SC10 Thread
Old 10-31-2011 | 01:34 PM
  #7771
???E-Racer's Avatar
Originally Posted by Lansonfloyd
IDK, I noticed that people break a lot of arms at the track so to avoid DNF I went RPM and haven't looked back. Not sure I'd be able to tell the difference of a flexy part vs. a very rigid part when it comes to arms. I have heard good things about the steering upgrade (STRC), that seems smart since there's quite a bit of play in the stock setup. What protective bumper/chassis protector (RPM/T-Bone/custom) did you decide to go with?
I run the RPM front A-arms (gotta have GT2 Hinge pins to run them)
as well, and the RPM bumper/chassis brace.
I wouldnt have my truck any other way. It's way stronger.
The next thing I plan on doing is getting some FT turnbuckles and Blue RPM ballcups.
???E-Racer is offline
Old 10-31-2011 | 01:42 PM
  #7772
bdyche's Avatar
Originally Posted by driver5150
Besides the factory team shocks, are there any other good shocks to run on the sc10?
For a while I was running Losi XXX-T MF2 shocks with 35wt oil all the way around with 6 0.030" limiters in the front and 2 0.030" limiters in the rears (mainly to set front shock length similar to SC10 shocks while maintaining similar shock travel). They worked great, but now I'm running my XXX-T so I put them back on there. The RTR shocks can work, too, they just need to be refreshed often. I've found with 35wt oil in the RTR shocks they hardly leak at all and instead of rebuilding them between rounds I can go every other race day and still have consistent performance. The major problem I have is dirt intrusion rather than fluid leaking.
bdyche is offline
Old 10-31-2011 | 01:52 PM
  #7773
Asharus's Avatar
you can try using kyosho grooved o rings (or the trinity ones, and mcmaster carr has a 100 pack for cheap too). i use these on all 3 sets of v2s i have and they havent leaked a drop.
Asharus is offline
Old 10-31-2011 | 02:39 PM
  #7774
bdyche's Avatar
I might have to give that a shot. I haven't had any issues with the V2's on my B4.1, and next week I'm getting a FT SC10, so hopefully I can get some of those o-rings and save myself some trouble.
bdyche is offline
Old 10-31-2011 | 03:15 PM
  #7775
Oso Negro's Avatar
Anyone have that part number? I'm going to buy them. Tired of paying the Kyosho price for them.
Plus they are hard to find.
Oso Negro is offline
Old 10-31-2011 | 06:38 PM
  #7776
netmaster's Avatar
Anyone have the part numbers of what I need to put a sway bar on the front?
I see the pics, just need to know what exactly I need to order. And if its piano wire what diameter do I need?
Thanks!
netmaster is offline
Old 10-31-2011 | 06:40 PM
  #7777
So*Cal AFDude's Avatar
I run all FT equipment on mine and do not have any breakage problem. I don't hit stuff like crazy either. I think the RPM gear on the front takes away handling characteristics
So*Cal AFDude is offline
Old 10-31-2011 | 08:48 PM
  #7778
soltydog's Avatar
I recently picked up a Mamba Max ESC and a Ripper 3900kv motor that i plan to run with the the stock spur gear in my SC10. My question is....what pinion would work best for a dirt racing and some bashing? With your answer, what kinda low end/high end ranges could i expect?
Also...am i wise to forego the mabma max and ripper and rely on for strictly bashing...or will this be 'competitive'
thanks!
soltydog is offline
Old 10-31-2011 | 09:24 PM
  #7779
Wild Cherry's Avatar
Tech Legend
Thanks!
#9635 B4 & T4 sway bar kit
use black bar
also will need 2 short ball studs
Wild Cherry is offline
Old 11-01-2011 | 05:44 AM
  #7780
Sprinkler's Avatar
use black bar
Will the SC10 rear kit work for the front?
Sprinkler is offline
Old 11-01-2011 | 05:50 AM
  #7781
Sprinkler's Avatar
Nevermind it is the rear kit.
Old 11-01-2011 | 06:58 AM
  #7782
At the track I've slowly given away all my spare arms to racers in need because they've snapped theirs.
Lansonfloyd is offline
Old 11-01-2011 | 08:13 AM
  #7783
I agree
nitro0619 is offline
Old 11-01-2011 | 08:23 AM
  #7784
Asharus's Avatar
here you go
http://www.shortbusracers.com/2011/0...shock-leaking/
and I think these are the trinity o rings
http://www.trinityrc.net/shop/index....product_id=205
Asharus is offline
Old 11-01-2011 | 12:06 PM
  #7785
lewis4x4's Avatar
OK, so I know that it is in here somewhere but I can;t seem to find it through the search. Can someone help. Is there an official/un-official steps/TIPS for building the Factory Team kit? I'm about to start building one... Or, is there another thread just for that?
Thanks...
lewis4x4 is offline
