SC10 Thread
#3872
Yeah I did wonder that and did take out oil but didnt fully compress the shock shaft that way but there was very little rebound and little resistance at bottom of stroke but will give it a go that way and see if it makes any difference..thanks.
#3874
The shock oil seems fine with a 2 hole piston. What springs are you running? Try Red in front and Green in back. Front should have 2 .25 in spaces on either side. Rear should have a .5 in spacer on either side.
#3875
I got this setup from the fastest mod sct racer at the track
#3876
Use #2 piston all around with 45 in front and 40 in back. Gold sway bar in back with blue buggy Spring fronts in front shocks and silver rears in the rear shocks. Stock hard tires all around work good but stock soft tires in the back is better. Half degree hubs are nice but not needed. DiAled and stable at high speeds and good in corners. Use the rear anchorman position for the steering linkage.
#3879
My outdrives are shaking. the outside ends of them where the bone goes in are doing circles instead of staying in one place. is this normal, or is my diff messed up? it also looks as if the bones dont go into the outdrives as far as they did before.... anyone have ideas? i am going to take it apart soon but idk what to look for, this is my first rc car
my buddy that knows everything doesnt know anything about gear diffs
#3883
this is what I all have right now in my "MOD truck"
-Peak Racing Vantage Modified Single 14t Brushed Motor
-J-concepts goosebumps Tires
-Proline beadloc wheels
-Proline 1/8th scale closed cell foams
-Novak Rooster 12t Reversible w/LiPo Profiles
-Lungsford Titanium super duty Turnbuckles kit
-Lungsford Titanium front axles
-Hitec hs-645mg servo--which is SLOW..BLAH
-Factory Team Carbon fiber battery strap- blue
-Factory Team carbon front shock tower
-Factory Team carbon rear shock tower
-Factory Team Billet Shock caps
-Factory Team Billet Motor Plate
-Factory Team front/ rear spring kit
-Factory Team alloy servo mount/blue
-Factory Team alloy shock Bushings/blue
-Factory Team top plate - carbon
-Factory team rear chassis brace-carbon
-Factory Team caster blocks-30*
-Factory Team sway bar kit
-Factory Team front/rear carbon arms
-Factory Team unobatainium shock shafts
-factory Team 30* castor hubs
-MIP ball diff
-MIP CVD drive kit
-RPM gear cover
-RPM Ball Cups
- rmdesigns -underchassis protector
-radio spektrum dx2.0
-battery packs Turnigy 5200 -2s-30c- 7.4v lipo packs
I just sold my stock SC10 to my friend and that had the stock ESC with the 17.2 Brushed motor and that thing was fast with a lipo
#3885
depends on the track.. the beadlocs are HEAVIER then the stock wheels...the j-concepts wheels are about the same weight as the stockers maybe lighter?I love the goose bumps tons of traction...
