onto the axles. I'll have access to a set of the AE wheels soon, and I'll check the fit, but I have no problems with the Proline wheels.
#6869
