SC10 Thread
Old 06-10-2010 | 03:49 PM
  #4411
T-BirdJunkie's Avatar
From: Norwood, OH...and CCRCR and The OhioRCFactory
Just out of curiosity, is anybody running the PL slash F150 body on their SC10? If so, can you post a picture of how the rear is trimmed?
T-BirdJunkie is offline
Old 06-10-2010 | 04:11 PM
  #4412
I could not get switches to hook up, I run calibers and bowties now, but am gonna buy a set of megagrids and megabites and try them out. Also I know hot bodes just released the beams for indoors as well.
Attached Thumbnails SC10 Thread-hb-megabite-sc-tires.jpg   SC10 Thread-hb-megagrid-sc-tires.jpg   SC10 Thread-hb-beams-sc-tires.jpg
interplanet is offline
Old 06-10-2010 | 04:29 PM
  #4413
Switches have been fine for bashing.
Old 06-10-2010 | 05:06 PM
  #4414
Mr.Maim's Avatar
JC Goosebumps for hard-packed wet track racing. JC Double Dees for not-so-wet racing. Both in green compound.
Both wear exceptionally long and hook up well if your setup is correct. Lots of steering with the Double Dees.
Mr.Maim is offline
Old 06-10-2010 | 05:07 PM
  #4415
Mr.Maim's Avatar
Originally Posted by T-BirdJunkie
Never underestimate the usefulness of force and applying more torque to the hex driver
Let us know if the tires stay attached under use. I'd be concerned that the side ribs being pinched in the beadlocks will eventually cause the tires to come free.
Mr.Maim is offline
Old 06-10-2010 | 05:25 PM
  #4416
sly6t's Avatar
Originally Posted by sly6t
yA need a SLY CARBON CHASSIS lol
This is my carbon sc10 race truck , chassis is nearly done , its turned out pretty good , just waiting for a few things befor i turn a tyre with this weapon .
im waiting for :
engine and esc combo to get here .
new shocks and my grp wheels and race rubber.
Attachment 603164
Attachment 603165
Attachment 603166
Originally Posted by Driver86
You going to be selling those?
nah man sorry there hand made ,n with the time to make them id have to charge to much for them but then again if a super good price came up hahhahahaha lol i should have it running next week il bang up sum more pics when its going
sly6t is offline
Old 06-10-2010 | 05:52 PM
  #4417
So far they've passed the "hold one wheel and go WOT" test. It's a Castle 4600 with 20/84 gearing, so if that doesn't debead 'em, nothin will.
Old 06-10-2010 | 08:06 PM
  #4418
Having just done it...PL says "some trimming required"...
It's more like "chop out the grille and the entire ass end off the body then it might fit"
Old 06-10-2010 | 08:11 PM
  #4419
same with the silverado body, but the truck seems to jump much nicer with it.
Old 06-10-2010 | 09:44 PM
  #4420
Not a shock, considering you chopped the big parachute outta the back
WOOHOO, 500 posts! In a hair under six years!
Old 06-10-2010 | 11:24 PM
  #4421
Mr.Maim's Avatar
Sweet. So did you have to hack a bunch of the inside of the tire out for the bead to set?
Mr.Maim is offline
Old 06-10-2010 | 11:25 PM
  #4422
Didn't hack anything on the tire or the wheel, good sir
Old 06-11-2010 | 05:36 AM
  #4423
Driver86's Avatar
Oh, speaking of the transmission...
I was also looking at the parts list for the FT-SC10. The slipper plates and spring are different than the stock T4 and SC10. Does anybody have an opinion on their usefulness? Are they easier to find the "sweet spot" as advertised? I'd like to know from someone who has driven both the RTR and FT SC10s.
Even though Driver86 is putting all the Factory Team parts on his SC10, this is unnecessary as Driver86 likes his slipper tight at all times.
Driver86 is offline
Old 06-11-2010 | 05:46 AM
  #4424
Driver86's Avatar
Driver86 just installed the FT Red front and Gray rear springs along with an anti-squat plate. Will be testing tonight to see how it hooks up. It was great before with the stock motor, but when going to a beefier motor it got squirrelly in the rear again. Also put in the Futaba receiver to use with the new Futaba 2PL radio.
New setup:
Mudflaps removed
RPM front bumper and chassis brace
Pro-Line Caliber M3 tires on KMC wheels
Epic 15T 20 degree motor
Duratraxx Intellispeed ESC
30 degree front hubs
-1 Camber longest setting +2 washers each side under inside ball studs, stock toe
Rear shocks top middle hole, lower inside Gray springs 30wt oil
fron shock top middle hole, lower inside Red Springs 30wt oil
1 anti-squat plate
flipped battery plate with 2s hard case li-po positioned all the way back against shock tower
If this isn't dialed and glued then the next step is toe-in hubs
Driver86 is offline
Old 06-11-2010 | 06:53 AM
  #4425
yeah, it didnt fit very good at first, but now with that cut I have the front grill just over the bumber and it fits great. Its also almost an inch lower for the roofline, but a taller ride height.
