SC10 Thread
Old 10-24-2011 | 06:48 PM
  #7621
HighLife420's Avatar
Anyone got any Silver rear springs that they want to sell or trade? I went to 4 hobby shops today and not 1 of them had the rear silver.
I can trade if you need, let me know which color you want.
HighLife420 is offline
Old 10-24-2011 | 06:50 PM
  #7622
Thanks for sharing that pic of the new chassis and springs....would be great to eliminate that little issue whether it hurts performance or not.
Quickstang is offline
Old 10-24-2011 | 06:57 PM
  #7623
monty c's Avatar
From: Dont get any more northwest than me..........
Originally Posted by monty c
whats the best setup for a tight high bite clay indoor?? i am currently running the Maifield national setup. it was great outdoors but this weekend was the first indoor race. it drove nice but seemed like it had alot of bounce on the landing of jumps. not sure if i am bottoming out and bouncing or its to stiff and bouncing.
what setup is everyone running indoors??
anyone?? geez, if this was a Losi thread i would have 2 or 3 different team drivers helping me by now, where is all the Associated team drivers to help a guy with set ups??
monty c is offline
Old 10-24-2011 | 07:18 PM
  #7624
20 SMOKE's Avatar
i race out doors so cant help
20 SMOKE is offline
Old 10-25-2011 | 05:32 AM
  #7625
Oso Negro's Avatar
Smile
I'm not an AE sponsored driver but I'd be happy to help, in any case.
I generally advocate coming to your own unique setup using the method that is advocated on The "Tune with Camber Links" thread.
http://www.rctech.net/forum/electric...ber-links.html
If you want a solid baseline setup for indoor clay you can start with this...
http://www.teamassociated.com/pdf/ca..._ocrc_2010.pdf
A lot of people use this with great success.
Send me a PM if you would like more detailed information about indoor clay setups for the SC10.
Oso Negro is offline
Old 10-25-2011 | 06:33 AM
  #7626
Registered User
You probably didn't get people jumping up and down to respond because similar questions are asked and answered several times a week on this thread. Please read the old posts and you will have more set up information than you know what to do with.
Ryno B4.1 is offline
Old 10-25-2011 | 06:41 AM
  #7627
Oso Negro's Avatar
that is very true!
Old 10-25-2011 | 06:52 AM
  #7628
Asharus's Avatar
I use the 2010 Maifield Roar Nats setup on every track I've been to and the only thing I change are the tires. It's an excellent setup. I did make a few changes though. 32.5wt all around and using the C hole on the rear hub with 2 washers underneath the ballstud on the u brace. I use this setup on both my 17.5 and 10.5 SC10s.
Asharus is offline
Old 10-25-2011 | 07:09 AM
  #7629
Oso Negro's Avatar
That is great setup too! It isn't especially different from the Cavalieri setup though. Shock oil being the biggest difference
Old 10-25-2011 | 09:23 AM
  #7630
Jr mitch setup works great. Except we use blue front springs and the rear c hubs
nitro0619 is offline
Old 10-25-2011 | 09:43 AM
  #7631
wrathfull's Avatar
Hey Monty, a few weeks ago i was asking for help with setting up my sc10 for racing at mikes, well OSO Negro has helped me tremendously. I do think thats why my truck was setup so well on saturday. He runs on a track quite similar to the one at mikes and gave me his setup, as you seen it worked great for me. 1st place in novice for only my second day racing. I agree some of it is skill(years of playing with rc vehicles) but alot had to do with the setup I honestly believe. So thank you OSO, without the help I would not be moving up to Stock, can't wait for Nov. 5th, Ill be there on saturday to practice, cheers
wrathfull is offline
Old 10-25-2011 | 11:52 AM
  #7632
gamedog1966's Avatar
Default sc 10 gearing
what gearing should i use if im running indoor clay. my truck is seeming to be at like 160 after mayb 15- 20 min run at the track.
gamedog1966 is offline
Old 10-25-2011 | 12:13 PM
  #7633
Asharus's Avatar
you shouldnt be temping after 15-20 mins. you should be temping for the length of your heat/main
for example, if you run 6 min mains, i would gear to be at about 160 after 6 mins
Asharus is offline
Old 10-25-2011 | 01:16 PM
  #7634
CraigMBA's Avatar
The library of setups for this truck is big enough, and the truck is sorted well enough, that they can spend their time doing other development work - like on the SC10 4x4 which is neither sorted nor has a large library of setups.
What I suggest is figure out what tires the fastest guys run at your track, and then find setups on AE's website or PetitRC that use those same tires. Using this stragety, I was able to win every heat and main my first day out at my local track straight off the trailer, making not a single change from the time I unloaded to the time I went home other than charging the battery. I think I might of turned the brake EPA down two laps into my first practice, but technically that is the transmitter.
Here is what I use. I run slightly lighter shock oil because its cooler now than the middle of the summer when this setup was done.
My truck remains fast and easy to drive with 'about' the same setup indoor and outdoor, changing only to the proper tires/compounds for the conditions.
Here is most of the setup library:
http://www.petitrc.com/setup/associa...iatedSC10.html
My 4x is just a nightmare to drive compared to my 2w, the 4w is downright evil. and it's all setup. My 2w is just a pleasure to drive. The 4w is getting better.
CraigMBA is offline
Old 10-25-2011 | 01:29 PM
  #7635
Pulse_'s Avatar
Hello, can you tell me what are the spares I will need for a SC10 FT?
I will use it for racing & bashing
Pulse_ is offline
